Discuss
MaxPayne
Discuss
Post by MaxPayne » Sun Sep 08, 2019 8:11 pm
Hi!
Win 7 x64
The mouse has a noticeable lag that is quite annoying when editing the configuration. Also the desktop remote crashes in a loop occasionally and generates the error: This didn't happen in r1710.
04:34:11 Traceback (most recent call last) (0.5.0-rc2):
04:34:11 File "wx\lib\buttons.pyc", line 330, in OnLeftDown
04:34:11 File "wx\_core.pyc", line 10638, in CaptureMouse
04:34:11 PyAssertionError: C++ assertion "!wxMouseCapture::IsInCaptureStack(this)" failed at ..\..\src\common\wincmn.cpp(3271) in wxWindowBase::CaptureMouse(): Recapturing the mouse in the same window?
Thanks.
Re: Discuss
Post by kgschlosser » Mon Sep 09, 2019 12:32 am
Fist off you are using an old release of EG 0.5.
You can get the latest one here. https://github.com/EventGhost/EventGhos ... v0.5.0-rc6
You also need to be a bit more descriptive with the problem. Where are you having issues with the mouse? What do you have open in EG? What plugins do you have installed? Does the problem happen all the time?
