Has anybody done anything with Sensibo Sky?
Re: Has anybody done anything with Sensibo Sky?
Post by kgschlosser » Fri Feb 23, 2018 10:49 am
ok well this is where I would need access to the unit to make it a whole lot faster process of debugging this thing. Otherwise it is going to be a whole lot of back and forth. it's up to you. The only thing I will need to do is to turn the unit on and off. nothing more. If i get that to work everything else should fall into place
Mastiff
Post by Mastiff » Fri Feb 23, 2018 11:50 am
You're not reading my messages, are you? :mrgreen: :mrgreen: :mrgreen: I PM'ed you the API key two days ago! And I think I told you in the thread that I would do it too!
Post by kgschlosser » Fri Feb 23, 2018 12:22 pm
yeah I know I have the key. but you said something about unplugging the unit. so that would remove my ability to change anything on the unit.
Mastiff
Post by Mastiff » Fri Feb 23, 2018 12:26 pm
Ah, sorry. No, that's the physical heat pump I plugged out, not the Sensibo. But I actually just moved the Sensibo outside of the range of the heat pump. It doesn't take "talkback" from the pump, so it won't know the difference.
Post by kgschlosser » Sat Feb 24, 2018 3:57 am
ok.... give this whirly bird a twirl.
the control has changed. run the file as before just DO NOT add your api key or device name.
test.py
(32.16 KiB) Downloaded 90 times
Mastiff
Post by Mastiff » Sat Feb 24, 2018 6:57 am
I get the API key prompt, and I input that. And then connect Varmepumpe ovenpå. And I get some unicode error again. :(
Enter Command: connect Varmepumpe ovenpå
D:\test.py:843: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
  File "py.py", line 29, in <module>
  File "D:\test.py", line 953, in <module>
    dev = client.get_device(device_name)
  File "D:\test.py", line 850, in get_device
    raise AttributeError
AttributeError
With double quotes:
Enter Command: connect "Varmepumpe ovenpå"
AttributeError
Post by kgschlosser » Sat Feb 24, 2018 11:51 am
i created a github repository for this https://github.com/kdschlosser/Sensibo_Sky_API
I think I may have fixed that issue. You can download the latest version from there. you will have to rename the __init__.py to test.py and run it the same way as you just did.
I tested this thing out and I was able to power the unit on and off successfully. I didn't mess about with any of the other things.
Mastiff
Post by Mastiff » Sat Feb 24, 2018 4:01 pm
I'm afraid there's something wonky there. Or I did something wrong, I don't know.
D:\>"c:\program files (x86)\eventghost\py" test.py
  File "D:\test.py", line 7
    <!DOCTYPE html>
SyntaxError: invalid syntax
Scratch that. For some reason the file isn't downloaded when I click save as, I'm downloading some kind of Github HTML.
Mastiff
Post by Mastiff » Sat Feb 24, 2018 4:08 pm
I just don't get it. I can't seem to download it correctly. I tried to save as a raw file, but I still got errors:
  File "D:\test.py", line 44, in <module>
    import requests  # NOQA
ImportError: No module named requests
Post by kgschlosser » Sun Feb 25, 2018 6:06 am
go to the repository. you should see a green button that says "clone or download" when you click on it a menu opens and gives you 2 options. one is open with desktop. the other is download as zip. you want to download it as a zip.
Post by kgschlosser » Sun Feb 25, 2018 6:10 am
I also fixed the import error with requests. that was my bad.. sorry..
Mastiff
Post by Mastiff » Sun Feb 25, 2018 7:19 am
I got further, but I'm afraid I got this:
D:\test.py:916: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
Command not valid for this device/mode
Enter Command:
Post by kgschlosser » Sun Feb 25, 2018 8:20 am
fixed
Mastiff
Post by Mastiff » Sun Feb 25, 2018 8:27 am
Seems like there's another one:
D:\test.py:1003: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
Enter Command:
I still have the device available for use if you want to check yourself. I can keep it like that for around 12 more hours.
Post by kgschlosser » Sun Feb 25, 2018 8:53 am
I am using it right now without issue.
C:\Python36-32\python.exe C:/Users/Administrator/Documents/GitHub/pySensibo_Sky/pySensibo_Sky/__init__.py
Enter API Key:
"help" for a list of commands
Enter Command: start poll 0.2
Enter Command: power on
Varmepumpe ovenpå.power = True # this is an event
Enter Command: power off
Varmepumpe ovenpå.power = False # this is an event
