Sending events from outside to EventGhost
eirik226
Re: Sending events from outside to EventGhost
Post by eirik226 » Fri Mar 02, 2018 2:31 pm
Just yell out if you need any help to set it up - the guide should be pretty easy to follow tho. As I said I think you'll need the chrome plugin for it and make sure it's allowed to run in the background. So if chrome is closed it still works. From there you'll have to send the events to EG - should be a setting inside the chrome extension.
