Please help with script it has stopped working
Re: Please help with script it has stopped working
Post by kgschlosser » Mon Sep 30, 2019 7:02 am
and I didn't even think about the volume slider getting hidden when in full screen. that's my goof but at least you figured it out and you were able to fix the thing.
I am not sure 100% what has change between the windows 10 builds that would have caused this to break the way it did. But I am not going to question it. I think you have a better script that doesn't rely on screen resolutions to check full screen state. and that is actually important. Because a window can be sized to match the screen resolution and technically not be in a "full screen" mode. I have never seen an application that offers a full screen mode have any borders edges or frames. Thus far it has been reliable. Now. if an application does a 100% custom drawn GUI and they even draw the frame, border or edge themselves this would not work. I have not seen an application do that, but it doesn't mean that there isn't one out there. Even custom drawn GUI's will still leave the frame or the edge being handled by windows. Because this is something that can be adjusted by the user in terms of size and color.and it is a way to have a defined boundary between applications and it will be something that user knows to look for.
molitar
Post by molitar » Mon Sep 30, 2019 8:47 pm
About as well as can be expected with Windows 10. It will stop for no apparent reason and stop responding at all since update to build 1903. I end up having to use a program like processmanager or that to terminate the app so that it terminates threads. Be nice if we see an EventGhost update the last beta was quite a while ago.
Post by kgschlosser » Tue Oct 01, 2019 10:56 pm
ok so you are having EventGhost freeze up on you?
If that si the case then most of the time this is being caused by a plugin. list off your installed plugins and versions to me. I may have you remove one ata time and see if the issue goes away...
Another way to check is to run EG from the command line with the -debug parameter.. open EventGhost and let it run for 1/2 a day. and then close it gracefully. in your %appdata%/eventghost folder there is going to be log.txt you will need to send that to me.
You can also run EG with the -debug parameter until it freezes. then terminate the app and send me the log file for that as well. send them to me in a PM please. and also zip them up.
we should be able to track down where the problem is coming from.
molitar
Post by molitar » Wed Oct 02, 2019 3:42 am
Task Monitor
Media Player Classic 1.7
Keyboard
ffdshow <disabled>
Taskbar 1.0.0
On Screen Explorer 0.2.14
Deal Extreme USB PC Remote 1.1.1
I'll run it with the debug log for a bit so when it happens again I can get you the log.
BTW after enabling the debug an error showing up when it's started now.
DEBUG: 0 ActionThread: StartLoad(cls=<class 'eg.Classes.TreeLink.TreeLink'>)
File "C:\Program Files (x86)\EventGhost\eg\Classes\MainFrame\__init__.py", line 814, in UpdateRatio
self.ratio = float(t_val) / float(l_val)
ZeroDivisionError: float division by zero
DEBUG: 1 MainThread: Document.HideFrame()
Post by kgschlosser » Fri Oct 11, 2019 9:57 am
ok if you go to %appdata%/eventghost there is a file in there config.py. edit that file. locate the line that has "propResize = " and tell me what the value is. I also want to know what the value is for "ratio = " under the MainFrame class
Post by kgschlosser » Fri Oct 11, 2019 9:58 am
also I would still like to see that log file please :D
molitar
Post by molitar » Fri Oct 11, 2019 7:20 pm
Ok I did a nice clean log file. Did a few things like volume controls and OSD in both max screen and not maximized. I have had to restart EG many many times probably due to the alpha bug as all OSD will stop displaying until I restart it and eventually I'll have to log out to get it to display OSD again. This is OSD for everything including the volume control.
The only things I changed in the OSD was green was a bit hard to see with the particular show I was watching so I changed color and it was a it off screen due to scaling at bottom so I made text show centered. Other then that I have not really touched the code.
I tried to attach file but kept getting error message server was unable to parse. Tried as the txt and zip and it failed so I had to put in code box below.
