WIN10, EG5-RC6 - Warnings at DVBViewer Start
Kagor
Post by Kagor » Mon Dec 16, 2019 10:17 am
with WIN10 (Home, 32bit) some warnings appear after the start command of DVBViewer (DVBViewer: Start DVBViewer), which can be seen in the log in debug mode. This causes a delay of about 15 sec until EG reacts again. I have inserted the corresponding passage of the log. Is it possible to fix this problem?
Thanks and regards
Klaus
debugEGStartDVBViewer.txt
Log file from debug
(7.87 KiB) Downloaded 66 times
Re: WIN10, EG5-RC6 - Warnings at DVBViewer Start
Post by kgschlosser » Mon Dec 16, 2019 7:03 pm
I need a copy of your tree to see what is going on.
you can PM it to me. You will have to zip it up.
