Command line events
ralphberner
Command line events
Post by ralphberner » Sun Aug 25, 2019 6:30 am
I triggert events by command lines for former versions of EventGhost (4.x) sucessfully.
Example:
"C:\Program Files (x86)\EventGhost\eventghost.exe" -e Keyboard.LShift+F2
for a macro called "Volume Up" wich is triggered by the event "Keyboard.LShift+F2".
After i switched to 0.5.0-rc6 this doesn't work anymore.
Has the command line structure altered from version 4 to 5?
I don't understand the help well because there are no examples.
Any ideas about this?
Re: Command line events
Post by jonib » Thu Aug 29, 2019 2:55 pm
I get "Main.Keyboard.LShift+F2" event, I guess the "Main." part is different from before? Don't know if it's possible to make non "Main." events from the commandline in the current EventGhost version.
ralphberner
Post by ralphberner » Thu Aug 29, 2019 4:57 pm
Thanks for the hint. But i couldn't get it run.
Post by jonib » Thu Aug 29, 2019 9:46 pm
So what is not working? you are not getting an event? or the wrong event? the event needs to match the event in the macro.
ralphberner
Post by ralphberner » Sat Aug 31, 2019 6:51 am
Here are more details:
I trigger this command by a cmd file:
If i quit EventGhost and trigger it, EventGhost just starts. That proves the path to the exe is correct.
If Event ghost is running already and i trigger the command, i get this:
https://pasteboard.co/IvcAF9R.bmp
EvnetGhost Version 0.5.0.-rc6 (2018-12-24)
Windows 10 Pro X64
Post by jonib » Sat Aug 31, 2019 3:02 pm
Looks like you need to add the "Main.Keyboard.LShift+F2" event to the macro for it to work.
I created an issue in the Eventghost issue tracker as I don't know if this is an intended breaking behavior compared to the old Eventghost 0.4.
Post by jonib » Sat Aug 31, 2019 4:15 pm
Response to the issue:
DanEdens wrote:You can get around this by using the wildcards * and ? in your trigger.
For example:
*.LShift+f2
ralphberner
Post by ralphberner » Thu Sep 05, 2019 2:56 pm
OK, i renamed the event wthin the macro from
Keyboard.LShift+F2
to
After that it works again with the old command
Thanks for the help. :D
Post by jonib » Thu Sep 05, 2019 3:51 pm
Good.
Looks like it is a bug in the new versions and will probably be fixed later, but for now that seems to be the way to fix it.
Post by kgschlosser » Sun Sep 08, 2019 7:39 am
if you want to you can replace program files (x86)\eventghost\eg\Cli.py with the file that is attached. this is get rid of the "Main" prefix only if you are triggering an event that has a "." in it. otherwise it will add the "Main" to it.
Cli.py
(6.24 KiB) Downloaded 75 times
Post by jonib » Sun Sep 08, 2019 7:26 pm
So trying the "Cli.py" on EG rc6 I got this error and EventGhost didn't' start:
  File "EventGhost.pyw", line 53, in <module>
  File "D:\Program\Util\EventGhost\eg\__init__.py", line 31, in <module>
    import Cli
  File "D:\Program\Util\EventGhost\eg\Cli.py", line 30, in <module>
    from NamedPipe import is_eg_running
ImportError: No module named NamedPipe
Post by kgschlosser » Mon Sep 09, 2019 12:27 am
That would figure I grabbed the wrong Cli.py file to edit.
