Has anybody done anything with Sensibo Sky?
Re: Has anybody done anything with Sensibo Sky?
Post by kgschlosser » Sun Mar 04, 2018 6:32 pm
it should work that way. we will find out i guess.
It seems to when the room temperature is changing
Mastiff
Post by Mastiff » Sun Mar 04, 2018 6:34 pm
Yeah, seems like that. :mrgreen:
Post by kgschlosser » Sun Mar 04, 2018 6:39 pm
we are going to have to wait a week to get the unicode 100% right. it may be easier this time around if you can do the VM with TeamViewer. this would be ideal since it seems there is something that causes a change. the unicode handling is the single biggest thing I hate about python 2.
Post by kgschlosser » Sun Mar 04, 2018 6:41 pm
I forgot I still had eventghost running with the API key in plac. i see events for the temperature changing and the power turning on and off. so that is a good thing.
Mastiff
Post by Mastiff » Sun Mar 04, 2018 8:12 pm
You probably did, but no more. :mrgreen: I have deleted that key and made another one. I can't take any chances when my renters are there. So we'll see next weekend. Oh, btw, to change the API key I had to delete the macro directory and the plug-in, and then add it all anew. Trying to open the plug-in configuration gave me a red mess in the logger. But we'll get to that next wekeend. Have a nice week!
Post by kgschlosser » Mon Mar 05, 2018 12:19 am
Ok next weekend it is. We have made some progress I am happy to say.
Post by kgschlosser » Mon Mar 05, 2018 12:21 am
I will also need a copy of that teaceback. I don't know if you had debugging enabled. If you did the traceback will be saved to %APPDATA%\EventGhost\log.txt
Mastiff
Post by Mastiff » Mon Mar 05, 2018 8:17 am
I'll get a VM set up and do logging on that one this week. :mrgreen:
Mastiff
Post by Mastiff » Tue Mar 06, 2018 2:43 pm
I have created a Windows 7 VM with only EG and your plug-in activated, plus Team Viewer. But where do I enable debugging? I can't find that in the plug-in.
Post by kgschlosser » Tue Mar 06, 2018 5:23 pm
its not in my plugin. it's in EG. start EG from a command line with /debug
Mastiff
Post by Mastiff » Tue Mar 06, 2018 5:32 pm
Gotcha. Will do. I'll put that in the startup shortcut.
Post by kgschlosser » Tue Mar 06, 2018 6:16 pm
change the name of the startup shortcut and then disable the startup from inside of EG. this is because EG will check the startup shortcut and will delete it and make a new one if it is modified.
Mastiff
Post by Mastiff » Tue Mar 06, 2018 7:00 pm
Done.
Mastiff
Post by Mastiff » Mon Jul 02, 2018 7:40 pm
Suddenly the script is failing. I have added more network cards to the automation VM, and I think that's when it started. Does this tell you anything:
21:37:10   Exception in thread Thread-345:
21:37:10   Traceback (most recent call last):
21:37:10     File "threading.pyc", line 801, in __bootstrap_inner
21:37:10     File "threading.pyc", line 754, in run
21:37:10     File "C:\ProgramData\EventGhost\plugins\SensiboSky\__init__.py", line 176, in do
21:37:10       d = self.device_names
21:37:10     File "C:\ProgramData\EventGhost\plugins\SensiboSky\__init__.py", line 160, in device_names
21:37:10       available_devices = self._sensibo_sky.device_names
21:37:10     File "C:\ProgramData\EventGhost\plugins\SensiboSky\pySensibo_Sky\__init__.py", line 1169, in device_names
21:37:10       return sorted(self.devices.keys())
21:37:10     File "C:\ProgramData\EventGhost\plugins\SensiboSky\pySensibo_Sky\__init__.py", line 1185, in devices
21:37:10       params=params
21:37:10     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\api.py", line 71, in get
21:37:10       return request('get', url, params=params, **kwargs)
21:37:10     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\api.py", line 57, in request
21:37:10       return session.request(method=method, url=url, **kwargs)
21:37:10     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\sessions.py", line 475, in request
21:37:10       resp = self.send(prep, **send_kwargs)
21:37:10     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\sessions.py", line 585, in send
21:37:10       r = adapter.send(request, **kwargs)
21:37:10     File "C:\Program Files (x86)\EventGhost\lib27\site-packages\requests\adapters.py", line 467, in send
21:37:10       raise ConnectionError(e, request=request)
21:37:10   ConnectionError: HTTPSConnectionPool(host='home.sensibo.com', port=443): Max retries exceeded with url: /api/v2/users/me/pods?fields=id%2Croom&apiKey=MY KEY (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x050BD410>: Failed to establish a new connection: [Errno 10060] Et tilkoblingsfors\xf8k mislyktes fordi den tilkoblede parten ikke svarte p\xe5 riktig m\xe5te etter en tidsperiode, eller den etablerte tilkoblingen mislyktes fordi den tilkoblede verten ikke svarte',))
21:37:10
Post by kgschlosser » Mon Jul 02, 2018 10:30 pm
you can try changing the binding order for the network cards. other then that I am not sure I do not know the internal mechanics of the requests library. that is the library used for web requests.
Can you load a webpage on the VM since you added the network cards? the only thing i can think is it is having problems trying to connect to the server.
