Destroy image task doesnt work after some time
dexaconsult
Post by dexaconsult » Wed Sep 18, 2019 1:12 pm
Hello EG community,
I have a rather simple problem. I am using a motion detector to trigger an event by USB. That works good. After 15min of no movement, I make a black fullscreen image with EG, that works so far.
After event.movement is triggert, I use the "delete image" action to destroy the image. What also works when I test it manually.
BUT: After some hours, suddently the event doesnt destroy the image anymore! The events are correct...
Does anybody has an idea??
Ty and regards
Re: Destroy image task doesnt work after some time
Post by kgschlosser » Wed Oct 23, 2019 6:40 pm
need to see the code to know what is going on. I am assuming you are doing this through a Python Script.
