Pulling variables from HTTP webserver
eli2k
Post by eli2k » Tue Sep 26, 2017 12:47 am
I'm building a remote to control actions on a PC through the webserver component. Rather than making a bunch of macros for each HTTP.command, I noticed that I can use HTTP.* to capture every HTTP event. Can I extract what is in the * portion in order to make the programming in Python easier? I could not figure out how to turn that wildcard into a variable that I can use later. Thank you.
setup: windows 7 + EventGhost 0.5.0-rc4 + Intel nuc6i5syh
Boolean263
Re: Pulling variables from HTTP webserver
Post by Boolean263 » Tue Sep 26, 2017 1:43 am
You can access the `eg.event` object from Python to get more information about the event that triggered your macro/action. To answer your direct question, everything after the "HTTP." can be found in `eg.event.suffix`.
I tried to document it all on this wiki page; please let me know if you still have questions, because it'll help me figure out what needs to be added.
Good luck!
eli2k
Post by eli2k » Tue Sep 26, 2017 1:51 am
Good luck!
Thanks! I ran across the old webserver page (www.eventghost.net/mediawiki/index.php?title=Webserver) and couldn't find anything beyond how to use the webserver component.
I'll take a look at it what you posted. I was just doing some searching before seeing this, and found someone talking about eg.event.payload. I found I could formulate a URL like index.htm?Control&Stop, and EG would capture every Control event into one macro, and I could use eg.event.payload[0] to get that first argument/parameter, which is Stop, and from there I could do whatever I want with it.
I was planning to have that one macro house every command and what to do inside one python script and do actions depending on which application is active. Do you think that will be slower than making a separate macro for each command?