15:22:15: DEBUG: 0 MainThread: ----------------------------------------
15:22:15: DEBUG: 0 MainThread: EventGhost started
15:22:15: DEBUG: 0 MainThread: EventGhost Version: 0.5.0-rc6
15:22:15: DEBUG: 0 MainThread: Machine type: AMD64
15:22:15: DEBUG: 0 MainThread: Processor: AMD64 Family 23 Model 8 Stepping 2, AuthenticAMD
15:22:15: DEBUG: 0 MainThread: Architecture: ('32bit', 'WindowsPE')
15:22:15: DEBUG: 0 MainThread: Python:  2.7.12 CPython ('default', 'Oct 31 2016 18:42:08') [MSC v.1500 32 bit (Intel)]
15:22:15: DEBUG: 0 MainThread: PluginManager.ScanAllPlugins :0.16729290000000002
15:22:15: DEBUG: 0 MainThread: SendKeysParser.__init__()
15:22:15: DEBUG: 0 MainMessageReceiver: MainMessageReceiver.__MainLoop()
15:22:15: DEBUG: 0 MainMessageReceiver: MainMessageReceiver.Setup()
15:22:15: DEBUG: 0 MainThread: Document.ShowFrame()
15:22:16: DEBUG: 0 MainThread: Log.GetData()
15:22:16: DEBUG: 0 MainThread: MainFrame.OnIconize(event=<wx.IconizeEvent>)
15:22:16: DEBUG: 0 MainThread: MainFrame.Iconize(flag=True)
15:22:16: DEBUG: 0 MainThread: Document.HideFrame()
15:22:16: DEBUG: 0 MainThread: Document.HideFrame => None
15:22:16: DEBUG: 0 MainThread: Document.ShowFrame => None
15:22:16: DEBUG: 0 ActionThread: ActionThread.__MainLoop()
15:22:16: DEBUG: 0 EventThread: EventThread.__MainLoop()
15:22:16: DEBUG: 0 Socket Server: starting...
15:22:16: DEBUG: 0 Socket Server: started.
15:22:18: DEBUG: 0 EventThread: EventThread.StartSession(filename=u'c:\\program files (x86)\\eventghost\\default - mpc.egtree')
15:22:18: DEBUG: 0 ActionThread: ActionThread.StartSession(filename=u'c:\\program files (x86)\\eventghost\\default - mpc.egtree')
15:22:18: DEBUG: 0 MouseThread: MouseThread.run()
15:22:18: DEBUG: 0 ActionThread: Document.Load(filePath=u'c:\\program files (x86)\\eventghost\\default - mpc.egtree')
15:22:18: DEBUG: 1 MainThread: OSDFrame.__init__(parent=None)
15:22:18: DEBUG: 0 ActionThread: StartLoad(cls=<class 'eg.Classes.TreeLink.TreeLink'>)
15:22:18: DEBUG: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=2033898, uMsg=536L, wParam=32787L, lParam=198130296)
15:22:18: DEBUG: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=2033898, uMsg=536L, wParam=32787L, lParam=198130360)
15:22:18: DEBUG: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=2033898, uMsg=536L, wParam=32787L, lParam=198131768)
15:22:18: DEBUG: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=2033898, uMsg=536L, wParam=32787L, lParam=198043856)
15:22:18: DEBUG: 0 Thread-3: SessionChangeNotifier.Register()
15:22:18: DEBUG: 0 ActionThread: Document.SetExpandState(expanded=set([0, 2, 3]))
15:22:18: DEBUG: 0 ActionThread: XML loaded in 0.036948 seconds.
