[FIXED] 0.3.6.913 only errors
Post by Pako » Thu Mar 22, 2007 3:45 pm
In my PC (Win XP Home) make version 0.3.6.913 only this:
Traceback (most recent call last) (913):
File "d:\Programs\E\EventGhost\eg\ThreadWorker.py", line 108, in DoOneEvent
File "d:\Programs\E\EventGhost\eg\ThreadWorker.py", line 53, in __call__
File "d:\Programs\E\EventGhost\eg\ActionThread.py", line 55, in StartSession
File "d:\Programs\E\EventGhost\eg\Document.py", line 165, in Load
File "d:\Programs\E\EventGhost\eg\Document.py", line 173, in AfterLoad
AttributeError: Section instance has no attribute 'time'
Configuration tree is empty.
Post by Bitmonster » Thu Mar 22, 2007 4:01 pm
Should be fixed in the next build. As a workaround delete the "Config.py" file in EGs application data folder. Should be located in something like:
C:\Documents and Settings\[USERNAME]\Application Data\EventGhost\Config.py
Post by Bitmonster » Thu Mar 22, 2007 4:30 pm
0.3.6.923 is up.
Post by Pako » Fri Mar 23, 2007 7:56 am
0.3.6.923 - only little modification:
 Traceback (most recent call last) (923):
   File "d:\Programs\E\EventGhost\eg\Document.py", line 174, in AfterLoad
 AttributeError: Section instance has no attribute 'expandState'
Post by Bitmonster » Fri Mar 23, 2007 11:24 am
Fabulous. Ok, 0.3.6.925 is up.
Post by Pako » Fri Mar 23, 2007 1:59 pm
0.3.6.925 - responsible change:
Step 1 (Clear instalation, EG opens MyConfig.xml):
 Plugin: X10: Generic X10
 Error starting plugin: X10 Remote
 No X10 receiver found!
 Plugin: Zoom Player
 Plugin: Winamp
 Enable exclusive: Keyboard Emulation
 Main.OnInit
 Main.OnInitAfterBoot
Step 2 (I'am try open "Options..." dialog):
   File "wx\lib\masked\numctrl.pyc", line 1176, in OnTextChange
   File "wx\lib\masked\numctrl.pyc", line 1201, in GetValue
   File "wx\lib\masked\numctrl.pyc", line 1552, in _fromGUI
   File "wx\lib\masked\numctrl.pyc", line 885, in _GetNumValue
 UnicodeDecodeError: 'ascii' codec can't decode byte 0xa0 in position 0: ordinal not in range(128)
   File "d:\Programs\E\EventGhost\eg\MainFrame\__init__.py", line 716, in OnCmdOptions
     eg.OptionsDialog().DoModal()
   File "d:\Programs\E\EventGhost\eg\Dialogs\OptionsDialog.py", line 96, in __init__
     max=100
   File "d:\Programs\E\EventGhost\eg\Controls\SpinIntCtrl.py", line 55, in __init__
     integerWidth=integerWidth
   File "d:\Programs\E\EventGhost\eg\Controls\SpinNumCtrl.py", line 76, in __init__
     **new_args
   File "wx\lib\masked\numctrl.pyc", line 597, in __init__
   File "wx\lib\masked\numctrl.pyc", line 848, in SetParameters
Post by Bitmonster » Fri Mar 23, 2007 2:09 pm
Very interesting. What characters are commonly used in your country to group decimals and as a decimal separator?
Or in other words, how would you type 10,000.00 in your country?
Post by Pako » Fri Mar 23, 2007 2:22 pm
Bitmonster wrote:Very interesting. What characters are commonly used in your country to group decimals and as a decimal separator?
Default settings:
group decimals separator = " " (space)
decimal separator = "," (comma)
Bitmonster wrote:Or in other words, how would you type 10,000.00 in your country?
10 000,00
Post by Bitmonster » Fri Mar 23, 2007 2:24 pm
I just uploaded 0.3.6.926. There is a little chance, it will fix this error.
Post by Pako » Fri Mar 23, 2007 2:32 pm
0.3.6.926 - sorry
"Options..." dialog choice:
   File "d:\Programs\E\EventGhost\eg\Dialogs\OptionsDialog.py", line 92, in __init__
     memoryLimitSpinCtrl = eg.SpinIntCtrl(
   File "d:\Programs\E\EventGhost\eg\Init.py", line 277, in __getattr__
     mod = __import__("Controls.%s" % name, fromlist=[name])
   File "d:\Programs\E\EventGhost\eg\Controls\SpinIntCtrl.py", line 27, in <module>
     class SpinIntCtrl(eg.SpinNumCtrl):
   File "d:\Programs\E\EventGhost\eg\Controls\SpinNumCtrl.py", line 31, in <module>
     class SpinNumCtrl(wx.Window):
   File "d:\Programs\E\EventGhost\eg\Controls\SpinNumCtrl.py", line 38, in SpinNumCtrl
     "groupChar": unicode(localedict['thousands_sep']),
Post by Bitmonster » Fri Mar 23, 2007 2:37 pm
Next try: 0.3.6.927
BTW: I just learned, that there a two space characters in Windows. The normal one with ASCII ordinal 32 and a second one (so called "protected space") with an ordinal of 160. And your locale seems to use the second one as decimal group character.
Post by Pako » Fri Mar 23, 2007 2:45 pm
0.3.6.927 - "Options..." dialog choice - bingo !
I must be away.
Another errors next time.
