DLNA
Re: DLNA
Post by kgschlosser » Sat Aug 04, 2018 9:13 am
ok so you can give this a try and see if it works.
you are going to need to pass the full path and filename to current_media instead of a URL
this new script sets up an http server that should setup everything the device needs.
example of setting the media
current_media = r'c:\some_folder\some_avi_file.avi'
you need to make sure you put the r in the front or escape all of the backslashes
You can change the PORT to whatever port you want the server to listen on.
import re
import socket
import threading
from contextlib import contextmanager
from urllib2 import urlopen
import mimetypes
import os
import SimpleHTTPServer
import SocketServer
PORT = 8000
class DLNA(object):
    DIDL = '''<?xml version="1.0"?>
<DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:dc="http://purl.org/dc/elements/1.1/">
<item id="{id}" parentID="{parent_id}" restricted="0">
    <dc:title>{title}</dc:title>
    <dc:creator>{creator}</dc:creator>
    <upnp:class>{klass}</upnp:class>
    <res protocolInfo="http-get:*:{mime_type}:*">{url}</res>
</item>
</DIDL-Lite>
    PORT = PORT
    SSDP_GROUP = ("239.255.255.250", 1900)
    URN_AVTransport = "urn:schemas-upnp-org:service:AVTransport:1"
    URN_AVTransport_Fmt = "urn:schemas-upnp-org:service:AVTransport:{0}"
    URN_RenderingControl = "urn:schemas-upnp-org:service:RenderingControl:1"
    URN_RenderingControl_Fmt = "urn:schemas-upnp-org:service:RenderingControl:{0}"
    SSDP_ALL = "ssdp:all"
    class Handler(SimpleHTTPServer.SimpleHTTPRequestHandler):
        file_path = ''
        def do_HEAD(self):
            self.send_response(200)
            self.send_header('contentFeatures.dlna.org', '*')
            self.send_header('transferMode.dlna.org', 'Streaming')
            self.send_header('Accept-Ranges', 'bytes')
            self.send_header('Cache-Control', 'no-cache')
            self.send_header("Content-type", self.guess_type(self.file_path))
            self.send_header("Content-Length", os.path.getsize(self.file_path))
            self.end_headers()
            self.copyfile(open(self.file_path, 'rb'), self.wfile)
    def get_device(self, device):
        return self[device]
    def __iter__(self):
        for device in self._devices:
            yield device
    def __contains__(self, item):
        return self[item] is not None
    def __getitem__(self, item):
            if item in (device.name, device.ip):
                return device
        return None
    def __init__(self):
        self._devices = []
        def do():
            self.discover(timeout=10)
        t = threading.Thread(target=do)
        t.daemon = True
        t.start()
    def discover(self, timeout=1, st=SSDP_ALL, mx=3, ssdp_version=1):
        """ Discover UPnP devices in the local network.
        name -- name or part of the name to filter devices
        timeout -- timeout to perform discover
        st -- st field of discovery packet
        mx -- mx field of discovery packet
        return -- list of DlnapDevice
        st = st.format(ssdp_version)
        payload = "\r\n".join([
            'M-SEARCH * HTTP/1.1',
            'User-Agent: EventGhost/0.5',
            'HOST: {0}:{1}'.format(*DLNA.SSDP_GROUP),
            'Accept: */*',
            'MAN: "ssdp:discover"',
            'ST: {0}'.format(st),
            'MX: {0}'.format(mx),
        sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
        sock.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
        sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
        sock.settimeout(timeout)
        sock.bind((socket.gethostbyname(socket.gethostname()), 1025))
        for _ in range(3):
            sock.sendto(payload, DLNA.SSDP_GROUP)
        try:
            while True:
                data, addr = sock.recvfrom(1024)
                if DLNA.URN_AVTransport in data or DLNA.URN_RenderingControl in data:
                    d = self.DlnapDevice(data, addr[0])
                    d.ssdp_version = ssdp_version
                    if d not in self._devices:
                        self._devices.append(d)
        except socket.timeout:
            pass
        finally:
            try:
                sock.close()
            except socket.error:
                pass
    class DlnapDevice:
        def __init__(self, raw, ip):
            self.ip = ip
            self.ssdp_version = 1
            self.port = None
            self.name = 'Unknown'
            self.control_url = None
            self.rendering_control_url = None
            self.has_av_transport = False
            self.__raw = raw.decode()
            self.location = DLNA._get_location_url(self.__raw)
            self.port = DLNA._get_port(self.location)
            raw_desc_xml = urlopen(self.location).read().decode()
            self.__desc_xml = DLNA._xml2dict(raw_desc_xml)
            self.name = DLNA._get_friendly_name(
                self.__desc_xml
            self.control_url = DLNA._get_control_url(
                self.__desc_xml,
            self.rendering_control_url = DLNA._get_control_url(
                self.__desc_xml,
            self.has_av_transport = self.control_url is not None
        def __repr__(self):
            return '{0} @ {1}'.format(self.name, self.ip)
        def __eq__(self, d):
            return self.name == d.name and self.ip == d.ip
        def _payload_from_template(self, action, data, urn):
            """ Assembly payload from template.
