Logging Windows operations? Moving application to virtual desktop?
- kgschlosser
Re: Logging Windows operations? Moving application to virtual desktop?
Its not a plugin. so do not pay attention to it. just use the code on the first page of this topic.
kgschlosser wrote: ↑Thu Jul 25, 2019 9:27 pmwell it's not really a plugin yet. This is just a drop into a pyhon script and run at the moment. Once I get the initial connection bits working then a plugin can be developed.
Not sure what you mean by that..
You have it in the register plugin.Code: Select all
eg.RegisterPlugin( name = "Virtual Desktops", author = "Kgschlosser", version = "0.0.004", guid = "{C2F03A33-21F5-47FA-B4BB-156362A2F239}", canMultiLoad = False, url = "http://eventghost.net/forum/viewtopic.php?f=10&p=53389#p53389", description = "Creates events based on Virtual desktop interactions.", )
if you mean to get a new GUID.
GUID Generator is a good place.
Yes! that is what I meant. Thanks I've been stuck here 4 plugins I want to make. Basically I'm just learning what guid really is other than a number I google what to do with whenever i see it .
O dude sorry I was making a joke. Really wasn't clear my bad. It's the first steps towards a plugin is all. I'll make sure you know if and when it get's done.
No worries about the plugin not working. Kevin, I get this error now
from ctypes.wintypes import HRESULT, HWND, BOOL, POINTER, DWORD, INT, UINT, LPVOID, ULONG
import comtypes
import ctypes
from comtypes import helpstring, COMMETHOD
from comtypes.GUID import GUID
REFGUID = POINTER(GUID)
REFIID = REFGUID
ENUM = INT
IID = GUID
INT32 = ctypes.c_int32
INT64 = ctypes.c_int64
CLSID_ImmersiveShell = GUID(
'{C2F03A33-21F5-47FA-B4BB-156362A2F239}'
CLSID_IVirtualNotificationService = GUID(
'{A501FDEC-4A09-464C-AE4E-1B9C21B84918}'
class HSTRING__(ctypes.Structure):
_fields_ = [
('unused', INT),
HSTRING = POINTER(HSTRING__)
class EventRegistrationToken(ctypes.Structure):
_fields_ = [
('value', INT64)
class AdjacentDesktop(ENUM):
LeftDirection = 3
RightDirection = 4
class ApplicationViewOrientation(ENUM):
ApplicationViewOrientation_Landscape = 0
ApplicationViewOrientation_Portrait = 1
class TrustLevel(ENUM):
BaseTrust = 0
PartialTrust = BaseTrust + 1
FullTrust = PartialTrust + 1
IID_IInspectable = GUID(
'{AF86E2E0-B12D-4C6A-9C5A-D7AA65101E90}'
class IInspectable(comtypes.IUnknown):
_case_insensitive_ = True
_idlflags_ = []
_iid_ = IID_IInspectable
_methods_ = [
COMMETHOD(
[helpstring('Method GetIids')],
HRESULT,
'GetIids',
(['out'], POINTER(ULONG), 'iidCount'),
(['out'], POINTER(POINTER(IID)), 'iids'),
COMMETHOD(
[helpstring('Method GetRuntimeClassName')],
HRESULT,
'GetRuntimeClassName',
(['out'], POINTER(HSTRING), 'className'),
COMMETHOD(
[helpstring('Method GetTrustLevel')],
HRESULT,
'GetTrustLevel',
(['out'], POINTER(TrustLevel), 'trustLevel'),
IID_IApplicationViewConsolidatedEventArgs = GUID(
'{514449EC-7EA2-4DE7-A6A6-7DFBAAEBB6FB}'
class IApplicationViewConsolidatedEventArgs(IInspectable):
_iid_ = IID_IApplicationViewConsolidatedEventArgs
_idlflags_ = []
_methods_ = [
COMMETHOD(
[helpstring('Method get_IsUserInitiated')],
HRESULT,
'get_IsUserInitiated',
(['retval', 'out'], POINTER(BOOL), 'value'),
IID_IApplicationView = GUID(
'{D222D519-4361-451E-96C4-60F4F9742DB0}'
class IApplicationView(IInspectable):
