Help with numbers in payload
therealbiglou
Post by therealbiglou » Fri Jun 05, 2020 2:01 am
I'm trying to extract the number from a payload and use it in an if statement:
watts = eg.event.payload
if watts > 1:
    eg.TriggerEvent("Great Room TV Power Usage On")
However, no matter what the value in the payload--even less than 1--it triggers the event. If I print the payload, I see something like:
['83.69']
Am I doing something wrong? Should this payload be converted to a number somehow to compare in the script?
Re: Help with numbers in payload
Post by kgschlosser » Fri Jun 05, 2020 6:05 am
as a matter of fact you are..
the payload is a list. you can tell this because of the []'s.
Think of a list of grocery items. when you make a list you put one item on each line. well the same thing goes with these lists. the only difference is on a grocery list you start off with line 1. in a python list you start off with line 0.
so how we tell python what item we want is by adding [line number] to the end of the variable name.
eg.event.payload[0]
Now there is also one other thing. do you see the single quotes surrounding the number in the list?? well that means it is not actually a number it is a string of text. Now technically even if it was a "number" it's really not a number it is a float a float has a decimal point in it. Python as given us an easy way to convert the string into an actual float.
watts = eg.event.payload[0]
watts = float(watts)
therealbiglou
Post by therealbiglou » Sun Jun 07, 2020 9:00 pm
Brilliant, that worked perfectly! Thanks!
Post by kgschlosser » Sun Jun 07, 2020 9:54 pm
no worries m8. That's why I am here. If you are wanting to further your python skills I am more then happy to help. So ask as many questions as you like.