            fields = ''
            for tag, value in data.items():
                fields += '<{tag}>{value}</{tag}>'.format(tag=tag, value=value)
            payload = """<?xml version="1.0" encoding="utf-8"?>
             <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                <s:Body>
                   <u:{action} xmlns:u="{urn}">
                      {fields}
                   </u:{action}>
                </s:Body>
             </s:Envelope>""".format(action=action, urn=urn, fields=fields)
            return payload
        def _create_packet(self, action, data):
            """ Create packet to send to device control url.
            action -- control action
            data -- dictionary with XML fields value
            if action in ["SetVolume", "SetMute", "GetVolume"]:
                url = self.rendering_control_url
                urn = DLNA.URN_RenderingControl_Fmt.format(self.ssdp_version)
                url = self.control_url
                urn = DLNA.URN_AVTransport_Fmt.format(self.ssdp_version)
            payload = self._payload_from_template(action=action, data=data,
                urn=urn)
            packet = "\r\n".join([
                'POST {} HTTP/1.1'.format(url),
                'Accept: */*',
                'Content-Type: text/xml; charset="utf-8"',
                'HOST: {0}:{1}'.format(self.ip, self.port),
                'Content-Length: {0}'.format(len(payload)),
                'SOAPACTION: "{0}#{1}"'.format(urn, action),
                'Connection: close',
                payload,
            return packet
        def guess_type(self, path):
            if not mimetypes.inited:
                mimetypes.init()
            base, ext = os.path.splitext(path)
            if ext in mimetypes.types_map:
                return mimetypes.types_map[ext]
            return ''
        @property
        def current_media(self):
            return self.media_info
        @current_media.setter
        def current_media(self, path):
            """ Set media to playback.
            url -- media url
            instance_id -- device instance id
            DLNA.Handler.file_path = path
            id = 1
            parent_id = 1
            mime_type = self.guess_type(path)
            if mime_type.startswith('audio'):
                klass = 'object.item.audioItem.musicTrack'
                klass = 'object.item.videoItem'
            title = os.path.splitext(os.path.split(path)[1])[0]
            creator= 'None'
            url = 'http://{host}:port/file_name'.format(
                host=socket.gethostbyname(socket.gethostname()),
                port=PORT,
                file_name=os.path.split(path)[1]
            packet = self._create_packet(
                'SetAVTransportURI',
                dict(
                    InstanceID=0,
                    CurrentURI=url,
                    CurrentURIMetaData=DLNA._escape_xml(DLNA.DIDL.format(
                        url=url,
                        klass=klass,
                        mime_type=mime_type,
                        title=title,
                        creator=creator,
                        id=id,
                        parent_id=parent_id
            DLNA._send_tcp((self.ip, self.port), packet)
        def play(self):
            """ Play media that was already set as current.
                'Play',
                dict(InstanceID=0, Speed=1)
        def pause(self):
            """ Pause media that is currently playing back.
                'Pause',
        def stop(self):
            """ Stop media that is currently playing back.
