I have an automation set up with The Renamer and Ember Scraper.
When a movie is downloaded, it's automatically moved to a folder where The Renamer will
rename it and then move it to my movie library, where Ember will scrape it.
I have used the following command line options for The Renamer:
-fetchmovie
For Ember Media Manager:
-newauto -all -nowindow
Both applications are set to "Minimized" in Window Option, yet whenever they start to process,
XBMC is minimized and I cannot bring it back to the front with my remote control, because
EventGhost will not process two makros at the same time.
I know this is not the most elegant version by far, so any pointers would be greatly appreciated.
Question 1: Is there any way to keep XBMC in the front, even while scraping is going on?
Question 2: Sometimes Ember / TheRenamer will go crazy and repeat scraping for many times. Is there anyway to make Ember wait 30 Seconds,
but still being use other makros during this time. From what I read "Wait 30 seconds" will halt all other makros as well.
Thanks a lot and have a great holiday season!
