Remote Controls
WharfRat
Remote Controls
Post by WharfRat » Sun Apr 20, 2014 8:31 am
I am starting a new topic for all the remote controls that do and do not work with EventGhost.
This is an important topic, which I may eventually have to hand over to one of the admins to continue.
Therefore, I have created a new identity for myself, which I will surrender.
So, for now, WharfRat is ControlFreak.
EventGhost 0.4.1.r1640
PHX01RN plugin v3.0.1
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:36 am
Part I : Introduction
This topic is about remote controls for EventGhost.
Its purpose is to serve as a resource.
From this, we can coherently update the list of supported remote controls on the EventGhost Web site pages and the distributed documentation.
It is also a place where you can ask questions about unknown remote controls.
Only the essentials are discussed here. Everything else should be directed to the forum topics for each particular remote and/or plugin.
The topic is structured as follows:
  • Part I : Introduction
    Part II : Explanation
    Part III : Reference codes
    Part IV : Remotes that work with EventGhost
    Part V : Remotes that do not work with EventGhost
    Part VI : Plugins
    Part VII : Installing a Remote Control
    Part VIII : Unknown Remote Controls
    Part IX : Useful links
    remote 0001
    remote 0002
    etc.
    and then queries and responses and comments and more remotes
    etc.
Hopefully, it also serves as a challenge to increase the population of Part IV, and decrease the population of Part V.
After much reorganization, to simplify things, this topic now also has two supplementary topics: Remote Control Plugins and Remote Control Diagnostics.
Last edited by ControlFreak on Sun Aug 17, 2014 5:21 pm, edited 11 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:53 am
Let us refer to the handheld part of a remote control as the transmitter.
Let us refer to the computer interface part of a remote control as the receiver.
DIY (Do It Yourself) refers to a handmade device.
The details for each remote control follows a consistent format.
remote code: the reference code for this remote
  • see Part III
    this is the preferred way to refer to this remote
works: yes or no
  • yes is if the remote works with EventGhost
    no is if the remote does not work with EventGhost
name: the common way to refer to this remote
  • this usually refers to the brand and model by which it is usually known
    see also alternate names
a picture, if there is one, preferably including both the transmitter and the receiver
Vendor ID: hexadecimal value of the Plug-and-Play ID of the manufacturer
Product ID: hexadecimal value of the Plug-and-Play ID of the item
alternate names: other common names by which this particular remote is known
variations: links to slight variations of this particular remote
  • these refer to this particular brand and model of the remote
equivalent remotes: links to other brands of this particular remote
OEM: (Original Equipment Manufacturer) the company which makes this remote, and the other brands and variations of it
type: what the remote consists of
  • remote control is the transmitter plus the receiver
    remote receiver is just the receiver only
    remote transmitter is just the transmitter only
medium: how the remote communicates (IR or RF)
  • IR is Infrared, commonly called CIR (Consumer InfraRed), which is definitely not the same as IRDA
    RF is radio frequencies, which can be further classified as Bluetooth, 2.4GHz, or whatever, if it is known
interface: how the remote is connected to the computer (USB, serial port, LAN, or whatever)
universal receiver: does the receiver work with any transmitter
can blast: does the receiver also transmit to other devices (TV, HiFi, etc.)
can learn: does the receiver also record transmissions from other transmitters
plugin: which plugins will work with this remote
requirements: what other hardware is needed for this remote
  • each plugin may have additional requirements
    please refer to the plugins as well
WWW: website for the remote
  • this is not the EventGhost forum topic for the remote
    refer to the plugins for the EventGhost forum topics
notes: whatever else may prove to be useful
verified: have my assumptions been checked by someone who knows more about the remote than me
  • do not assume that everything is correct until it has been verified
If a remote does not work with EventGhost, then plugins and requirements are usually omitted.
Additionally, the notes will also serve as a reminder that the remote does not work with EventGhost.
HELP! Everyone needs to get involved in this topic.
Check the details of your remote.
I only have a 0022 using RP-0020.
We need to get everything verified.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:54 am
In order to impose some order on what could become a chaotic topic, we will use various kinds of reference codes.
remote codes:
Remotes that do, or do not, work with EventGhost will receive a 4 digit numeric remote code.
For example: 0001, 0002, 0003, etc.
ControlFreak will assign that number, because no one else can edit Part IV or Part V.
(next available remote code: 0058)
query codes:
If you have a query about an unknown remote, you should use a 4 letter alphabetic (upper case A to Z) query code.
For example: AAAA, AAAB, AAAC, etc.
Just look for the latest query code in the most recent posting, and increment it to the next letter.
Of course, responses and general comments do not have codes, but will usually refer to remote codes and query codes.
Images of a remote should be a maximum of 400 pixels wide and 300 pixels high, preferably with both the transmitter and the receiver.
Before you decide to make a query, please take the time to read all of the postings in this topic.
