Logging Windows operations? Moving application to virtual desktop?
Re: Logging Windows operations? Moving application to virtual desktop?
Post by kgschlosser » Tue Aug 20, 2019 4:48 am
Let me know what does and does not work and I will go from there.
Now remember that if an action has "Get" at the first word that means the action returns something. so if you add the Dump result to log action after it you will see the returned item get printed out..
If you want to access the returned item from a python script then you put the get action and then a python script.. eg.result is what the returned item gets set to.
dan Edens
Post by dan Edens » Wed Sep 11, 2019 1:13 pm
Okay today I'ma do that. I've been to busy to have the brain power for anything last 3 weeks.
So to me this the most important action is "Move Window To Desktop." Would love to get EG sorting my absurd amount of clutter.
When i try to configure it, this is what i get.
Traceback (most recent call last) (WIP):
  File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 180, in ProcessingTask
  File "C:\Program Files (x86)\EventGhost\eg\Classes\ConfigDialog.py", line 112, in Configure
    treeItem.Configure(*args)
  File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionItem.py", line 80, in Configure
  File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 268, in Configure
    list(desktop.name for desktop in pyWinVirtualDesktop)
  File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 268, in <genexpr>
  File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\pyWinVirtualDesktop\__init__.py", line 599, in name
    return pyWinVirtualDesktop.config.get_name(self.id)
  File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\pyWinVirtualDesktop\config.py", line 56, in get_name
    desktop_ids = pyWinVirtualDesktop.desktop_ids
  File "C:\Program Files (x86)\EventGhost\eg\__init__.py", line 50, in __getattr__
    mod = __import__("eg.Classes." + name, None, None, [name], 0)
ImportError: No module named desktop_ids
Here is the log from trying to use "Pin App"
  File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 362, in Configure
    if use_window_ctrl_label.GetValue():
AttributeError: 'StaticText' object has no attribute 'GetValue'
So above I see that it has no window target, okay so i try to use find window action which returns this,
  File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 349, in on_use_window
    evt.skip()
AttributeError: 'CommandEvent' object has no attribute 'skip'
Cheers!
dan Edens
Post by dan Edens » Mon Sep 23, 2019 1:28 am
just bumping incase it didn't refresh, I haven't been getting notifications for some reason.
Post by kgschlosser » Tue Sep 24, 2019 9:15 am
It's on my todo list. been working on my house quite a bit and I have not had a huge amount of time for my "hobbies"
dan Edens
Post by dan Edens » Thu Sep 26, 2019 4:05 pm
no worries dude i'm in the same boat. I've been to my desk twice this month lol
