Amazon Echo Skill EchoToEventGhost
ptiernan
Re: Amazon Echo Skill EchoToEventGhost
Post by ptiernan » Thu Mar 21, 2019 1:25 pm
Hi slattyman,
Looking for some help, I am newby to EventGhost and Alexa. Tried to follow this tutorial but go stuck on the Interaction Model.
I copied your model but I get the error below when I build the model.
The prompt "Slot.Validation.XXXXXXXXXXX.XXXXXXXXXXXX.XXXXXXXXXXXXX" is used in the dialog model but is not declared in the prompt bundle. Error code: InvalidPromptReference
Thanks for the help in advance.
Cheers Paul
slattynan
Post by slattynan » Sun Jun 02, 2019 10:02 am
hi paul, sorry for slow response, I've been super busy.
You need to replace the slot validation code (XXX's) in my example with your unique number. it is somewhere in the tutorial. send me a PM if you are atill struggling and I will step you through it
I have been doing some more work on this as i wanted to truely understand how to use and modify it. Once i've completed i will post some better structured examples to help others.
slattynan
Post by slattynan » Tue Jun 18, 2019 10:17 pm
Hi Guys,
I have finally finished updating the plugin code to provide additional functionality. The changes now allow 3 modes of interaction, as below:-
  • OPTION 1
    • (Invocation, Intent, Action)
      • Example 1: Alexa, "Event ghost", "perform action", "lights on"
      • Example 2: Alexa, "ask Event ghost to perform action lights on"
      • Example 3: Alexa, "Event ghost", "Dim lights", "in dining room"
    Benefit: The actions can be configured with all sorts of pre-configured structure using the Alexa toolkit. This is useful if your want content like numbers, dates, weekdays etc... or want to setup lots of commands without spending a lot of time configuring Alexa skills. I have one skill setup with the Action slot defined as a search query, this allows me to pass any command to EG to trigger events (i,e Alexa, "Event ghost", "perform action", what ever you say)
    Drawback: Lots of words to initiate actions which wears thin (hence my update)
  • OPTION 2
    • Shorter (Invocation, Intent)
      • Example 1 Alexa, "Event ghost", " play music"
      • Example 2 Alexa, "ask Event ghost to play music"
    Benefit: Requires a little effort to configure, but provides restricted options to ensure Alexa understands the command. Can be configured with multiple utterances (word variances)
    Drawback: Not as short as it can be
  • OPTION 3
    • Shortest (Invocation)
      • Example 1 Alexa, "initiate music"
    Benefit: Few words required
    Drawback: Most effort to configure, requires an Alexa skill per command, linked by the skillid to the EG python code. Also you have to stay clear of Alexa's trigger commands (and there are loads which you will stumble over lots! For example "Play" or "start" would have been the obvious choice rather than "initiate music", if they weren't restricted!)
All my code changes are very minor, however it took me a while to get my head around m19brandon's hard work, mostly because I had no experience with Alexa skill writing.
Before I share the goodness I need to update the tutorial, which is more work than I'd like thanks to Amazon's updates to the management consoles.
K is m19brandon likely to review and update github? Do you have any way to contact him? or suggestions how to go about updating this? It's not something I have done before.
Post by kgschlosser » Wed Jun 19, 2019 10:17 am
@slattynan
Thats a good question. I am not sure. you can try sending him a PM here. and open an issue on github and see if you get a response.
The end game is it does not really matter. if you do not get a response from him you can post a link to your fork here in the forums.
well this is a multi ended question. it all depends on what route you want to go.
If @m19brandon responds to you then you will need to lean how to use github if you do not already know. If you need help with it send me a PM and I can walk you through what to do.
If you get no response you have 2 choices. one is you can attach a copy of the new plugin into this forum. or you can create a github account. fork the original repository make the changes and then post a link to the repo here.
