How can I realize a periodically ping?
bernd
Post by bernd » Wed Sep 16, 2015 10:07 pm
as described in the heading, I am try to execute the ping command in regular intervalls. For example every 60 seconds in an endlees loop.
Can I do this with EG standart commands or have I manage this with phyton? I am already tried the automatic repeat command but without success.
Thanks in advance.
Kind regards,
bernd
Javier
Re: How can I realize a periodically ping?
Post by Javier » Wed Sep 16, 2015 11:59 pm
I think Paco's SchedulGhost plugin has a repeat function which will let you trigger an event which can be used to trigger your macro.
bernd
Post by bernd » Thu Sep 17, 2015 10:01 am
Thank you,
I am already tried the Scheduleghost plugin but I solved it with the EG trigger command.
1.Trigger (for example shortcut "Keyboard.Ctrl+P")
2.Command (in my case the Ping-Command)
3.EG-Command create a trigger (use the first trigger "Keyboard.Ctrl+P", you can also use a delay)
-> endlees loop
Kind regards
