emulate keystroke for fix press
gabigabigabi
Post by gabigabigabi » Tue Aug 27, 2019 7:52 pm
Hi ,
I want to emulate a keystroke when presing another key
i add a given-- event item// lets say when i press letter -- f
i add emulate keystrokes and write there letter ==h
when i fix press f on a microsoftword document it will emulate the stroke perfectly but just one time then it will continue with the actual key
like this
hfffffffffffffffffff
IS there any way i can emulate keystrokes for fix pressing?
Thanks for reading
Re: emulate keystroke for fix press
Post by kgschlosser » Fri Aug 30, 2019 5:22 am
i believe that the key events are enduring events. You should be able to place a repeat action at the bottom of the macro to repeat it until you release the key.