                'Stop',
        def seek(self, position):
            Seek position
                'Seek',
                dict(InstanceID=0, Unit='REL_TIME', Target=position)
        @property
        def volume(self):
                'GetVolume',
                dict(InstanceID=0, Channel='Master')
            return DLNA._send_tcp((self.ip, self.port), packet)
        @volume.setter
        def volume(self, volume=10):
                'SetVolume',
                dict(InstanceID=0, DesiredVolume=volume,
                    Channel='Master')
        @property
        def mute(self):
            return None
        @mute.setter
        def mute(self, value):
                'SetMute',
                dict(
                    InstanceID=0,
                    DesiredMute=str(int(value)),
                    Channel='Master'
        @property
        def info(self):
            """ Transport info.
                'GetTransportInfo',
                dict(InstanceID=0)
        @property
        def media_info(self):
            """ Media info.
                'GetMediaInfo',
                dict(InstanceID=0)
        @property
        def position_info(self):
            """ Position info.
                'GetPositionInfo',
                dict(InstanceID=0)
    @staticmethod
    def _get_tag_value(x, i=0):
        """ Get the nearest to 'i' position xml tag name.
        x -- xml string
        i -- position to start searching tag from
        return -- (tag, value) pair.
           e.g
              <d>
                 <e>value4</e>
              </d>
           result is ('d', '<e>value4</e>')
        x = x.strip()
        value = ''
        tag = ''
        # skip <? > tag
        if x[i:].startswith('<?'):
            i += 2
            while i < len(x) and x[i] != '<':
                i += 1
        # check for empty tag like '</tag>'
        if x[i:].startswith('</'):
            i += 2
            in_attr = False
            while i < len(x) and x[i] != '>':
                if x[i] == ' ':
                    in_attr = True
                if not in_attr:
                    tag += x[i]
                i += 1
            return (tag.strip(), '', x[i + 1:])
        # not an xml, treat like a value
        if not x[i:].startswith('<'):
            return ('', x[i:], '')
        i += 1  # <
        # read first open tag
        in_attr = False
            # get rid of attributes
            if x[i] == ' ':
                in_attr = True
            if not in_attr:
                tag += x[i]
            i += 1
        i += 1  # >
        # replace self-closing <tag/> by <tag>None</tag>
        empty_elmt = '<' + tag + ' />'
        closed_elmt = '<' + tag + '>None</' + tag + '>'
        if x.startswith(empty_elmt):
            x = x.replace(empty_elmt, closed_elmt)
        while i < len(x):
            value += x[i]
            if x[i] == '>' and value.endswith('</' + tag + '>'):
                # Note: will not work with xml like <a> <a></a> </a>
                close_tag_len = len(tag) + 2  # />
                value = value[:-close_tag_len]
                break
            i += 1
        return (tag.strip(), value[:-1], x[i + 1:])
    @staticmethod
    def _xml2dict(s, ignoreUntilXML=False):
        if ignoreUntilXML:
            s = ''.join(re.findall(".*?(<.*)", s, re.M))
        d = {}
        while s:
            tag, value, s = DLNA._get_tag_value(s)
            value = value.strip()
            isXml, dummy, dummy2 = DLNA._get_tag_value(value)
            if tag not in d:
                d[tag] = []
            if not isXml:
                if not value:
                    continue
                d[tag].append(value.strip())
                if tag not in d:
                    d[tag] = []
                d[tag].append(DLNA._xml2dict(value))
        return d
    s = """
       hello
       this is a bad
       strings
       <a any_tag="tag value">
          <b><bb>value1</bb></b>
          <b><bb>value2</bb> <v>value3</v></b>
          </c>
          <d>
             <e>value4</e>
          </d>
          <g>value</g>
       </a>
    @staticmethod
    def _xpath(d, path):
        """ Return value from xml dictionary at path.
        d -- xml dictionary
        path -- string path like root/device/serviceList/service@serviceType=URN_AVTransport/controlURL
        return -- value at path or None if path not found
        for p in path.split('/'):
            tag_attr = p.split('@')
            tag = tag_attr[0]
            if tag not in d:
                return None
            attr = tag_attr[1] if len(tag_attr) > 1 else ''
            if attr:
                a, aval = attr.split('=')
                for s in d[tag]:
                    if s[a] == [aval]:
                        d = s
                        break
                d = d[tag][0]
        return d
    running = False
    @staticmethod
    def _get_port(location):
        """ Extract port number from url.
