Please help with script it has stopped working
molitar
Post by molitar » Tue Aug 06, 2019 3:18 am
This code just stopped working with the python error below.
Python script "1", line 7, in <module>
hwnd = Find_MPC_Volume_Ctrl()
File "C:\Program Files (x86)\EventGhost\eg\Classes\WindowMatcher.py", line 127, in FindMatch
hwnds = self.Find()
File "C:\Program Files (x86)\EventGhost\eg\Classes\WindowMatcher.py", line 120, in Find
childClassMatch(GetClassName(childHwnd)) and
OverflowError: Python int too large to convert to C long
Please help with error in this code. Thanks
# variable fs = fontsize as a string
from eg.WinApi.Dynamic import SendMessage
TBM_GETPOS = 1024
Find_MPC_Volume_Ctrl=eg.WindowMatcher(u'mpc-hc64.exe', None, u'MediaPlayerClassicW', None, u'msctls_trackbar32', 1, True, 0.0, 0)
if len(hwnd) > 0:
    if eg.globals.WindowsState != "Fullscreen":
        fs = '64'
        mon = 2
        top = 1000
        fs = '128'
        mon = 1
        top = 1800
    volume = SendMessage(hwnd[0], TBM_GETPOS, 0, 0)
    osd = "Volume: %i%%"
    if volume == 1 : volume = 0
    eg.plugins.EventGhost.ShowOSD(osd % volume, u'0;-' + fs + ';0;0;0;700;0;0;0;238;3;2;1;66;Arial', (255, 255, 255), (0, 0, 0), 5, (0, top), mon, 3.0, True)
    print "Window not found"
Re: Please help with script it has stopped working
Post by kgschlosser » Tue Aug 06, 2019 10:04 pm
you have some application that is running that is causing an issue with it. I close down everything you have running except for EG and MPC and give it a go and see what happens.
molitar
Post by molitar » Wed Aug 07, 2019 2:27 am
Actually restoring the mediaplayerclassic plugin from a system backup fixed it. I am not sure if Windows 10 did something with permissions or somehow corrupted the file. But restoring that fixed the problem. That was all I did was restore from a 1 week backup and it worked. Wonder if a Win 10 update modified some permissions?
Post by kgschlosser » Wed Aug 07, 2019 4:40 am
There are a new set of challenges to overcome when Microsoft releases new builds.
And it has nothing to do with permissions. The issue is that some data that was received via the Windows API and then passed to another portion of the Windows API and it didn't like it.
so here is an example.
if you set a chunk of data to be a 32 bit integer it can hold a number between 0 and 4,294,967,295
and if you set another chunk of data to be a 64 bit integer it can hold a number between 0 and 9,223,372,036,854,775,807
In python an int is an int. in c++ not so much.
So if somewhere in the Windows API they changed the data type for a parameter from a 32 bit int to a 64 bit int. and somewhere alse in the API is function that uses the data got elsewhere but they forgot to update the data type to a 64 bit int.
hence why you are getting an error stating that the number is to large.
molitar
Post by molitar » Mon Sep 23, 2019 3:02 am
Thanks and now I stumbled on problem where all I get is Volume: 0% after updating to Windows 10 build 1903. Is there an easy fix for this problem?
Post by kgschlosser » Tue Sep 24, 2019 9:17 am
Need a little bit more info on this.
You are getting the volume for what and from where?
molitar
Post by molitar » Tue Sep 24, 2019 6:37 pm
From Mediaplayer Classic. Since the update to 1903 the volume just shows 0% now. Same script as first post by me. Only thing that changed is updated Windows from 1809 to 1903.
Post by kgschlosser » Wed Sep 25, 2019 5:32 am
ok this is what I need you to do. something could have changed with the update that is causing the window matcher to return the wrong handle.
there are 2 lines of code in your script you are going to need to change.
create a Find Window action and use the cross hairs to target the volume control in MPC. then I want you to apply the changes and close the dialog.
then right click on the action and in the menu click on "Copy as Python".
then go into you script and replace
with the copied action. the Find Window action does not return anything. But it stored the information elsewhere in EG. so we want to make sure that storage is empty before running the action. so on the line before the action add this code.
 del eg.lastFoundWindows[:]
now I need you to replace the line
with the following code.