Because the original code is on GitHub it would be best to fork it and make the changes. so there is a trail giving the original author credit for the unmodified portion of the code.
slattynan
Post by slattynan » Wed Jun 19, 2019 2:48 pm
Ta K, that's enough guidance. I'll get on it :)
There may also a way I could configure it to work with the smart home skill, this would address the issues with option 3. If this becomes a popular request I'll consider updating it. Personally I'm happy with it... for now :D
slattynan
Post by slattynan » Thu Jul 11, 2019 5:06 pm
Getting Started with EchoToEG for Amazon Alexa
Overview
EchoToEG allows you to trigger events in EventGhost using voice commands through Amazon Alexa.
There are 3 ways to interact which are configured in Alexa skills.
There is a detailed step-by-step instruction with screenshots in the repo should you get stuck. It's perhaps a little too detailed for experienced users, but should be useful for trouble shooting. https://github.com/nexgenclassic/EchoTo ... oToEG2.pdf
Option 1 – Invocation, intent and action:-
- (Invocation, Intent, Action)
- Benefits:
  • The actions can be configured with all sorts of pre-configured structure using the Alexa toolkit. This is useful if you want content like numbers, dates, weekdays etc...
  • Can be configured with lots of commands without spending a lot of time configuring Alexa skills.
  • The example is configured with Action slot defined as a search query, this allows you to pass any command to EG to trigger events (i,e Alexa, "Event ghost", "perform action", whatever you say)
- Drawback:
  • Lots of words to initiate actions
Option 2 - Invocation and intent:-
- Shorter (Invocation, Intent)
  • Example 1: Alexa, "Event ghost", " play music"
  • Example 2: Alexa, "ask Event ghost to play music"
- Benefits:
  • Requires a little effort to configure
  • Provides restricted options to ensure Alexa understands the command.
  • Can be configured with multiple utterances (word variances)
- Drawbacks:
  • Not as short as it can be
Option 3 - Invocation only:-
- Shortest (Invocation)
  • Example 1: Alexa, "initiate music"
- Benefits:
  • Few words required
- Drawbacks:
  • Most effort to configure, requires an Alexa skill per command, linked by the skillID to the EG python code.
You have to stay clear of Alexa's trigger commands (and there are loads which you will stumble over lots! For example "Play" or "start" would have been the obvious choice rather than "initiate music", if they werent restricted!)
Setup Tutorial
Step 1 (Create your AWS Lambda function that your skill will use)
1. Download or clone my EchoToEventGhost github project [https://github.com/nexgenclassic/EchoToEventGhost](https://github.com/nexgenclassic/EchoToEventGhost)
2. Make sure you have your EventGhost Webserver is running and you can post to from outside your network. 3. If you do not already have an account on AWS, go to Amazon Web Services and create an account.
4. Log in to the AWS Management Console and navigate to AWS Lambda.
5. Click the region drop-down in the upper-right corner of the console and select either **US East (N. Virginia)** or **EU (Ireland)**. Lambda functions for Alexa skills must be hosted in either the **US East (N. Virginia)** or **EU (Ireland)** region.
6. If you have no Lambda functions yet, click **Create a Lambda Function**.
7. Select **Author from scratch**.
8. Click in the empty box and select **Alexa Skills Kit** , then next.
9. For the function name enter **EchoToEGv3** , the Description can be left blank, and for the runtime select **Node.js 6.10**
Note: If Node.js 6.10 is not available select a later version. You will be presented with more options later on.
10. Select **Create a new role with basic Lambda permissions** from the drop down.
11. Under the Lambda **function** **code** section leave as **Edit code inline.**
12. Delete the existing code and then **copy in the code** from [\EchoToEventGhost\AlexaSkillKit\_Code\EchoToEGv2.js](https://github.com/nexgenclassic/EchoTo ... oToEGv2.js)
13. Edit the variables in the code:-
  • Line 17: Is your EventGhost Webserver using **http** and https
  • Line 19: **Enter your External IP** or domain name
  • Line 22: Enter the **port number** you configured in the EventGhost Webserver
  • Lines 30 & 31 are your EventGhost Webserver user name and password
Note: There are other variables that can be set for added security or personalisation. It is recommended you get the function working before exploring these.