That is, look for an existing query code first.
Some example queries are given later.
plugin codes:
EventGhost has four different types of plugins: Remote Receiver, Program Control, External Equipment, Other
(the plugin types can simply be abbreviated as RP, PP, EP, OP)
We will use RP- and a four digit number to designate remote plugin reference codes.
For example: RP-0001, RP-0002, RP-0003, etc.
ControlFreak will assign that number, because no one else can edit Part VI.
(next available remote plugin code: RP-0042)
Last edited by ControlFreak on Sat Aug 16, 2014 10:38 am, edited 7 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:55 am
remotes:
0001 ASUS PSR-2000
0002 ATI Remote Wonder
0003 ATI Remote Wonder PLUS
0004 ATI Remote Wonder II
0005 auvisio VRC-1100
0008 generic VRC-1100
0009 AVerTV/Studio TV card remote
0010 Conceptronic CLLRCMCE
0011 Cyberlink Universal Remote Control
0014 Egon USB receiver
0015 ELV FS20 PCE
0016 Evation Irman
0017 Gyration Media Center Remote
0006 hama 52451
0018 Hauppauge PC TV remote
0019 Hewlett Packard TRC3
0020 Home Electronics Tira
0021 IgorPlug-USB
0022 iRF P-01RN
0023 iRF W-01RN
0024 Keene IR Anywhere
0025 Logitech UltraX Media Remote
0026 Marmitek PC Control
0027 Medion RF Remote Control
0029 Microsoft MCE Remote 2
0030 Microsoft Xbox remote control
0031 Niveus PC Remote Control
0032 NVIDIA Personal Cinema Remote
0007 ORtek VRC-1100
0033 Packard Bell RF MCE Remote Control OR32E
0034 PC Remote
0035 Pearl Q-Sonic Master Remote 6in1
0012 Sapphire TheatriX
0013 nameless Sapphire
0036 SnapStream Firefly
0037 Sony PS3 Bluetooth Remote 1
0038 Sony PS3 Bluetooth Remote 2
0039 Sony PS3 Blu-Link Remote
0040 Speed-Link SL-6399 Media Remote
0041 Streamzap PC Remote
0042 TechniSat USB IR Receiver
0043 TechnoTrend PC TV remote
0044 TechnoTrend USB IR Receiver
0045 Terratec USB Receiver
0046 Universal Infrared Receiver V1 (UIR)
0047 UIRT2
0048 USB-UIRT
0049 Y.A.R.D.
non-remote devices:
0050 keyboard
0051 mouse
0052 joysticks and gamepads
0053 Microsoft Sidewinder Game Voice
0057 Leap Motion Controller
tablet and smartphone devices:
0054 Android devices
0055 Apple iOS devices
0056 Windows Phone devices
non-catalogued devices:
learning remote controls (e.g. Logitech Harmony, Philips Pronto, etc.)
PDAs (e.g. iPAQ, etc.)
Last edited by ControlFreak on Fri Aug 15, 2014 12:01 pm, edited 7 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:56 am
0028 Microsoft MCE Remote 1
(and some others also)
Last edited by ControlFreak on Sun Jun 08, 2014 10:52 am, edited 7 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:57 am
Part VI : Plugins
Remote control plugins enable EventGhost to respond to the remote controls.
Plugins marked as (*) are not included with EventGhost (as of v0.4.1.r1640).
The non-included plugins must be downloaded and installed manually.
remote plugins:
RP-0001 ASUS PSR-2000
RP-0002 ATI Remote Wonder II (WinUSB)
RP-0003 auvisio VRC-1100 Ro
RP-0004 BT8x8 based remotes
RP-0005 Conceptronic CLLRCMCE
RP-0006 Cyberlink Universal Remote Control
RP-0007 Egon USB receiver (*)
RP-0008 ELV FS20 PCE
RP-0039 EventPhone Remote
RP-0009 Generic HID
RP-0010 Hauppauge IR
RP-0011 Home Electronics Tira
RP-0012 IgorPlug-USB
RP-0035 Joystick
RP-0013 Keene IR Anywhere
RP-0034 Keyboard
RP-0041 LeapMotionGhost (*)
RP-0014 LIRC Client
RP-0015 Logitech UltraX Media Remote
RP-0016 Microsoft MCE Remote
RP-0017 Microsoft MCE Remote - Vista/Win7
RP-0018 Microsoft MCE Remote - Vista and newer (*)
RP-0037 MouseEvent (*)
RP-0019 PC Remote Controller
RP-0020 PHX01RN
RP-0021 PlayStation 3 Bluetooth Remote
RP-0040 RemoteGhost (*)
RP-0036 Sidewinder Game Voice
RP-0022 Speed-Link SL-6399 Media Remote
RP-0023 Streamzap PC Remote
RP-0024 TechniSat USB IR Receiver
RP-0025 TechnoTrend IR Devices (BDA)
RP-0026 TechnoTrend USB IR Receiver
RP-0027 Terratec USB Receiver
RP-0038 terRemote (*)
RP-0028 UIR / Irman
RP-0029 UIRT2
RP-0030 USB-UIRT
RP-0031 X10 Remote
RP-0032 Xbox remote control
RP-0033 Y.A.R.D.
non-catalogued plugins:
..-.... Desktop Remote
..-.... Webserver
..-.... voice control (*)
Last edited by ControlFreak on Fri Aug 15, 2014 12:03 pm, edited 6 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 8:58 am
There are no universal methods of installing a remote control.
