Logging Windows operations? Moving application to virtual desktop?
Re: Logging Windows operations? Moving application to virtual desktop?
Post by kgschlosser » Tue Aug 06, 2019 9:49 pm
ok so here is a test run of a plugin. I have not even tried to load this thing yet.
https://github.com/kdschlosser/WindowsVirtualDesktop
dan Edens
Post by dan Edens » Tue Aug 06, 2019 10:01 pm
This is what i got. Wasn't sure where to put everything so i included pics of what I did. in lib27 and site packages.
mostly just rushing out the door at work, I'll dig tomorrow!
      Error starting plugin: WindowsVirtualDesktop
      Traceback (most recent call last) (WIP):
        File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginInstanceInfo.py", line 196, in Start
        File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 212, in __start__
          import pyWinVirtualDesktop as _pyWinVirtualDesktop
        File "C:\Program Files (x86)\EventGhost\plugins\WindowsVirtualDesktop\pyWinVirtualDesktop\__init__.py", line 9, in <module>
          import libWinVirtualDesktop as _libWinVirtualDesktop
      ImportError: DLL load failed: %1 is not a valid Win32 application.
2019-08-06 16_59_48-Window.png (10.74 KiB) Viewed 3109 times
Post by kgschlosser » Tue Aug 06, 2019 10:08 pm
OYE!!!
I have to compile it as 32 bit.. sorry about that. forgot..
Post by kgschlosser » Tue Aug 06, 2019 10:09 pm
I also see I need to fix an issue with the location of the pyd file.
Post by kgschlosser » Tue Aug 06, 2019 10:20 pm
OK both of those are now fixed.
you only need to put the WindowsVirtualDektop folder into %programdata%\EventGhost\plugins folder. then add the plugin to your tree.
dan Edens
Post by dan Edens » Wed Aug 07, 2019 2:18 pm
Got it working!
Okay tried this a few ways.
When I place it in programdata/eg/plugins it doesn't show up.
Shows up when I have it in the programfiles(x86)/eg/plugins but everything gives not enough arg errors.
   Error in Action: "WindowsVirtualDesktop: Get Desktop Name From Number"
     File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionBase.py", line 116, in CallWrapper
       return self(*args)
   TypeError: __call__() takes exactly 2 arguments (1 given)
Get Desktops(from programfiles/eg/plugins) works!! but the rest are as above.
Post by kgschlosser » Wed Aug 07, 2019 8:11 pm
hmmmm ok.. let me have a look see at what is going on.
Post by kgschlosser » Wed Aug 07, 2019 8:27 pm
ok dumb question here..
you are letting the plugin load the actions into your tree automatically yes??
are you configuring those actions before executing them?
dan Edens
Post by dan Edens » Tue Aug 13, 2019 8:25 pm
Sorry I've had a hell of a week.
I should of been more clear about that.
I'm not configuring them because that is when it errors out, when i try to open config. I'll make a list of which ones do it one sec
edit:
I think I set it up incorrectly. I'll get back to you
dan Edens
Post by dan Edens » Tue Aug 13, 2019 8:48 pm
Okay now I got it working from the program data location instead of EG's plugin folder.
Nothing has changed, This is running "is app pinned" without find window, than with find window. Not sure if thats helpful but it was diffrent.
  File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 180, in ProcessingTask
  File "C:\Program Files (x86)\EventGhost\eg\Classes\ConfigDialog.py", line 112, in Configure
    treeItem.Configure(*args)
  File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionItem.py", line 80, in Configure
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 311, in Configure
    window_ctrl = wx.Choice(self, -1, choices=sorted(choices))
  File "wx\_controls.pyc", line 501, in __init__
TypeError: in method 'new_Choice', expected argument 1 of type 'wxWindow *'
Keyboard.LCtrl
Keyboard.LShift+LCtrl
Keyboard.LShift+LCtrl+A
Keyboard.RCtrl
Keyboard.RCtrl+Return
Is App Pinned
   Find Window: sublime_text.exe
   WindowsVirtualDesktop: Is App Pinned
      Error in Action: "WindowsVirtualDesktop: Is App Pinned"
          return self(*args)
Here is a list of which ones will configure and which ones error, aswell as the total error log from giving them all a go.
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 241, in Configure
    list(desktop.name for desktop in pyWinVirtualDesktop)
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 241, in <genexpr>
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\pyWinVirtualDesktop\__init__.py", line 599, in name
    return pyWinVirtualDesktop.config.get_name(self.id)
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\pyWinVirtualDesktop\config.py", line 56, in get_name
    desktop_ids = pyWinVirtualDesktop.desktop_ids
  File "C:\Program Files (x86)\EventGhost\eg\__init__.py", line 50, in __getattr__
    mod = __import__("eg.Classes." + name, None, None, [name], 0)
ImportError: No module named desktop_ids
TaskMonitorPlus.Deactivated.EventGhost <title='[EventGhost]', window_class=u'wxWindowNR',...>
TaskMonitorPlus.Activated.mspaint <title=u'Untitled - Paint', window_class=u'MSPaintApp',...>
TaskMonitorPlus.Deactivated.mspaint <title=u'Untitled - Paint', window_class=u'MSPaintApp',...>
TaskMonitorPlus.Activated.EventGhost <title='[EventGhost]', window_class=u'wxWindowNR',...>
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 264, in Configure
  File "C:\ProgramData\EventGhost\plugins\WindowsVirtualDesktop\__init__.py", line 264, in <genexpr>
Keyboard.LCtrl
get Desktops returns eg.result to
[<eg.UserPluginModule.WindowsVirtualDesktop.pyWinVirtualDesktop.Desktop object at 0x0A295150>, <eg.UserPluginModule.WindowsVirtualDesktop.pyWinVirtualDesktop.Desktop object at 0x0A2E8C50>]
which is super cool! lol
Post by kgschlosser » Wed Aug 14, 2019 6:46 am
are you configuring the the actions.. double click on the actions!!!!! just about all of them have settings to them.
****** EDIT ***** sorry about that I'm a dumb ass and didn't read your entire post. I will fix the issue. have to change the self in alot of those controls to panel is all.. I will do it now. I will also add in support for find window.
Post by kgschlosser » Wed Aug 14, 2019 6:49 am
the find window action is a slow pig... and any of the desktop stuff can only be done on top level windows so for me to enumerate those and then check and see if it is visible (shown) and see if it is attached to a virtual desktop is a whole mess faster then the find window action. the find window action is geared to all window sub classed items. and not just top level windows.
I will add in support for using find window as well only because it gives the option of stopping the macro and also wildcarding
Post by kgschlosser » Wed Aug 14, 2019 7:20 am
OK i fixed the actions so the config dialogs for them should work now.
I also added in support for the FindWindow action being used ahead of one of the actions that support it. You will need to configure the action to use the FindWindow action..
now what do you mean by this?? it should work easily in both locations. copy the folder that has the __init__.py in it right into either the plugins folder in program files or into the one in programdata. you do not want to have a copy in both locations.
Post by kgschlosser » Wed Aug 14, 2019 7:31 am
I also believe i fixed the other traceback errors. the ones that are not related to wxPython.
dan Edens
Post by dan Edens » Mon Aug 19, 2019 10:39 pm
Ah awesome, thanks dude your the best.