14. Under the **Lambda function handler and role** section, leave **Handler** and **Role** as is and for **Existing role** select "lamba\_basic\_execution"
15. Leave the other sections as is and click **Next** and then on the next page click **Create Function**
16. Under **Actions** you can test your function by using the **Configure test event** , change the name of **Hello World** as needed and pasted the contents of [\EchoToEventGhost\AlexaSkillKit\_Code\EchoToEG\_TestEvent.xml](https://github.com/nexgenclassic/EchoTo ... tEvent.xml) (Line 23 is the command that is passed) and then **Save and Test** If all works you could see an event in your EventGhost log.
Step 2 (Create your Alexa Skill and link your Lambda function)
1. Sign in to the **Amazon developer portal**. If you havent done so already, you'll need to create a free account. [https://developer.amazon.com/edw/home.html#/](https://developer.amazon.com/edw/home.html#/)
2. From the top navigation bar, select **Alexa**.
3. Under **Alexa Skills Kit** , choose **Create Skill**.
4. Choose **Add a New Skill**.
5. Name your skill. This is the name displayed to users in the Alexa app. **Event Ghost** is a good choice.
6. Leave **Custom** and **provision your own** ptions selected.
7. Click **create skill**.
8. Leave from scratch selected, click **choose**
9. Select **Invocation** in the left side column.
10. Create an invocation name. This is the word or phrase that users will speak to activate the skill. **Event Ghost** is a good choice. Amazon recommends against signal word invocation name.
11. Click **JSON Editor** in the left side column, paste the JSON code from [\EchoToEventGhost\AlexaSkillKit\_Code\IntentSchema.txt](https://github.com/m19brandon/EchoToEve ... Schema.txt)
12. Click **Endpoint** in the left side column and then select **AWS Lambda ARN**.
13. Click Copy to Clipboard to **copy your skill id**.
14. Go **back the AWS Console tab** and paste the skill ID into the **Skill ID box** and click **Add** and then **Save**.
15. Return to the **Alexa skill site** and paste your **ARN number** into the **Default Region**.
16. Click Save **Endpoints** , then **Save Model** and then **Build Model**.
Step 3 (Ensure your skill is linked to your Alexa)
1. Open the **Alexa app** on your **mobile phone**.
  • Click on the burger menu on the top left and select **SKILLS & GAMES**.
  • Goto **Your Skills** and **select Dev**.
  • **Open the skill** (Event Ghost or whatever your name it) and select **ENABLE TO USE**.
Step 4 (EventGhost, add some code to make stuff happen)
1. Create a new Python Script Macro, Name it EG Alexa Welcome Script, copy in the contents of [\EchoToEventGhost\EventGhost\_Code\PythonWelcomeScript.py](https://github.com/nexgenclassic/EchoTo ... eScript.py)
2. Create a second new Python Script Macro, Name it EG Alexa Action Script, copy in the contents of [\EchoToEventGhost\EventGhost\_Code\PythonActionScript.py](https://github.com/nexgenclassic/EchoTo ... nScript.py)
3. Copy [\EchoToEventGhost\EventGhost\_Code\index.html](https://github.com/m19brandon/EchoToEve ... index.html) into your webserver folder.
4. Now it's time to talk to Alexa! Say: "Alexa, Event Ghost". It will error, this is normal.
5. From your EventGhost log, drag the HTTP.EchoToEGWelcome[etc…]. event into the welcome script macro.
6. Now talk to Alexa again! Say: "Alexa, ask Event Ghost to perform action test". It will error again.
7. From your EventGhost log, drag the EchoToEG [etc…]. event into the action script macro.
8. Test your Skill.
Setting up your commands
Example of Option 1 Configuration – Invocation, intent and action:-
The following steps are very similar to the steps completed previously, the main differences are:-
  • You are going to set the skill name to something relevant to the command you are making
  • Choosing your skill name will require more thought to avoid use of Alexa trigger words.