        location -- string like http://anyurl:port/whatever/path
        return -- port number
        port = re.findall('http://.*?:(\d+).*', location)
        return int(port[0]) if port else 80
    @staticmethod
    def _get_control_url(xml, urn):
        """ Extract AVTransport contol url from device description xml
        xml -- device description xml
        return -- control url or empty string if wasn't found
        return DLNA._xpath(
            xml,
            'root/device/serviceList/service'
            '@serviceType={0}/controlURL'.format(urn)
    @staticmethod
    @contextmanager
    def _send_udp(to, packet):
        """ Send UDP message to group
        to -- (host, port) group to send the packet to
        packet -- message to send
        sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM,
            socket.IPPROTO_UDP)
        sock.sendto(packet.encode(), to)
        yield sock
        sock.close()
    @staticmethod
    def _escape_xml(xml):
        """ Replace escaped xml symbols with real ones.
        return xml.replace('<', '&lt;').replace('>', '&gt;').replace('"', '&quot;')
    @staticmethod
    def _unescape_xml(xml):
        return xml.replace('&lt;', '<').replace('&gt;', '>').replace('&quot;',
    @staticmethod
    def _send_tcp(to, payload):
        """ Send TCP message to group
        to -- (host, port) group to send to payload to
        payload -- message to send
        sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        sock.settimeout(5)
        data = ''
        try:
            sock.connect(to)
            sock.sendall(payload.encode('utf-8'))
            data = sock.recv(2048)
            data = DLNA._xml2dict(DLNA._unescape_xml(data), True)
            errorDescription = DLNA._xpath(
                data,
                's:Envelope/s:Body/s:Fault/detail/UPnPError/errorDescription'
            if errorDescription is not None:
                data = dict(
                    data=data,
                    error=errorDescription
            pass
        finally:
            try:
                sock.close()
                pass
        return data
    @staticmethod
    def _get_location_url(raw):
        """ Extract device description url from discovery response
        raw -- raw discovery response
        return -- location url string
        t = re.findall('\n(?i)location:\s*(.*)\r\s*', raw, re.M)
        if len(t) > 0:
            return t[0]
        return ''
    @staticmethod
    def _get_friendly_name(xml):
        """ Extract device name from description xml
        return -- device name
        name = DLNA._xpath(xml, 'root/device/friendlyName')
        return name if name is not None else 'Unknown'
    @staticmethod
    def _get_serve_ip(target_ip, target_port=80):
        """ Find ip address of network interface used to communicate with target
        target-ip -- ip address of target
        return -- ip address of interface connected to target
        s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
        s.connect((target_ip, target_port))
        my_ip = s.getsockname()[0]
        s.close()
        return my_ip
eg.globals.DLNA = DLNA()
def run(prt):
    eg.globals.DLNA.httpd = SocketServer.TCPServer(("", prt), eg.globals.DLNA.Handler)
    eg.globals.DLNA.httpd.serve_forever()
threading.Thread(target=run, args=(PORT,)).start()
holdestmade
Re: DLNA
Post by holdestmade » Mon Aug 06, 2018 9:37 am
Hi, still the same I'm afraid
I think I'm 7 hours in front of you so let me know when a good time and I'll look at installing Teamviewer
Thanks again
Re: DLNA
Post by kgschlosser » Mon Aug 06, 2018 10:39 am
you're in GB??
holdestmade
Re: DLNA
Post by holdestmade » Mon Aug 06, 2018 12:08 pm
Sure am
Re: DLNA
Post by kgschlosser » Mon Aug 06, 2018 6:57 pm
ok it is going to be a few days and I will touch base with you as to when i can do up a team viewer session.
holdestmade
Re: DLNA
Post by holdestmade » Tue Aug 07, 2018 10:11 am
Sure, no rush, Z-wave is more important !
Cheers