# this is going to simply stop the macro from running and exit the script if FindWindow did not find anything.
if not eg.lastFoundWindows:
    eg.StopMacro()
    eg.Exit()
# get the handle from the storage container.
hwnd = eg.lastFoundWindows[0]
you will end up a code block that looks like this. The action parameters are going to be different but the basic outline is going to be the same.
eg.plugins.Window.FindWindow(u'rundll32.exe', u'Speakers Properties', u'#32770', u'', u'msctls_trackbar32', 2, False, 0.0, 0)
    eg.StopMacro()
    eg.Exit()
molitar
Post by molitar » Wed Sep 25, 2019 4:57 pm
Ok here is current code but getting a new error now. Before the event runs I jump to a WindowState script that determines if the Window is in Normal State or Full Screen. I then assign a value called eg.globals.WindowState but with the new script for some reason I have two problems the first is the eg.globals.WindowsState is lost and second problem is hwnd value no longer has a length.
Python script "226", line 17, in <module>
if len(hwnd) > 0:
TypeError: object of type 'int' has no len()
Original code returned
DXusbPCR.Num8
Volume Down
Jump to "Windows State" and return
Windows State
Find Window: mpc-hc64.exe
Python Script
(0, 1, (-32000, -32000), (-1, -1), (-7, 0, 1925, 1140))
Windows State = Normal
Media Player Classic: Volume Down
Python Script
Auto-Repeat Macro: 0.2
Clear Pending Events
For some reason after this new code it's losing the eg.global.WindowState value.
DXusbPCR.Num2
Volume Up
Windows State
Python Script
Media Player Classic: Volume Up
Python Script
Python script "150", line 16, in <module>
print eg.globals.WindowState
AttributeError: 'Bunch' object has no attribute 'WindowState'
TBM_GETPOS = 1024
#del eg.lastFoundWindows[:]
eg.plugins.Window.FindWindow(u'mpc-hc64.exe', None, u'MediaPlayerClassicW', u'', u'msctls_trackbar32', 1, False, 0.0, 0)
   eg.StopMacro()
   eg.Exit()
if len(hwnd) > 0:
        fs = '64'
        mon = 2
        top = 1000
        fs = '128'
        mon = 1
        top = 1800
May help if you see the original WindowsState code.
from win32gui import GetWindowPlacement
#SW_SHOWNORMAL = 1
#SW_SHOWMINIMIZED = 2
#SW_SHOWMAXIMIZED = 3
FindWin = eg.WindowMatcher(None, None, u\'MediaPlayerClassicW\' , None, None, None, True, 0.0, 0)
hwnd = FindWin()
def GetWindowStatus(hwnd):
    showList  = ("None", "Normal", "Minimized", "Maximized")
    placement = GetWindowPlacement(hwnd)
    #unrem the below line to display the placement values that you need for the if placement[4] line
    print placement
    if placement[4] == (1920, 0, 5760, 2160):
        return "Fullscreen"
        return showList[placement[1]]
eg.globals.WindowsState = GetWindowStatus(hwnd[0])
print "Windows State = " + eg.globals.WindowsState
Post by kgschlosser » Wed Sep 25, 2019 8:20 pm
do the same thing you did in the first script to the window state script. instead of targeting the volume control target the actual MPC window instead. then paste the python code into place.
Post by kgschlosser » Wed Sep 25, 2019 8:24 pm
also there is a better way of determining if the window state is actually full screen. a window being maximized and a window being full screen are not the same thing. in order to check if a window is fullscreen you need to check and see if the window has a caption bar or not.
I can key something up for you that will work better.
Let me tinker about with it for a bit. I will install MPC and test with a little bit later today.
molitar
Post by molitar » Sun Sep 29, 2019 3:59 am
Have you had a chance yet? If not that is ok I understand people get busy. Just be nice to have my volume show more then 0% again. Thanks really appreciate it.
Post by kgschlosser » Sun Sep 29, 2019 1:40 pm
This is tested and it's 100% working
This is the volume OSD script. There were a few errors in it like the len(hwnd) and hwnd[0] we aready checked if there was any returned windows. and if there isn't stop the macro and exist the script. so after that we then set hwnd from eg.lastFoundWindows[0]
I removed the unneeded code.
# this is going to seem like a goofy bit of code. what this does is makes sure
# that eg.globals.WindowsState exists. and if it doesn't then set it to 'Normal'
eg.globals.WindowsState = getattr(eg.globals, 'WindowsState', 'Normal')
TBM_GETPOS = 1024
eg.plugins.Window.FindWindow(u'mpc-hc64.exe', None, u'MediaPlayerClassicW', u'', u'msctls_trackbar32', 1, False, 0.0, 2)
   eg.StopMacro()
   eg.Exit()
    fs = '64'
    mon = 2
    top = 1000
    fs = '128'
    mon = 1
    top = 1800
volume = SendMessage(hwnd, TBM_GETPOS, 0, 0)
if volume == 1 :
    volume = 0
and here we have the grabbing of the window state. I shifted to using the Find Window action just like above,, so those mechanics are the same except I am not targeting the volume control.
