The EventGhost project is looking for translators!
somainit
Re: The EventGhost project is looking for translators!
Post by somainit » Sun Feb 15, 2009 12:35 pm
Bitmonster wrote:And what are these keys supposed to do in EventGhost? I thought the IME would handle them.
On second thought, you can say that again.
I got the wrong idea...
PedroV9
Post by PedroV9 » Mon Jan 18, 2010 4:30 pm
Translation to Portuguese-Brazil
version: 0.3.7.r1366
January 13, 2010
PS: The mouse is fully translated, EventGhost, System, Windows was partially translated.
Hugs!
pt_PT.py
(10.7 KiB) Downloaded 848 times
Re:
Post by Bitmonster » Mon Jan 18, 2010 7:49 pm
PedroV9 wrote:Translation to Portuguese-Brazil
January 13, 2010
Hugs!
Thanks for your contribution.
Added the language file as "Portuguese (Brazilian)" to the trunk. It will be included in the next version.
PedroV9
Re: Re:
Post by PedroV9 » Tue Jan 19, 2010 1:10 am
The translation has been completely revised, and some typo found if you can download again ...
PS: When the next version will be available? :wink:
Re: Re:
Post by Bitmonster » Wed Jan 20, 2010 1:52 pm
PedroV9 wrote:PS: When the next version will be available? :wink:
Now.
batto
Post by batto » Fri Sep 24, 2010 7:43 pm
The "-translate" commandline option not work on version 0.3.7.r1462. What can i do to translate to other language?
Post by Pako » Sun Oct 03, 2010 5:13 pm
Your problem may be caused by some plugin (maybe foobar2000).
I recommend to try the following:
All plugins (except EventGhost, System, Window and Mouse) to move from the folder ...\EventGhost\plugins\ to some other place.
Then try to run the EG with the argument -translate.
If it succeeds, you can roll back individual plugins in place.
So find out which plugin is causing the problem.
batto
Post by batto » Wed Oct 27, 2010 5:24 pm
Pako wrote:Your problem may be caused by some plugin (maybe foobar2000).
Thank you very much, Pako. Problem solved!
Here my translation to Vietnamese (Vietnam) in version 0.3.7.r1462 (28-10-2010).
All plugins like Eventghost, system, window, mouse, keyboard... are fully translated, others was partially translated.
Vietnam flag
vi_VI.py
Vietnamese language file
(37.52 KiB) Downloaded 686 times
Foune
Post by Foune » Wed Jul 27, 2011 2:49 pm
Here is an updated version of French language.
Program Version: 0.4.1.r1534
fr_FR.py
French language update
(25.16 KiB) Downloaded 667 times
Osni
Post by Osni » Mon Jan 16, 2012 8:32 pm
Hi, I'm translating to PT-BR and I have a problem...
Everytime I open EventGhost with the attached translation, it closes without displaying any error message.
I managed to open it after excluding the Serial plugin entries, but after translating it again and a few more plugins, I can't open EventGhost again :(
Could you check what's the problem, so that I continue translating the other plugins?
BTW, i'm runnning EventGhost 0.4.1.r1544.
pt_BR.py
(79.66 KiB) Downloaded 631 times
Post by Pako » Sun Jan 22, 2012 8:07 am
Osni wrote:Everytime I open EventGhost with the attached translation, it closes without displaying any error message.
One advice:
Use the -debug command line argument. Then you usually see where the problem is.
In your case the problem was in the Serial Port plugin.
pt_BR.py
(79.87 KiB) Downloaded 658 times
Osni
Post by Osni » Mon Jan 23, 2012 7:10 pm
Pako wrote:One advice:
Thanks Pako, I knew the problem was in Plugin.Serial.Write.Description, but I translated it over 4 times and those character codes always messed up the translation.
I'll submit the file again once I finish a few more plugins.
EDIT:
Damn, error again at the same line, when I saved after a few VLC translations :x.
I'll just delete these codes or leave the description untranslated :roll: .
BuzzUKO
Post by BuzzUKO » Tue Aug 04, 2015 8:31 am
I'm interested in translating EventGhost to Hebrew.
The thing is that Hebrew is an RTL language and not LTR.
Is that possible to work it around while I start translating?
YamNahar
Post by YamNahar » Mon Sep 28, 2015 1:13 am
I am currently working for the Romanian translation of EventGhost.
I will post it when it would be finished.
Filandre
Post by Filandre » Sun Jan 24, 2016 10:08 pm
Added some translations to french.
fr_FR.py
(26.67 KiB) Downloaded 351 times