15:22:18: DEBUG: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
15:22:18: DEBUG: 0 ActionThread: DXusbPCR.__start__(ignoreNumLock=True)
15:22:18: DEBUG: 0 ActionThread: ActionThread.StartSession => None
15:22:18: DEBUG: 1 MainThread: Document.HideFrame()
15:22:18: DEBUG: 1 MainThread: MainFrame.Destroy()
15:22:18: DEBUG: 1 MainThread: LogCtrl.Destroy()
15:22:18: DEBUG: 1 MainThread: TreeCtrl.Destroy()
15:22:18: DEBUG: 1 MainThread: StatusBar.Destroy()
15:22:18: DEBUG: 1 MainThread: StatusBar.__del__()
15:22:18: DEBUG: 1 MainThread: MainFrame.Destroy => True
15:22:18: DEBUG: 1 MainThread: Document.HideFrame => None
15:22:18: DEBUG: 1 MainThread: LogCtrl.__del__()
15:22:21: DEBUG: 1 MainThread: Document.ShowFrame()
15:22:21: DEBUG: 1 MainThread: Log.GetData()
15:22:21: DEBUG: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
15:22:21: DEBUG: 1 MainThread: Document.ShowFrame => None
15:22:30: DEBUG: 1 MainThread: MainFrame.OnClose(dummyEvent=<wx.CloseEvent>)
15:22:30: DEBUG: 1 MainThread: MainFrame.Iconize(flag=True)
15:22:30: DEBUG: 1 MainThread: Document.HideFrame()
15:22:30: DEBUG: 1 MainThread: MainFrame.Destroy()
15:22:30: DEBUG: 1 MainThread: LogCtrl.Destroy()
15:22:30: DEBUG: 1 MainThread: TreeCtrl.Destroy()
15:22:30: DEBUG: 1 MainThread: StatusBar.Destroy()
15:22:30: DEBUG: 1 MainThread: StatusBar.__del__()
15:22:30: DEBUG: 1 MainThread: MainFrame.Destroy => True
15:22:30: DEBUG: 1 MainThread: Document.HideFrame => None
15:22:30: DEBUG: 1 MainThread: LogCtrl.__del__()
15:22:30: DEBUG: 1 MainThread: MainFrame.__del__()
15:23:13: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='                                     Assassins Pride - 01 [HorribleSubs]\n \n[....................................................................................................] - 0.14%\n                                     Elapsed: 00:00:02 / Total: 00:23:50', fontInfo=u'0;-030;0;0;0;700;255;0;0;0;3;2;1;34;Consolas', textColour=(0, 255, 255), outlineColour=(0, 0, 0), alignment=4, offset=(0, 0), displayNumber=2, timeout=5.550000000000001, event=2332, skin=None)
15:23:14: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:20: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:22: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Mute Off', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2420, skin=u'Default')
15:23:22: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:23: DEBUG: 0 Thread-5: OSDFrame.OnTimeout()
15:23:24: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 44%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2356, skin=u'Default')
15:23:24: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:25: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 46%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2460, skin=u'Default')
15:23:26: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 44%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2364, skin=u'Default')
15:23:26: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 42%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=1964, skin=u'Default')
15:23:27: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 40%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2520, skin=u'Default')
15:23:27: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 42%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2304, skin=u'Default')
15:23:27: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 44%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2060, skin=u'Default')
15:23:28: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 46%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2300, skin=u'Default')
15:23:28: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 48%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2528, skin=u'Default')
15:23:28: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 50%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2536, skin=u'Default')
15:23:28: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 52%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=1616, skin=u'Default')
15:23:28: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 54%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2548, skin=u'Default')
15:23:28: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 56%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2552, skin=u'Default')
15:23:29: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 58%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2560, skin=u'Default')
15:23:29: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 60%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2516, skin=u'Default')
15:23:31: DEBUG: 1 MainThread: Document.ShowFrame()
15:23:32: DEBUG: 1 MainThread: Log.GetData()
15:23:32: DEBUG: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
15:23:32: DEBUG: 1 MainThread: Document.ShowFrame => None
15:23:32: DEBUG: 0 Thread-21: OSDFrame.OnTimeout()
15:23:34: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 6%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2052, skin=u'Default')
15:23:34: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:35: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 62%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2404, skin=u'Default')
15:23:35: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:36: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 64%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2544, skin=u'Default')
15:23:37: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 66%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2352, skin=u'Default')
15:23:37: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 68%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2288, skin=u'Default')
15:23:37: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 70%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2340, skin=u'Default')
15:23:37: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 72%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2360, skin=u'Default')
15:23:38: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 74%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2612, skin=u'Default')
15:23:38: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 76%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2592, skin=u'Default')
15:23:38: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 78%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2608, skin=u'Default')