I do not like pywin32 to much. it has to many goofy issues with it. So insted i grabbed the bull by the horns and used ctypes to access the windows API.
There is one thing that a full screen application does not have.. and that is a border/frame/edge, so we check the style and the style ex for these things and if the window has any of them then it is a "Normal" window. if it has none of them then it is "Fullscreen" window.
I can also put in code that will tell you what monitor the application is playing on as well. so you can set different OSD for it playing fullscreen on a monitor, or normal on a monitor, fullscreen on a TV and normal on a TV.
Let me know if you are interested in that code
I also put into the script all of the various style and style ex constants with a description of what they do.. just for your reference.
import ctypes
from ctypes.wintypes import LONG, HWND
user32 = ctypes.windll.User32
# Retrieves the extended window styles.
GWL_EXSTYLE = -20
# Retrieves a handle to the application instance.
GWL_HINSTANCE = -6
# Retrieves a handle to the parent window, if any.
GWL_HWNDPARENT = -8
# Retrieves the identifier of the window.
GWL_ID = -12
# Retrieves the window styles.
GWL_STYLE = -16
# Retrieves the user data associated with the window. This data is intended
# for use by the application that created the window. Its value is initially
# zero.
GWL_USERDATA = -21
# Retrieves the address of the window procedure, or a handle representing the
# address of the window procedure. You must use the CallWindowProc function to
# call the window procedure.
GWL_WNDPROC = -4
# ***** Wnidow Styles
# The window has a thin-line border.
WS_BORDER = 0x00800000
# The window has a title bar (includes the WS_BORDER style).
WS_CAPTION = 0x00C00000
# The window is a child window. A window with this style cannot have a menu
# bar. This style cannot be used with the WS_POPUP style.
WS_CHILD = 0x40000000
# Same as the WS_CHILD style.
WS_CHILDWINDOW = 0x40000000
# Excludes the area occupied by child windows when drawing occurs within the
# parent window. This style is used when creating the parent window.
WS_CLIPCHILDREN = 0x02000000
# Clips child windows relative to each other; that is, when a particular child
# window receives a WM_PAINT message, the WS_CLIPSIBLINGS style clips all
# other overlapping child windows out of the region of the child window to be
# updated. If WS_CLIPSIBLINGS is not specified and child windows overlap,
# it is possible, when drawing within the client area of a child window, to
# draw within the client area of a neighboring child window.
WS_CLIPSIBLINGS = 0x04000000
# The window is initially disabled. A disabled window cannot receive input
# from the user. To change this after a window has been created, use the
# EnableWindow function.
WS_DISABLED = 0x08000000
# The window has a border of a style typically used with dialog boxes. A
# window with this style cannot have a title bar.
WS_DLGFRAME = 0x00400000
# The window is the first control of a group of controls. The group consists
# of this first control and all controls defined after it, up to the next
# control with the WS_GROUP style. The first control in each group usually
# has the WS_TABSTOP style so that the user can move from group to group.
# The user can subsequently change the keyboard focus from one control in
# the group to the next control in the group by using the direction keys.
# You can turn this style on and off to change dialog box navigation. To
# change this style after a window has been created, use the SetWindowLong
# function.
WS_GROUP = 0x00020000
# The window has a horizontal scroll bar.
WS_HSCROLL = 0x00100000
# The window is initially minimized. Same as the WS_MINIMIZE style.
WS_ICONIC = 0x20000000
# The window is initially maximized.
WS_MAXIMIZE = 0x01000000
# The window has a maximize button. Cannot be combined with the
# WS_EX_CONTEXTHELP style. The WS_SYSMENU style must also be specified.
WS_MAXIMIZEBOX = 0x00010000
# The window is initially minimized. Same as the WS_ICONIC style.
WS_MINIMIZE = 0x20000000
# The window has a minimize button. Cannot be combined with the
WS_MINIMIZEBOX = 0x00020000
# The window is an overlapped window. An overlapped window has a title bar
# and a border. Same as the WS_TILED style.
WS_OVERLAPPED = 0x00000000
# The windows is a pop-up window. This style cannot be used with the
# WS_CHILD style.
WS_POPUP = 0x80000000
# The window has a sizing border. Same as the WS_THICKFRAME style.
WS_SIZEBOX = 0x00040000
