Plugin installs not working
slattynan
Post by slattynan » Fri Nov 30, 2018 6:20 pm
When running the plugin files they are no longer prompting install in EG. I have tried a working plugin on the previous version and then tried it on 2 installs on 2 different machines, before and after upgrading to the latest version.
jachin99
Re: Plugin installs not working
Post by jachin99 » Sat Dec 01, 2018 5:27 am
I have seen the prompt hide behind other windows at times. Can you confirm this isn't happening for you? They seem to work fine for me on EG 5 RC 4
Post by kgschlosser » Sat Dec 01, 2018 11:13 am
I think there still may be some kinks that need ironing out in the latest RC. if you close EG fully and then double click the install file does it work then???
slattynan
Post by slattynan » Sat Dec 01, 2018 4:22 pm
HI,
Definitely not hidden behind other windows. Tried with tablet mode on and off too in-case that had an effect.
It does work when EG is closed
Post by kgschlosser » Sun Dec 02, 2018 12:13 am
i have already fixed this and the restart problem. if you want the corrected files I can attach them to a post.
slattynan
Post by slattynan » Sun Dec 02, 2018 8:01 am
nah, I have a workaround now. happy days :D