15:23:38: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 80%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=1168, skin=u'Default')
15:23:38: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 82%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2628, skin=u'Default')
15:23:38: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 84%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2616, skin=u'Default')
15:23:39: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 86%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2624, skin=u'Default')
15:23:39: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 88%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2656, skin=u'Default')
15:23:39: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 90%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=2104, skin=u'Default')
15:23:42: DEBUG: 0 Thread-37: OSDFrame.OnTimeout()
15:23:43: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 92%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2652, skin=u'Default')
15:23:44: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:45: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 8%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2672, skin=u'Default')
15:23:45: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:45: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 10%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2056, skin=u'Default')
15:23:45: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 12%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2660, skin=u'Default')
15:23:46: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 14%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2596, skin=u'Default')
15:23:47: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 16%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2644, skin=u'Default')
15:23:48: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 90%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2664, skin=u'Default')
15:23:48: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 88%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2668, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 86%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2648, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 84%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2936, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 82%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2952, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 80%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2984, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 78%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2968, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 76%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2964, skin=u'Default')
15:23:49: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 74%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3012, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 72%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2928, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 70%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2972, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 68%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2944, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 66%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2956, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 64%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3036, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 62%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3020, skin=u'Default')
15:23:50: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 60%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3064, skin=u'Default')
15:23:51: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 58%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3024, skin=u'Default')
15:23:51: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 56%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2992, skin=u'Default')
15:23:51: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 54%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2620, skin=u'Default')
15:23:51: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 52%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2960, skin=u'Default')
15:23:51: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 50%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3040, skin=u'Default')
15:23:51: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 48%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2924, skin=u'Default')
15:23:52: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 46%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2920, skin=u'Default')
15:23:52: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 44%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2756, skin=u'Default')
15:23:52: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 46%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2636, skin=u'Default')
15:23:52: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 48%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2852, skin=u'Default')
15:23:53: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 50%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3060, skin=u'Default')
15:23:53: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 52%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2912, skin=u'Default')
15:23:54: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='                                     Assassins Pride - 01 [HorribleSubs]\n \n[///.................................................................................................] - 2.94%\n                                     Elapsed: 00:00:42 / Total: 00:23:50', fontInfo=u'0;-030;0;0;0;700;255;0;0;0;3;2;1;34;Consolas', textColour=(0, 255, 255), outlineColour=(0, 0, 0), alignment=4, offset=(0, 0), displayNumber=2, timeout=5.550000000000001, event=3048, skin=None)
15:23:54: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:58: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 18%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3032, skin=u'Default')
15:23:58: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:23:59: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 16%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=2988, skin=u'Default')
