XmlIdLink not defined
rdgerken
Post by rdgerken » Tue Dec 11, 2012 1:24 am
Why is it when I "Copy As Python" a Jump or an Enable/Disable statement into a Python Command, it fails?
eg.plugins.EventGhost.EnableItem(XmlIdLink(1426))
19:36:49 Traceback (most recent call last):
19:36:50 Python script "35", line 2, in <module>
19:36:50 eg.plugins.EventGhost.EnableItem(XmlIdLink(1426))
19:36:50 NameError: name 'XmlIdLink' is not defined
Thank you for any help you can provide!
semihselcuk
Re: XmlIdLink not defined
Post by semihselcuk » Thu Mar 28, 2013 6:44 pm
Did you find any solution ? Because i have same problem too ..
rdgerken
Post by rdgerken » Sat Oct 19, 2013 11:49 pm
Anyone have a solution on this?
Just checking back.
abuttino
Post by abuttino » Wed Oct 23, 2013 3:25 pm
This isn't possible as a Python command
rdgerken
Post by rdgerken » Sat Oct 26, 2013 8:26 pm
Are you sure? Seems kind of silly that there wouldn't be a way for EG to control itself programmatically...
abuttino
Post by abuttino » Tue Oct 29, 2013 4:21 am
Absolutely positive.. I've done the research on it... You can google the same results I did..
blackwind
Post by blackwind » Fri Oct 02, 2015 6:01 am
Has anyone come up with a solution to this yet?
/bw
casik
Post by casik » Wed Feb 24, 2016 1:33 pm
You can insert macro with two actions:
first add eventghost action - Gets item enable state (True when enabled)
and second action immediately after first action - python script, where will be the first line operation handling with variable eg.result (eg.itemstate1 = eg.result)
If you want check more items state, you should repeat in macro this two actions for wanted items and than at the end add last python script action with handling of eg.itemstate1-X.
Cypher16e
Post by Cypher16e » Fri Aug 09, 2019 4:38 pm
Can you please expand, your answer may work but I'm having difficulty wrapping my mind around where you're going with this. Mind sharing an example of your scenario?