# The window has a window menu on its title bar. The WS_CAPTION style must
# also be specified.
WS_SYSMENU = 0x00080000
# The window is a control that can receive the keyboard focus when the user
# presses the TAB key. Pressing the TAB key changes the keyboard focus to
# the next control with the WS_TABSTOP style. You can turn this style on
# and off to change dialog box navigation. To change this style after a
# window has been created, use the SetWindowLong function. For user-created
# windows and modeless dialogs to work with tab stops, alter the message
# loop to call the IsDialogMessage function.
WS_TABSTOP = 0x00010000
# The window has a sizing border. Same as the WS_SIZEBOX style.
WS_THICKFRAME = 0x00040000
# and a border. Same as the WS_OVERLAPPED style.
WS_TILED = 0x00000000
# The window is an overlapped window. Same as the WS_OVERLAPPEDWINDOW style.
WS_TILEDWINDOW = (
    WS_OVERLAPPED |
    WS_CAPTION |
    WS_SYSMENU |
    WS_THICKFRAME |
    WS_MINIMIZEBOX |
    WS_MAXIMIZEBOX
# The window is an overlapped window. Same as the WS_TILEDWINDOW style.
WS_OVERLAPPEDWINDOW = (
    WS_OVERLAPPED |
    WS_CAPTION |
    WS_SYSMENU |
    WS_THICKFRAME |
    WS_MINIMIZEBOX |
    WS_MAXIMIZEBOX
# The window is a pop-up window. The WS_CAPTION and WS_POPUPWINDOW styles
# must be combined to make the window menu visible.
WS_POPUPWINDOW = (
    WS_POPUP |
    WS_BORDER |
    WS_SYSMENU
# The window is initially visible. This style can be turned on and off by
# using the ShowWindow or SetWindowPos function.
WS_VISIBLE = 0x10000000
# The window has a vertical scroll bar.
WS_VSCROLL = 0x00200000
# ******* Extended Styles
# The window accepts drag-drop files.
WS_EX_ACCEPTFILES = 0x00000010
# Forces a top-level window onto the taskbar when the window is visible.
WS_EX_APPWINDOW = 0x00040000
# The window has a border with a sunken edge.
WS_EX_CLIENTEDGE = 0x00000200
# Paints all descendants of a window in bottom-to-top painting order using
# double-buffering. For more information, see Remarks. This cannot be used if
# the window has a class style of either CS_OWNDC or CS_CLASSDC.
# Windows 2000: This style is not supported.
WS_EX_COMPOSITED = 0x02000000
# The title bar of the window includes a question mark. When the user clicks
# the question mark, the cursor changes to a question mark with a pointer.
# If the user then clicks a child window, the child receives a WM_HELP
# message. The child window should pass the message to the parent window
# procedure, which should call the WinHelp function using the HELP_WM_HELP
# command. The Help application displays a pop-up window that typically
# contains help for the child window. WS_EX_CONTEXTHELP cannot be used with
# the WS_MAXIMIZEBOX or WS_MINIMIZEBOX styles.
WS_EX_CONTEXTHELP = 0x00000400
# The window itself contains child windows that should take part in dialog
# box navigation. If this style is specified, the dialog manager recurses
# into children of this window when performing navigation operations such as
# handling the TAB key, an arrow key, or a keyboard mnemonic.
WS_EX_CONTROLPARENT = 0x00010000
# The window has a double border; the window can, optionally, be created with
# a title bar by specifying the WS_CAPTION style in the dwStyle parameter.
WS_EX_DLGMODALFRAME = 0x00000001
# The window is a layered window. This style cannot be used if the window has
# a class style of either CS_OWNDC or CS_CLASSDC. Windows 8: The WS_EX_LAYERED
# style is supported for top-level windows and child windows. Previous Windows
# versions support WS_EX_LAYERED only for top-level windows.
WS_EX_LAYERED = 0x00080000
# If the shell language is Hebrew, Arabic, or another language that supports
# reading order alignment, the horizontal origin of the window is on the right
# edge. Increasing horizontal values advance to the left.
WS_EX_LAYOUTRTL = 0x00400000
# The window has generic left-aligned properties. This is the default.
WS_EX_LEFT = 0x00000000
# reading order alignment, the vertical scroll bar (if present) is to the left
# of the client area. For other languages, the style is ignored.
WS_EX_LEFTSCROLLBAR = 0x00004000
# The window text is displayed using left-to-right reading-order properties.
# This is the default.
WS_EX_LTRREADING = 0x00000000
# The window is a MDI child window.
WS_EX_MDICHILD = 0x00000040