15:24:00: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 18%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3068, skin=u'Default')
15:24:00: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 20%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3116, skin=u'Default')
15:24:02: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 54%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3016, skin=u'Default')
15:24:03: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 56%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3112, skin=u'Default')
15:24:04: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 54%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2932, skin=u'Default')
15:24:05: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 52%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3052, skin=u'Default')
15:24:05: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 50%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2320, skin=u'Default')
15:24:06: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 48%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3248, skin=u'Default')
15:24:06: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 46%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2916, skin=u'Default')
15:24:07: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 44%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3260, skin=u'Default')
15:24:07: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 42%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3288, skin=u'Default')
15:24:08: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 22%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3328, skin=u'Default')
15:24:08: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:24:08: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 24%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3388, skin=u'Default')
15:24:08: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 26%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3404, skin=u'Default')
15:24:09: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 28%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3512, skin=u'Default')
15:24:09: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 30%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3528, skin=u'Default')
15:24:09: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 32%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3332, skin=u'Default')
15:24:09: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 34%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3624, skin=u'Default')
15:24:09: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 36%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3124, skin=u'Default')
15:24:10: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 38%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3384, skin=u'Default')
15:24:10: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText=u'Master Volume 40%', fontInfo=u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=6, offset=(0, 60), displayNumber=0, timeout=3.0, event=3628, skin=u'Default')
15:24:11: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 40%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3616, skin=u'Default')
15:24:11: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 38%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3276, skin=u'Default')
15:24:11: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 36%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3392, skin=u'Default')
15:24:11: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 34%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3740, skin=u'Default')
15:24:12: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 32%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3736, skin=u'Default')
15:24:12: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 30%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3508, skin=u'Default')
15:24:12: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 28%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3824, skin=u'Default')
15:24:12: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 26%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3832, skin=u'Default')
15:24:12: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 24%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3844, skin=u'Default')
15:24:13: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 22%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3864, skin=u'Default')
15:24:13: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 20%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3892, skin=u'Default')
15:24:13: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 18%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3908, skin=u'Default')
15:24:13: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 16%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=2940, skin=u'Default')
15:24:13: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 14%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3872, skin=u'Default')
15:24:15: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 16%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3848, skin=u'Default')
15:24:15: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 18%', fontInfo=u'0;-64;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1000), displayNumber=2, timeout=3.0, event=3868, skin=u'Default')
15:24:16: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='                                     Assassins Pride - 01 [HorribleSubs]\n \n[////................................................................................................] - 4.48%\n                                     Elapsed: 00:01:04 / Total: 00:23:50', fontInfo=u'0;-030;0;0;0;700;255;0;0;0;3;2;1;34;Consolas', textColour=(0, 255, 255), outlineColour=(0, 0, 0), alignment=4, offset=(0, 0), displayNumber=2, timeout=5.550000000000001, event=3340, skin=None)