_idlflags_ = []
_methods_ = [
COMMETHOD(
[helpstring('Method get_Orientation')],
HRESULT,
'get_Orientation',
(['retval', 'out'], POINTER(ApplicationViewOrientation), 'value'),
COMMETHOD(
[helpstring('Method get_AdjacentToLeftDisplayEdge')],
HRESULT,
'get_AdjacentToLeftDisplayEdge',
COMMETHOD(
[helpstring('Method get_AdjacentToRightDisplayEdge')],
HRESULT,
'get_AdjacentToRightDisplayEdge',
COMMETHOD(
[helpstring('Method get_IsFullScreen')],
HRESULT,
'get_IsFullScreen',
COMMETHOD(
[helpstring('Method get_IsOnLockScreen')],
HRESULT,
'get_IsOnLockScreen',
COMMETHOD(
[helpstring('Method get_IsScreenCaptureEnabled')],
HRESULT,
'get_IsScreenCaptureEnabled',
COMMETHOD(
[helpstring('Method put_IsScreenCaptureEnabled')],
HRESULT,
'put_IsScreenCaptureEnabled',
(['in'], BOOL, 'value'),
COMMETHOD(
[helpstring('Method put_Title')],
HRESULT,
'put_Title',
(['in'], HSTRING, 'value'),
COMMETHOD(
[helpstring('Method get_Title')],
HRESULT,
'get_Title',
(['retval', 'out'], POINTER(HSTRING), 'value'),
COMMETHOD(
[helpstring('Method get_Id')],
HRESULT,
'get_Id',
(['retval', 'out'], POINTER(INT32), 'value'),
COMMETHOD(
[helpstring('Method add_Consolidated')],
HRESULT,
'add_Consolidated',
(['in'], POINTER(IApplicationViewConsolidatedEventArgs), 'handler'),
(['retval', 'out'], POINTER(EventRegistrationToken), 'token'),
COMMETHOD(
[helpstring('Method remove_Consolidated')],
HRESULT,
'remove_Consolidated',
(['in',], EventRegistrationToken, 'EventRegistrationToken'),
IID_IServiceProvider = GUID(
'{6D5140C1-7436-11CE-8034-00AA006009FA}'
class IServiceProvider(comtypes.IUnknown):
_idlflags_ = []
_iid_ = IID_IServiceProvider
_methods_ = [
COMMETHOD(
[helpstring('Method QueryService'), 'local', 'in'],
HRESULT,
'QueryService',
(['in'], REFGUID, 'guidService'),
(['in'], REFIID, 'riid'),
(['out'], POINTER(LPVOID), 'ppvObject'),
IID_IObjectArray = GUID(
"{92CA9DCD-5622-4BBA-A805-5E9F541BD8C9}"
class IObjectArray(comtypes.IUnknown):
Unknown Object Array
_idlflags_ = []
_iid_ = None
_methods_ = [
COMMETHOD(
[helpstring('Method GetCount')],
HRESULT,
'GetCount',
(['out'], POINTER(UINT), 'pcObjects'),
COMMETHOD(
[helpstring('Method GetAt')],
HRESULT,
'GetAt',
(['in'], UINT, 'uiIndex'),
(['out', 'iid_is'], POINTER(LPVOID), 'ppv'),
IID_IVirtualDesktop = GUID(
'{FF72FFDD-BE7E-43FC-9C03-AD81681E88E4}'
class IVirtualDesktop(comtypes.IUnknown):
_iid_ = IID_IVirtualDesktop
_idlflags_ = []
_methods_ = [
COMMETHOD(
[helpstring('Method IsViewVisible')],
HRESULT,
'IsViewVisible',
(['out'], POINTER(IApplicationView), 'pView'),
(['out'], POINTER(INT), 'pfVisible'),
COMMETHOD(
[helpstring('Method GetID')],
HRESULT,
'GetID',
(['out'], POINTER(GUID), 'pGuid'),
IID_IVirtualDesktopManager = GUID(
'{A5CD92FF-29BE-454C-8D04-D82879FB3F1B}'
class IVirtualDesktopManager(comtypes.IUnknown):
_iid_ = IID_IVirtualDesktopManager
_idlflags_ = []
_methods_ = [
COMMETHOD(
[helpstring('Method IsWindowOnCurrentVirtualDesktop')],
HRESULT,
'IsWindowOnCurrentVirtualDesktop',
(['in'], HWND, 'topLevelWindow'),
(['out'], POINTER(BOOL), 'onCurrentDesktop'),
COMMETHOD(
[helpstring('Method GetWindowDesktopId')],
HRESULT,
'GetWindowDesktopId',
(['out'], POINTER(GUID), 'desktopId'),
COMMETHOD(
[helpstring('Method MoveWindowToDesktop')],
HRESULT,
'MoveWindowToDesktop',
(['in'], REFGUID, 'desktopId'),
CLSID_VirtualDesktopManagerInternal = GUID(
