[FIXED] Serial Plug-in - Errors on Load
Quantus
Post by Quantus » Thu Sep 21, 2006 2:24 pm
I am a recent EG convert.
Before using EG I was only peripherally aware of Python, but I wanted to create a plug-in to control my Yamaha RX-V1000 receiver via RS232, so I decided to install the ActiveState Python package.
Before installing the ActiveState Python package, the Denon serial plug-in and the general serial plug-in loaded without problems. After installing ActiveState, the plug-ins load with errors. Uninstalling ActiveState had no effect, and neither did re-installing EG. To make matters somewhat more complicated, I am not certain that ActiveState is the culprit.
I have included a screenshot of the error. FWIW, I have played with the Serial plug-in code, and functions like pointer() and sizeof() seem to be failing.
Any suggestions? Or am I just going to have to give-up on serial control?
Thanks for any help
Mark
Post by Bitmonster » Thu Sep 21, 2006 4:03 pm
Could you please update to the latest beta-version and try it again?
http://www.eventghost.org/forum/viewtopic.php?t=86
Installing ActivePython or any other Python distribution should have no effect on EventGhost. EventGhost runs everything from its own Python-interpreter.
You normally don't need to install anything to develop plug-ins for EG, but if you install ActivePython you at least have a small editor that is Python-aware and you get Python's help-files. And this can be handy.
Quantus
Post by Quantus » Thu Sep 21, 2006 10:08 pm
Well... I have no idea what the problem was, but your suggestion solved it.
Backed-up XML
Uninstalled EG
Deleted EG folder in Program Files
Installed 0.3.3 Build 740 Setup
Installed 0.3.3 Build 746 Update
Problem solved. Serial plug-in loads without a hitch.
Mark