15:24:16: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:24:22: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:24:23: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='                                     Assassins Pride - 01 [HorribleSubs]\n \n[/////...............................................................................................] - 4.97%\n                                     Elapsed: 00:01:11 / Total: 00:23:50', fontInfo=u'0;-60;0;0;0;700;255;0;0;0;3;2;1;34;Consolas', textColour=(0, 255, 255), outlineColour=(0, 0, 0), alignment=4, offset=(0, 0), displayNumber=1, timeout=5.550000000000001, event=3860, skin=None)
15:24:23: DEBUG: 0 Thread-112: OSDFrame.OnTimeout()
15:24:26: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 20%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=5.550000000000001, event=3928, skin=u'Default')
15:24:26: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:24:29: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 22%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=3904, skin=u'Default')
15:24:29: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 20%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=3504, skin=u'Default')
15:24:31: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 22%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=3756, skin=u'Default')
15:24:33: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='Volume: 20%', fontInfo=u'0;-128;0;0;0;700;0;0;0;238;3;2;1;66;Arial', textColour=(255, 255, 255), outlineColour=(0, 0, 0), alignment=5, offset=(0, 1800), displayNumber=1, timeout=3.0, event=3296, skin=u'Default')
15:24:36: DEBUG: 0 Thread-118: OSDFrame.OnTimeout()
15:24:36: DEBUG: 1 MainThread: OSDFrame.ShowOSD(osdText='                                     Assassins Pride - 01 [HorribleSubs]\n \n[//////..............................................................................................] - 5.87%\n                                     Elapsed: 00:01:24 / Total: 00:23:50', fontInfo=u'0;-60;0;0;0;700;255;0;0;0;3;2;1;34;Consolas', textColour=(0, 255, 255), outlineColour=(0, 0, 0), alignment=4, offset=(0, 0), displayNumber=1, timeout=5.550000000000001, event=3896, skin=None)
15:24:36: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:24:42: DEBUG: 1 MainThread: OSDFrame.OnPaint(dummyEvent=<wx.PaintEvent>)
15:24:44: DEBUG: 0 Thread-119: OSDFrame.OnTimeout()
15:24:57: DEBUG: 1 MainThread: App.Exit()
15:24:57: DEBUG: 1 MainThread: Document.CheckFileNeedsSave()
15:24:57: DEBUG: 1 MainThread: Document.CheckFileNeedsSave => 5100
15:24:57: DEBUG: 1 MainThread: Document.Close()
15:24:57: DEBUG: 1 MainThread: MainFrame.Destroy()
15:24:57: DEBUG: 1 MainThread: LogCtrl.Destroy()
15:24:57: DEBUG: 1 MainThread: TreeCtrl.Destroy()
15:24:57: DEBUG: 1 MainThread: StatusBar.Destroy()
15:24:57: DEBUG: 1 MainThread: StatusBar.__del__()
15:24:57: DEBUG: 1 MainThread: MainFrame.Destroy => True
15:24:57: DEBUG: 1 MainThread: Document.GetExpandState()
15:24:57: DEBUG: 1 MainThread: Document.Close => None
15:24:57: DEBUG: 1 MainThread: MainFrame.Iconize(flag=False)
15:24:57: DEBUG: 1 MainThread: Triggering OnClose
15:24:57: DEBUG: 1 MainThread: App.OnExit()
15:24:57: DEBUG: 1 MainThread: Calling exit functions
15:24:57: DEBUG: 1 MainThread: <function CloseOSD at 0x09ADE6F0>
15:24:57: DEBUG: 1 MainThread: Calling eg.DeInit()
15:24:57: DEBUG: 1 MainThread: stopping threads
15:24:57: DEBUG: 0 ActionThread: ActionThread.StopSession()
15:24:57: DEBUG: 0 ActionThread: UnloadPlugins()
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Task
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\MediaPlayerClassic
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Keyboard
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Taskbar
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\OSE
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\DX_USB_Remote
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\EventGhost
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\System
15:24:57: DEBUG: 0 ActionThread: System.__stop__()
15:24:57: DEBUG: 0 ActionThread: System.__stop__ => None
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Window
15:24:57: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Mouse
15:24:57: DEBUG: 0 ActionThread: Mouse.__stop__()
15:24:57: DEBUG: 0 ActionThread: Mouse.__close__()
15:24:57: DEBUG: 0 ActionThread: ActionThread.__MainLoop => None
15:24:57: DEBUG: 0 EventThread: EventThread.__MainLoop => None
15:24:57: DEBUG: 0 MouseThread: MouseThread.run => None
15:24:58: DEBUG: 0 Socket Server: stopping...
15:24:58: DEBUG: 0 Socket Server: stopped.
15:24:58: DEBUG: 1 MainThread: shutting down
15:24:58: DEBUG: 1 MainThread: MainMessageReceiver.Stop()
15:24:58: DEBUG: 0 MainMessageReceiver: MainMessageReceiver.__MainLoop => None
15:24:58: DEBUG: 1 MainThread: Waited for threads shutdown: 0.000006 s
15:24:58: DEBUG: 1 MainThread: Done!
Post by kgschlosser » Sat Oct 12, 2019 4:27 am
I need to see that log file when EG crashes/locks up.
I need to know if anything is getting captured in the log before it happens.
also I did ask for this as well.
I do not think the error in the log is causing your issue with EG hanging. But I do want to clear it up.
molitar
Post by molitar » Sat Oct 12, 2019 5:33 am
Value
propResize = True
The original log file I have is 2.2MB in size and as I am for some reason unable to attach any file without the error I have uploaded it to Google Drive.
Error
Error parsing server response.
Log file
https://drive.google.com/open?id=1JQYTg ... azxtNDSNPA
Now not sure if you meant the _init_.py for the ratio but if it is...
ratio = 2.0
Now I did have EventGhost freak out and then freeze up but this time it was with volume control up.. It got stuck in an infinite up even after I had stopped pressing remote button. The log file with that is also been uploaded to Google Drive.
Current Log with volume control getting stuck up and it reporting 0%
https://drive.google.com/open?id=1_5NcR ... roFM79390y
Post by kgschlosser » Sat Oct 12, 2019 4:50 pm
OK so now I can see what is going on.
I need a copy of your tree. send it to me in a PM please.
The reason why is you have an event that is created from a Windows notification. and with how EG is designed if for some reason the macro that you have running in that event takes a really long time it causes a stall in the windows notification system. this causes a cascading failure in EG and eventually either an application crash or it will simply freeze. I do not know exactly which event is causing it because it seem like it is happening when you start EG
also change that propResize to be False you need to do this when you do not have EG running