'{C5E0CDCA-7B6E-41B2-9FC4-D93975CC467B}'
IID_IVirtualDesktopManagerInternal = GUID(
'{F31574D6-B682-4CDC-BD56-1827860ABEC6}'
# IID_IVirtualDesktopManagerInternal = GUID(
# '{AF8DA486-95BB-4460-B3B7-6E7A6B2962B5}'
# '{EF9F1A6C-D3CC-4358-B712-F84B635BEBE7}'
class IVirtualDesktopManagerInternal(comtypes.IUnknown):
_iid_ = IID_IVirtualDesktopManagerInternal
_idlflags_ = []
_methods_ = [
COMMETHOD(
HRESULT,
'GetCount',
(['out'], POINTER(UINT), 'pCount'),
COMMETHOD(
[helpstring('Method MoveViewToDesktop')],
HRESULT,
'MoveViewToDesktop',
(['out'], POINTER(IVirtualDesktop), 'pDesktop'),
COMMETHOD(
[helpstring('Method CanViewMoveDesktops')],
HRESULT,
'CanViewMoveDesktops',
(['out'], POINTER(INT), 'pfCanViewMoveDesktops'),
COMMETHOD(
[helpstring('Method GetCurrentDesktop')],
HRESULT,
'GetCurrentDesktop',
(['out'], POINTER(POINTER(IVirtualDesktop)), 'desktop'),
COMMETHOD(
[helpstring('Method GetDesktops')],
HRESULT,
'GetDesktops',
(['out'], POINTER(POINTER(IObjectArray)), 'ppDesktops'),
COMMETHOD(
[helpstring('Method GetAdjacentDesktop')],
HRESULT,
'GetAdjacentDesktop',
(['out'], POINTER(IVirtualDesktop), 'pDesktopReference'),
(['in'], AdjacentDesktop, 'uDirection'),
(['out'], POINTER(POINTER(IVirtualDesktop)), 'ppAdjacentDesktop'),
COMMETHOD(
[helpstring('Method SwitchDesktop')],
HRESULT,
'SwitchDesktop',
(['in'], POINTER(IVirtualDesktop), 'pDesktop'),
COMMETHOD(
[helpstring('Method CreateDesktopW')],
HRESULT,
'CreateDesktopW',
(['out'], POINTER(POINTER(IVirtualDesktop)), 'ppNewDesktop'),
COMMETHOD(
[helpstring('Method RemoveDesktop')],
HRESULT,
'RemoveDesktop',
(['in'], POINTER(IVirtualDesktop), 'pRemove'),
(['in'], POINTER(IVirtualDesktop), 'pFallbackDesktop'),
COMMETHOD(
[helpstring('Method FindDesktop')],
HRESULT,
'FindDesktop',
(['in'], POINTER(GUID), 'desktopId'),
(['out'], POINTER(POINTER(IVirtualDesktop)), 'ppDesktop'),
IID_IVirtualDesktopNotification = GUID(
'{C179334C-4295-40D3-BEA1-C654D965605A}'
class IVirtualDesktopNotification(comtypes.IUnknown):
_iid_ = IID_IVirtualDesktopNotification
_idlflags_ = []
_methods_ = [
COMMETHOD(
[helpstring('Method VirtualDesktopCreated')],
HRESULT,
'VirtualDesktopCreated',
COMMETHOD(
[helpstring('Method VirtualDesktopDestroyBegin')],
HRESULT,
'VirtualDesktopDestroyBegin',
(['in'], POINTER(IVirtualDesktop), 'pDesktopDestroyed'),
(['in'], POINTER(IVirtualDesktop), 'pDesktopFallback'),
COMMETHOD(
[helpstring('Method VirtualDesktopDestroyFailed')],
HRESULT,
'VirtualDesktopDestroyFailed',
COMMETHOD(
[helpstring('Method VirtualDesktopDestroyed')],
HRESULT,
'VirtualDesktopDestroyed',
COMMETHOD(
[helpstring('Method ViewVirtualDesktopChanged')],
HRESULT,
'ViewVirtualDesktopChanged',
(['in'], POINTER(IApplicationView), 'pView'),
COMMETHOD(
[helpstring('Method CurrentVirtualDesktopChanged')],
HRESULT,
'CurrentVirtualDesktopChanged',
(['in'], POINTER(IVirtualDesktop), 'pDesktopOld'),
(['in'], POINTER(IVirtualDesktop), 'pDesktopNew'),
IID_IVirtualDesktopNotificationService = GUID('{0CD45E71-D927-4F15-8B0A-8FEF525337BF}')
class IVirtualDesktopNotificationService(comtypes.IUnknown):
_iid_ = IID_IVirtualDesktopNotificationService
_idlflags_ = []
_methods_ = [
COMMETHOD(
[helpstring('Method Register')],
HRESULT,
'Register',
(['in'], POINTER(IVirtualDesktopNotification), 'pNotification'),
(['out'], POINTER(DWORD), 'pdwCookie'),
COMMETHOD(
