switching between programs
longplayer
Post by longplayer » Fri Sep 22, 2017 11:40 am
Hi all
I am using version 0.4.1 of Eventghost in windows vista
I need to be able to switch between 3 programs as follows
OPEN A PROGRAM ON STARTUP
PRESS A KEY ( SET TO ANY KEY )
CLOSE THE PROGRAM (not mimimise) AND OPEN SECOND PROGRAM
PRESS SAME KEY
CLOSE SECOND PROGRAM AND OPEN THIRD PROGRAM
PRESS SAME KEY
CLOSE THIRD PROGRAM AND OPEN FIRST PROGRAM
ETC.
Help please
LONGPLAYER
Boolean263
Re: switching between programs
Post by Boolean263 » Fri Sep 22, 2017 11:30 pm
My first thought on achieving this would be to create a folder containing three macros, one for each of the programs you want to run. Then you can use the Enable Item Exclusively action to turn on the one for the second program from the one for the first program, and so on. You'd need to add the same key event to all three, but only the currently enabled one would process the keystroke.
Then in another folder, a macro triggered on Main.Init that uses Enable Item Exclusively to enable the first-program macro, and then jumps to it.
That's my thought. I'm sure there are other ways to achieve this end.
longplayer
Post by longplayer » Sat Sep 23, 2017 7:44 am
Many thanks for your helpfull reply. It might take me a bit of learning my way but I will try it.
LONGPLAYER
topix
Post by topix » Mon Sep 25, 2017 11:29 am
That's nearly the same question you asked around a hour earlier: viewtopic.php?f=2&t=9835
See that post for my answer.
longplayer
Post by longplayer » Mon Sep 25, 2017 4:05 pm
Hi again
Thanks TOPIX for your reply. I will have a look at that and have a play around.
LONGPLAYER
