Any way to print files with EG?
I'm hoping to automate printing of PDF files by using directory watcher. However, I could not find a way to actually get the files to print when they are found. Is there a way to get this set up? I assume simple keyboard shortcuts could be used, but that seems a bit messy. Are there plugins to directly print?
Re: Any way to print files with EG?
Sorry for the slow response, I use the following-
http://www.columbia.edu/~em36/pdftoprinter.html
Works well for me. I use it with the Alexa plugin to print shopping lists.... Every little helps
- kgschlosser
you can do it directly from python I believe this code should work.
This will only print to your default printer tho. If you need to print to something other then your default printer or you need to make settings changes for the print job it is going to be a lot more involved.
import os
os.startfile(r'C:\path\to\file_to_print.txt', 'print')