[helpstring('Method Unregister')],
HRESULT,
'Unregister',
(['in'], DWORD, 'dwCookie'),
comtypes.CoInitialize()
pServiceProvider = comtypes.CoCreateInstance(
CLSID_ImmersiveShell,
IServiceProvider,
comtypes.CLSCTX_LOCAL_SERVER,
pDesktopManagerInternal = comtypes.cast(
pServiceProvider.QueryService(
CLSID_VirtualDesktopManagerInternal,
ctypes.POINTER(IVirtualDesktopManagerInternal)
pObjectArray = POINTER(IObjectArray)()
pDesktopManagerInternal.GetDesktops(ctypes.byref(pObjectArray))
count = UINT()
pObjectArray.GetCount(ctypes.byref(count))
for i in range(count):
pDesktop = POINTER(IVirtualDesktop)()
pObjectArray.GetAt(i, IID_IVirtualDesktop, ctypes.byref(pDesktop))
id = GUID()
pDesktop.GetID(ctypes.byref(id))
print(id)
- kgschlosser
There is a guy that I am working with on getting this going. He has some ctypes and python experience. So it is coming together. It should only be a little while longer before it is finished.
Well than this might of been unnecessary, but I tried to make a template to work from on it, going to convert the code you have in there as best i can to fit as i get time this week.kgschlosser wrote: ↑Sun Jul 28, 2019 4:20 amThere is a guy that I am working with on getting this going. He has some ctypes and python experience. So it is coming together. It should only be a little while longer before it is finished.
https://github.com/DanEdens/Virtual_Desktops_Plugin
I just noticed I posted the code and not the error message so sorry about that. Anyway I saw a tidbit about some changes coming to virtual desktops in future builds of windows. Might want to pass it along. https://www.bleepingcomputer.com/news/m ... -desktops/
- kgschlosser
I know they added the ability to set names to application views the build before last.
They have been adding more and more with each new build of windows 10.
They are on their 9th version of the IApplicationView interface.
I think they are going to switch to a major/minor release schedule so that might give everyone some relief. A new version of Windows every year still sounds like a lot but at least it's not every six months
Virtual desktops are for me the biggest struggles between my linux and windows machines. I'm really efficient with them on with KDE, but in windows I almost never bother with it because It ends up being more management than it's worth. Being able to control it with EG is going to seriously level the playing field. Because this is NOT ENOUGH SCREENS lolkgschlosser wrote: ↑Mon Jul 29, 2019 7:28 amI know they added the ability to set names to application views the build before last.
There's one in the back behind the mains I mostly teamviewer into, and I have a 3 way HDMI splitter velcro'ed for my raspberry pi station
- kgschlosser
- kgschlosser
I have been meaning too, I'll check it out.kgschlosser wrote: ↑Mon Jul 29, 2019 6:59 pmhttp://eventghost.net/forum/viewtopic.php?f=14&t=9135
ever looked at this?
sick! This is going to be so cool.
Incase anyone reading this is interested in this awesome project,
There is more conversation to see at this link on github.
https://github.com/DanEdens/Virtual_Des ... n/issues/1
-pops more popcorn furiously-
I'm learning a lot this is truly a gold mine.
- kgschlosser
glad to see you have found some entertainment. and educational entertainment at that!
