Everytime I launch DVBVierwer, EventGhost launches it another one after 5 seconds.
I've find out that if It's due "Waiting time after detection of the window" value.
Any workaround for this?
Eventghost starts DvbViewer two times
Re: Eventghost starts DvbViewer two times
If yes, this will be the workaround.
Regards
Prinz
What do you mean? Is this problem gone if the wait time is set to a higher value (e.g. 10s)?pep wrote:I've find out that if It's due "Waiting time after detection of the window" value
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
CPU: Intel E5200
OS: WinXP SP3
I have this problem too.
Where to change "Waiting time after detection of the window"?
Two times ? I haven't this problem personnally.
I have configured Eventghost so it can open 2 DvbViewer instances (need to install dvbviewer 2 times) because i have 2 monitors now.
Maybe i can share the .xml ?
Download here: http://www.sendspace.com/file/kf7f81
