[FIXED] Speech plugin and last release
Bob
Post by Bob » Thu Oct 26, 2006 6:49 pm
With the 0.3.2 version I can use this plugin. But with the last release 0.3.3 build 780 I can't add a speech command.
When I try to valid the command's creation the command is not added to the macro-command.
Thanks in advance
Bob
Post by Bitmonster » Thu Oct 26, 2006 6:57 pm
Uhps, a small bug, that must be arised at some refactoring. Since I'm currently testing the new wxPython release, updates are not as easy as normally. You can fix it with a text-editor like notepad. Open the file plugins/Speech/__init__.py and change the last line from:
            if dialog.AffirmedShowModal():
                ReturnResult()
to:
                return ReturnResult()
Bob
Post by Bob » Thu Oct 26, 2006 7:27 pm
fixed !! :D
