Windows Optimized Services
You can Post Talk Chat about anything here. Anything but religion/bullshit & politics/stupidity
Post by kgschlosser » Sat Sep 08, 2018 11:12 pm
I decided to share this tidbit of information on tweaking the windows services.
In most cases a user doe not need to have Windows running all sorts of programs. In order to reduce the memory footprint, as well as processor usage it is smart to clean out anything that is running.
Things like Windows firewall. this does not need to be running if you have a gateway(router) to the internet. as most of these already have it built in. the exception would be if you have people that use your network then you would want to keep it enabled.
There are loads of services like this that you don't need to have running all of the time.
It is also important to remove things like the google update service. this is not something that is needed. A user has the ability to click a button to see if there is a new version available and install it whenever they want. I always live by the saying "if it ain't broke then don't fix it." one of the reasons why I am still running Windows 7 and also why I have windows Update turned off.
You can also disable Windows defender if and only if you have something like U-Block Origin installed into your browser. and you have MalwareBytes also installed (without the bit that is always running). you simply run MalwareBytes once every other week or so to clean out any garbage that happens to get installed. You also have to put in there a little common sense also. before you click on any link for the first time. if you hover over it with you mouse on the bottom of the browser it is going to show you where that link is going. if you see hjggfdsf876bmm.ru/fgsduytfsd7sbmnb you want to avoide clicking on that link. the host/domain bits of a link (the bits before the first /) should always be human readable. meaning. they are a word. like Microsoft.com. or EventGhost.net. this was done so that we as humans could remember the web address easily. also steer clear of downloading any applications from any place other then the application developers website. places like softpedia, and sourceforge you want to steer clear of. These sites tend to wrap the authors original installer with their own installer that will want to install all kinds of crap. If you ever have an installer for an app ask you about installing any tool bars into your browser. do not exit the installer. go and kill the process instead. most times the simple thing like clicking the close button will install shit onto your machine.Same deal goes with websites. if you find yourself at a website that looks suspicious. or causes your browser to lockup kill the process for the browser. do not worry because if you kill the process when you load the browser again it will tell you that it crashed and ask which pages you want to load out of the ones that were loaded when the crash took place.
Services are also another mechanism that malware/viruses/spyware will use to infect your system. always have a look see at the path to the executable inside of the service properties. This is a really good indicator. If the manufacturer of a service states Microsoft. then the service had better be in a Microsoft created directory. like Windows, Office, Visual Studio.. you can have an infection that will change an existing service to a new file.
on my windows 7 x64 SP1 installation I have 40 processes running after boot and login. This should be a pretty good number to use for all windows version. since the "core" of windows has not change much between Vista to 10 The number of running processes should be close. There is really dumb services like DLNA for Windows Media Player. if you do not use it turn it off.
Oh.. i did want to make note of a really crafty mechanism that gets used by some of these software manufacturers.. Google is a good example. even if you stop, disable or delete a service it will mysteriously reappear. if this happen Microsoft Task scheduler is the place to look. there will usually be an entry in there that will check the service and start/enable/install the service if it has been tampered with.
But I figured I would also share some service tweaking.
There will be 3 posts that follow. they are going to be extremely long posts. they are going to show 3 different Windows versions.
Windows 7
Windows 8.1
Windows 10
they will show the default system installed services. it will show the actual service name and it is going to show the default service startup if applicable for a specific windows edition of that version.
It is then going to show safe settings tweak settings. and for a windows & installation a bare-bones setup.
Before you make any changes please read the following
READ THIS
IT WILL SAVE YOU FROM A SYSTEM CRASH
STEP 1. (DO NOT SKIP THIS STEP)
go into your system properties dialog. Start --> Right click Computer --> Properties
in the window that opens click on Advanced system settings on the left. and under the Startup and Recovery section click on the Settings button.
Here there are 2 check boxes we are interested in they are in the System failure section.
Check - Write an event to the system log.
Uncheck - Automatically restart.
What the above does is. if you system gets a BSOD. it WILL NOT restart the computer. it will leave the BSOD on the screen.
IMPORTANT: Once you make a change you will want to reboot the computer.
**** DO NOT LOGIN.*****
let the computer sit for a bit. make sure the HDD activity is extremely low or none at all. look at the HDD activity light on the computer. Or wait 3 minutes if you do not have a light. This is going to insure that all services have started.
If you encounter a BSOD at this point it is going to be because of a change that was made. This is where disabling the restart on system failure comes into play.