1. Open the alexa development console webpage [https://developer.amazon.com/alexa/console/ask](https://developer.amazon.com/alexa/console/ask) and edit your Event Ghost skill.
Note: If you want to use an invocation name other than "Event Ghost" create a new skill as before.
2. Add a new **Intent** and name it **LightsOnIn** is used in this example.
3. Click on **Create a new slot** and enter a slot name called "room". Change the Select a slot type to **AMAZON.Room**.
4. Add Sample Utterances "turn the {room} lights on", "lights on in {room}" and lights on {room}
5. Turn the " **Does this intent require confirmation?"** slider to the **on** position.
6. Add the **Alexa prompt,**"Do you want to turn the {room} lights on?".
7. Change the " **Is this slot required to fulfil the intent?**" slide to the **on** position.
8. Click **Save Model** and then **build model**. Confirm the build is successful.
9. Test your skill works. Say "Alexa, event ghost", Alexa will respond with a welcome response, reply "lights on", Alexa should respond "in which room", reply "Dining room", should prompt "do you want to turn the dining room lights on", reply "Yes", Alexa should respond "trying command lights on in dining room".
Note: You can shorten the Alexa command request in a number of ways when the skill is configured in this way. Example "Alexa, ask event ghost to turn the dining room lights on"
Note: You can change the acknowledgement to be relevant to the command. Open the EG Alexa Actions Script python script and you will see # section as an example.
Example of Option 2 Configuration– Invocation and intent:-
The following steps are mostly a reduced version of the steps in option 1.
1. Add a new **Intent** and name it **Play** is used in this example.
2. Add Sample Utterances "play music" and "play"
3. Click **Save Model** and then **build model**. Confirm the build is successful.
4. Test your skill works.
  • Say " **Alexa, event ghost**", Alexa should respond with one of the welcome responses configure in the event ghost python script.
  • Reply " **play**" Alexa should respond "got it, let's get rocking" or "got it let's get this party started".
Note: The play command has already got a preconfigured response in the EventGhost action python script. Take a look at it and review the script for understanding.
Example of Option 3 Configuration– Invocation only:-
1. The following steps are very similar to the steps completed previously, the only differences are:-
2. Open the **alexa developer console** web page and Click **Create** **Skill** within the **Alexa Skills Kit**
3. Name your skill. This is the name displayed to users in the Alexa app. In this example I have used **welcome me home**.
4. Leave **Custom** and **provision your own** ptions selected. Click **create skill**.
5. Create an invocation name. This is the word or phrase that users will speak to activate the skill. I have used **welcome me home** in the example. Amazon recommends against signal word invocation name.
Note: Invocation name cannot contain the launch words "ask", "begin", "launch", "load", "open", "play", "resume", "run", "start", "talk to", or "tell".
6. Enter a name for the intent. **WelcomeMeHome** is used in the example.
7. Add Sample Utterances. In this example I have used "welcome home".
Note: No spaces are allowed.
8. Copy your skill id from the **AWS Lambda ARN** within the **Endpoint** section.
9. Go back the AWS Console tab and add a new **Alexa Skills Kit** and paste the skill ID into the **Skill ID box** and click **Add**. Then **Save**.
10. Copy the ARN address to clipboard. Return to the Alexa skill tab and paste your **ARN number** into the **Default Region**.
11. Click Save **Endpoints** , **Save Model** and then **Build Model**. A message box confirming the build was successful should appear.
Note: There is no need to Publish the skill.
12. Open the **Alexa app** on your **mobile phone**.
13. Return to EventGhost and open the Python script associated to the **EG Alexa Welcome Script.**
14. Paste the skill ID over the amzn1.ask.skill.xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx text on line 28 of the example skill script. Ensure the apostrophes (') remain either side of the ID.
