[FIXED] Zoom Player 5 and Task plugin
kricker
Post by kricker » Wed Jan 03, 2007 5:27 am
EvenGhost will not monitor the activate or deactivate of Zoom Player 5 if it is set to show icon in the system tray and not the taskbar. When Zoom Player is set this way, as soon as it is launched Evenghost shows it as created then immediately destroyed although the program is still in fact open. I am using 0.3.4_build_836.
Post by Bitmonster » Wed Jan 03, 2007 3:54 pm
Confirmed. The same applies to every program, that has no button in the taskbar (Trillian for example). Currently this cannot be changed. Windows simply does not send events for them.
I will look someday, if I can implement a lower level hook, but this is not so easy and therfor I can't give any time schedule.
kricker
Post by kricker » Wed Jan 03, 2007 4:32 pm
Bitmonster wrote:Confirmed. The same applies to every program, that has no button in the taskbar (Trillian for example). Currently this cannot be changed. Windows simply does not send events for them.
No problem. I'll just make sure I don't have anything set that way for now.
Post by Bitmonster » Fri Apr 20, 2007 2:31 pm
It seems, we have fixed this in 0.3.6.953.
