I have a virtual dimmer in Smartthings and use WebCore to set a level every half hour (level changes throughout the day)
I use Eventghost to play a wav file for every level
Eventghost is installed on Win 10
When I check the Eventghost loges I see all the virtual dimmer level changes throughout the day
The problem is it does not play the wav file ( it used to) I dont think I have made any changes
If I open my Android app (Smartthings) and manually adjust the virtual dimmer then Eventghost will play the wav file every time
Not sure what's going on I've attached the log
I have a webcore Eventghost setting to play the weather every half hour and that works no problem
Smartthings - Webcore - Eventghost