15. Customise the trigger command and return message to suit your needs. Examples:-
  • Existing code: eg.TriggerEvent('Invocation action example 1')
  • Example altered code: eg.TriggerEvent('Welcome me home')
  • Existing code: ReturnMsg = random.choice(WELCOME\_RESPONSES)
  • Example altered code: ReturnMsg = "Welcome home. Hasnt it been a lovely day"
16. Test your skill works. "Alexa, welcome me home".
slattynan
Post by slattynan » Thu Jul 11, 2019 5:08 pm
Hi guys,
Forked, updated and tutorial written. It turned into much more of a in depth monster than I realised it was going to be!! Honestly it was one of those, "I've started, some I'm damn well gonna finish" situations.
Hope it helps someone :D
Post by kgschlosser » Thu Jul 11, 2019 8:12 pm
Thanks for the awesome tutorial.. and I know what you are saying.. writing a tutorial sucks!
stuartjeffery
Post by stuartjeffery » Mon Jul 15, 2019 7:16 am
Great Tutuorial. Thanks you for taking the time.
I have still not mamaged to get this to work.
When i ask Alexa i get " there was a problem with the requested skills response". The python script in Eventghost is firing when the call comes in but doesnt appear to be giving anything back to the skill??
Attached is a screenshot from my eventghost screen
Anyone able to help?
slattynan
Post by slattynan » Mon Jul 15, 2019 9:59 pm
hi, let's figure it out.
have you opened the webserver port on your router?
Can you confirm you added the index file for your EG webserver?
If yes to both, try changing the port number. I had issues with port 80, im not sure if it was my router or my ISP, but with port 80 being the standard port for website traffic it makes sense to use another for this function
Also can you confirm what tutorial you followed for setting up the webserver? i struggled to find one to link to, so it would be useful for multiple reasons :D
stuartjeffery
Post by stuartjeffery » Tue Jul 16, 2019 7:55 am
Port is open on router as command comes in from Skill as shown in the screenshot.
I am using a non standard port of 1443.
I attach a screenshot of my webserver settings maybe this is the problem?
slattynan
Post by slattynan » Tue Jul 16, 2019 4:37 pm
Fair comment, you would think getting the command to come in would be the hard part! :D
Is your Windows firewall definitely not restricting the returned message?
Also, I don't have authentication enabled like you do in the screenshot. I would try disabling it and see if that fixes it.
I don't recommend disabling it as a permanent fix (for me I have it disabled to allow another function I use the webserver to work).
rdgerken
Post by rdgerken » Sat Nov 02, 2019 6:54 pm
For anyone still using this plugin, I've updated Brandon's github code with a change that adds a payload value for personId if you have it enabled on your Alexa skill and voice profile.
kkl
Post by kkl » Sat Nov 23, 2019 8:57 pm
Thanks very much slattynan for the update and clear directions.
Those with multiple Echo devices may want to know which device issued a command for location-aware logic. The device-specific id is actually encoded in the command string that comes from Amazon to the EG webserver. It's the second parameter that begins with 'amzn1.ask.device.AE47...' and continues on for quite a few characters (I won't copy the entire string in case there is a security issue). Each string like 'AE47'... appears to be unique to an Echo device. I've only tested for a few minutes, but the id appears to remain static and specific to each of my four Echo devices. To be useful, you'd probably want to convert it to something more human brain friendly. With this info, when you issue a command from a room, it's possible to know from which room the command originated in your decision logic.
Medy
Post by Medy » Wed Nov 27, 2019 10:32 am
If you have a decent desk microphone .. u can use the chrome auto voice plugin to forward events to eventghost.
another advantage you can use every wake up word you want.
Setup couldnt be easier....
my google home & alexa are collecting dust for a long time ...
they were eventghost input machines to begin with xD....