But here are some guidelines which may prove useful.
Unplug the receiver if it is already plugged in.
Close EventGhost.
Check the hardware requirements for the remote control in this topic.
Check the software requirements for the remote control in the Remote Control Plugins topic.
Some remote control plugins require WinUSB.
Check the forum topic for the particular remote control plugin for additional instructions as well.
Make sure all the requirements are met, and follow any suggested installation instructions.
If there are no recommended instructions, then proceed as follows:
Plug in the receiver.
If the Found New Harware Wizard starts up, then install the software automatically.
You might also want to install WinUSB manually now, if it is needed by the plugin.
Restart EventGhost.
Add the remote control plugin to the EventGhost Configuration tree.
A dialog will appear for installing the proper driver, click Yes.
Continue with all the remaining steps to install the driver.
Uncheck Log only assigned and activated events.
Press some buttons on the remote to see if any events show up in the EventGhost Log pane.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:00 am
If you already have the remote, then there are some things you can do that will help us all.
Do not try to get the remote working with EventGhost yet.
Close EventGhost.
Do not plug in the receiver yet, or unplug it if it is already plugged in.
Perform Procedure 01 and submit the results to this topic.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:01 am
Information about (IR) remote controls: http://www.remotecentral.com/
JP1 forum at hifi-remote: http://www.hifi-remote.com/forums/
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:03 am
remote code: 0001
works: yes
ASUS PSR-2000.png (139.39 KiB) Viewed 16674 times
Vendor ID: 147A
Product ID: E006
alternate names:
variations: different colours for the top row of buttons
equivalent remotes:
OEM:
type: remote control
medium: IR
interface: USB
universal receiver: no
can blast: no
can learn: no
plugin: RP-0001
requirements:
WWW:
notes:
do not confuse 0001 with nameless versions of it
do not confuse 0001 with AAAF, AAAG, or 0034
verified: no
Last edited by ControlFreak on Sun Aug 03, 2014 12:44 pm, edited 5 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:05 am
remote code: 0002
works: yes
name: ATI Remote Wonder
ATI Remote Wonder.png (56.46 KiB) Viewed 16440 times
Vendor ID: 0BC7 (?)
Product ID: 0006 (?)
alternate names:
variations:
equivalent remotes:
OEM:
medium: RF
interface: USB
can blast: no
can learn: no
plugin: RP-0031
requirements:
WWW:
notes:
verified: no
Last edited by ControlFreak on Sun Aug 03, 2014 12:44 pm, edited 3 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:07 am
remote code: 0003
works: yes
name: ATI Remote Wonder PLUS
ATI Remote Wonder PLUS.png (104.76 KiB) Viewed 16440 times
Vendor ID: 0BC7 (?)
alternate names:
variations:
equivalent remotes:
OEM:
medium: RF
interface: USB
can blast: no
can learn: no
plugin: RP-0031
requirements:
WWW:
notes:
verified: no
Last edited by ControlFreak on Sun Aug 03, 2014 12:45 pm, edited 4 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:10 am
remote code: 0004
works: yes
name: ATI Remote Wonder II
ATI Remote Wonder II.png (90.62 KiB) Viewed 16440 times
Vendor ID: 0471
Product ID: 0602
alternate names:
variations:
equivalent remotes:
OEM:
medium: RF
interface: USB
can blast: no
can learn: no
plugin: RP-0002
requirements:
WWW: http://ati.amd.com/products/remotewonder2/index.html
notes:
verified: no
Last edited by ControlFreak on Sun Aug 03, 2014 12:46 pm, edited 3 times in total.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sun Apr 20, 2014 9:12 am
remote code: 0005
works: yes
auvisio VRC-1100.png (117.39 KiB) Viewed 16440 times
Vendor ID: 05A4
Product ID: 9881
alternate names:
auvisio VRC-1100 Ro
variations:
equivalent remotes:
0006 hama 52451
0007 ORtek VRC-1100
OEM: ORtek (?)
medium: IR
interface: USB
can blast: no
can learn: no
plugin: RP-0003
requirements:
WWW:
notes:
verified: no
Last edited by ControlFreak on Sun Aug 03, 2014 12:47 pm, edited 3 times in total.
WharfRat