# A top-level window created with this style does not become the foreground
# window when the user clicks it. The system does not bring this window to the
# foreground when the user minimizes or closes the foreground window. The
# window should not be activated through programmatic access or via keyboard
# navigation by accessible technology, such as Narrator. To activate the
# window, use the SetActiveWindow or SetForegroundWindow function. The window
# does not appear on the taskbar by default. To force the window to appear on
# the taskbar, use the WS_EX_APPWINDOW style.
WS_EX_NOACTIVATE = 0x08000000
# The window does not pass its window layout to its child windows.
WS_EX_NOINHERITLAYOUT = 0x00100000
# The child window created with this style does not send the WM_PARENTNOTIFY
# message to its parent window when it is created or destroyed.
WS_EX_NOPARENTNOTIFY = 0x00000004
# The window does not render to a redirection surface. This is for windows
# that do not have visible content or that use mechanisms other than surfaces
# to provide their visual.
WS_EX_NOREDIRECTIONBITMAP = 0x00200000
# The window has generic "right-aligned" properties. This depends on the
# window class. This style has an effect only if the shell language is Hebrew,
# Arabic, or another language that supports reading-order alignment;
# otherwise, the style is ignored. Using the WS_EX_RIGHT style for static or
# edit controls has the same effect as using the SS_RIGHT or ES_RIGHT style,
# respectively. Using this style with button controls has the same effect as
# using BS_RIGHT and BS_RIGHTBUTTON styles.
WS_EX_RIGHT = 0x00001000
# The vertical scroll bar (if present) is to the right of the client area.
WS_EX_RIGHTSCROLLBAR = 0x00000000
# reading-order alignment, the window text is displayed using right-to-left
# reading-order properties. For other languages, the style is ignored.
WS_EX_RTLREADING = 0x00002000
# The window has a three-dimensional border style intended to be used for
# items that do not accept user input.
WS_EX_STATICEDGE = 0x00020000
# The window is intended to be used as a floating toolbar. A tool window has
# a title bar that is shorter than a normal title bar, and the window title is
# drawn using a smaller font. A tool window does not appear in the taskbar or
# in the dialog that appears when the user presses ALT+TAB. If a tool window
# has a system menu, its icon is not displayed on the title bar. However, you
# can display the system menu by right-clicking or by typing ALT+SPACE.
WS_EX_TOOLWINDOW = 0x00000080
# The window should be placed above all non-topmost windows and should stay
# above them, even when the window is deactivated. To add or remove this
# style, use the SetWindowPos function.
WS_EX_TOPMOST = 0x00000008
# The window should not be painted until siblings beneath the window (that
# were created by the same thread) have been painted. The window appears
# transparent because the bits of underlying sibling windows have already
# been painted. To achieve transparency without these restrictions, use the
# SetWindowRgn function.
WS_EX_TRANSPARENT = 0x00000020
# The window has a border with a raised edge.
WS_EX_WINDOWEDGE = 0x00000100
WS_EX_OVERLAPPEDWINDOW = (
    WS_EX_WINDOWEDGE |
    WS_EX_CLIENTEDGE
# The window is palette window, which is a modeless dialog box that presents
# an array of commands.
WS_EX_PALETTEWINDOW = (
    WS_EX_WINDOWEDGE |
    WS_EX_TOOLWINDOW |
    WS_EX_TOPMOST
# LONG GetWindowLongW(
#   HWND hWnd,
#   int  nIndex
_GetWindowLong = user32.GetWindowLongW
_GetWindowLong.restype = LONG
eg.plugins.Window.FindWindow(u'mpc-hc64.exe', None, u'MediaPlayerClassicW', None, None, None, False, 0.0, 2)
   eg.StopMacro()
   eg.Exit()
style = _GetWindowLong(HWND(hwnd), GWL_STYLE)
style_ex = _GetWindowLong(HWND(hwnd), GWL_EXSTYLE)
if style == style | WS_ICONIC:
    eg.globals.WindowsState = 'Minimized'
elif style == style | WS_MAXIMIZE:
    eg.globals.WindowsState = 'Maximized'
elif (
    style == style | WS_BORDER and
    style == style | WS_DLGFRAME and
    style == style | WS_THICKFRAME and
    style_ex == style_ex | WS_EX_WINDOWEDGE
    eg.globals.WindowsState = 'Normal'
    eg.globals.WindowsState = 'Fullscreen'
molitar
Post by molitar » Sun Sep 29, 2019 9:01 pm
Thanks for that code I did find one minor problem and that was in my detect window I had to select detect hidden also as when it is in fullscreen the controls are hidden so the code was exiting. Took me a bit to figure out the problem but I did and fixed that.
Post by kgschlosser » Mon Sep 30, 2019 6:54 am
is everything working now?
