Cyberlink Universal & Windows 10
jimmyjazz
Post by jimmyjazz » Tue Sep 03, 2019 2:17 pm
Hi there,
I recently upgraded my Win7 Media PC to Win10 and now find that my old Cyberlink Universal remote doesn't function fully.
Many of the standard media buttons - play/pause, select, volume - work, but most of the other buttons don't register at all. When I attempt to load my old config profile into EG I am prompted to download the appropriate Cyberlink plugin which then fails.
I can't find any other more appropriate Win10 driver anywhere and nothing in the forums - any help would be much appreciated.
Win10 - version 1803
EventGhost - version 0.4.1.r1722
Log details:
Autostart
Plugin: X10: Generic X10
Error starting plugin: X10 Remote
No X10 receiver found!
Plugin: Zoom Player
Plugin: Winamp
Plugin: Task Create/Switch Events
Enable exclusive: Keyboard Emulation
Plugin: CyberLink Universal Remote Control
Error starting plugin: CyberLink Universal Remote Control
Driver not found!
Winamp.Status.Changed.Off
Main.OnInit
Task.Activated.EventGhost
Task.NewWindow.EventGhost
Task.Deactivated.EventGhost
Exception in thread Thread-10:
File "C:\Program Files (x86)\EventGhost\eg\Classes\TransferDialog.py", line 261, in ThreadRun
todo = self.CreateActions()
File "C:\Program Files (x86)\EventGhost\eg\Classes\TransferDialog.py", line 249, in CreateActions
size = self.HttpGetSize(src)
File "C:\Program Files (x86)\EventGhost\eg\Classes\TransferDialog.py", line 307, in HttpGetSize
testFile = urllib2.urlopen(path)
File "urllib2.pyc", line 126, in urlopen
File "urllib2.pyc", line 397, in open
Task.ClosedWindow.EventGhost
File "urllib2.pyc", line 510, in http_response
File "urllib2.pyc", line 435, in error
File "urllib2.pyc", line 369, in _call_chain
File "urllib2.pyc", line 518, in http_error_default
HTTPError: HTTP Error 404: Not Found
Re: Cyberlink Universal & Windows 10
Post by kgschlosser » Thu Sep 05, 2019 2:43 pm
upgrade EventGhost to 0.5RC6 located HERE
then follow the directions HERE
jimmyjazz
Post by jimmyjazz » Fri Sep 06, 2019 7:17 pm
Genius, thanks so much!
So to confirm, this is what resolved the issue
1, Restarting Win10 with driver verification disabled
2, Installed WinUSB Addon
3, Copied the drivers folder it creates to %programdata%\Evenghost
4, Successfully installed the plugin that had been failing to this point
Kudos to kgschlosser!!
Post by kgschlosser » Sat Sep 07, 2019 2:16 am
i really would like to see you upgrade your EventGhost to RC6. Microsoft made some changes to the notifications system in Windows starting with 10. EG 0.4 is not written in a manner to handle these changes and you can end up with "phantom" like bugs. and they can happen all over the place. Inside of EG and also outside of EG.
It is up to you but if you happen to experience strange errors and behavior from any applications and also from EG. the cause could be EG.