If that BSOD occurs you are going to manually restart the computer. once it starts to boot.. tap the F8 key (windows boot modes, also called the "safe mode menu"). keep tapping it until the menu opens up. scroll down the menu to the "Last Known Good Configuration" option. this is the one we are going to use. It is going to return any changes made back to what they were before your last login. any system changes made to a PC do not actually get save until you restart and login again. That is the reason why i told you to not login until the HDD activity slows. usually 3 minutes at most we want to make sure that everything has loaded properly without error. and if an error comes up because we have not logged in we are able to reset everything back to what it was.
Nifty trick eh?
It is always good to leave that automatic restart on failure turned off. Even been at a login prompt and you could swear you were logged in?? this is most likely the culprit. unless you go digging through your event logs you have no other way of knowing that a system failure occurred. and in order to get to the eventlog you have to login. once you login the Last Known Good Configuration will not correct the issue. Kind of a goofy setup if you ask me. So it is best to have it stay at the BSOD so you now have a mechanism to fix the issue available to you.. One that actually works, not like the System Restore (I have never had it actually work).
if you delete service files form the system it is going to cause all kinds of other problems. if another service depends on the one you deleted you can have a pretty nasty cascading failure.
If you by chance have some kind of a service that is "suck" or you cannot make any changes to. be sure you always use Run as Administrator for a command prompt and use the sc module to manipulate the service. If a service is being a pecker. and didn't get deleted when you uninstalled the application it belongs to. Or you simply do not want it in there.. (the google update service). use the sc command to remove it. do not delete the executable
sc stop gupdate
sc delete gupdate
when deleting a service you need to make sure the service is in a stopped state. otherwise it will mark it for deletion. which means the service will not actually get deleted until the system reboots. if you stop the service first. it will delete it.. deleting a service using sc only removes the registry keys for the service. it does not remove any files. Which is a good thing because if you delete a file Last Known Good Configuration will not restore files, only changes made to the system. removing registry keys is a system change and can be reversed so long as the service executable exists on the system
This is a really good lesson in how to customize your system reducing your risk to almost 0. I know we have all made some kind of an error that forced us to have to install windows all over again. This is a really good way to protect from having to do that if you make a change that boogers up the system.
you can use msconfig to display all of the services. there is an option to hide all Microsoft services. Then it will display only 3rd party apps. these are simple to deal with. You will open a command prompt with elevated privileges(Run as Administrator). then type in
net STOP "THE_SERVICE_NAME"
be sure to keep the quotes in place
and if by chance there is an issue stopping it. you can change the service restart parameters. and kill the task
to change the service restart params you are first going to need to find out what they are so you can return them back to what they were.
so you would run this command
leaving the quotes in place
sc qfailure "SOME_SERVICE_NAME"
the response would be something similar to
SERVICE_NAME: WMPNetworkSvc
        RESET_PERIOD (in seconds)    : 86400
        REBOOT_MESSAGE               :
        COMMAND_LINE                 :
        FAILURE_ACTIONS              : RESTART -- Delay = 20000 milliseconds.
                                       RESTART -- Delay = 30000 milliseconds.
                                       RESTART -- Delay = 40000 milliseconds.
the command you would key in to disable the restart of the service is.
sc failure "SOME_SERVICE_NAME" reset= 0 reboot= "" command= "" actions= 0/0/0/0/0/0
and then kill the process. the process name should be the same as the service name. then check and see if the problem persists. if not you now know what service it is.
now we want to set the failure back to what it was. the actions represent the FAILURE_ACTIONS section of the query. If you do not see the FAILURE_ACTIONS section then enter actions= 0/0/0/0/0/0
there are 3 actions to set. each representing what to do for the first, second and third time the service has failed within the RESET_PERIOD given
each action set is separated by a "/" before the "/" is the action type and after the "/" is the delay time in seconds before performing the action.
to break it down
RESTART -- Delay = 40000 milliseconds = restart/40000
Each action_type / delay is separated by a "/" as well
so we can see there are 3 actions to perform
and this would be how you format it.
restart/20000/restart/30000/restart/40000
if you only see 2 items listed simply swap out the missing action/delay with 0/0
becomes
restart/20000/restart/30000/0/0
represents the action type and the delay time. the available action types are
0 = no action to perform
restart = restart the service
run = run a program from a command line
reboot = reboot the computer
you should know which one to use from the query.
Now I know this can be done using the properties of a service in the service manager. BUT.... you are not able to set seconds. only minutes.
so 30000 = 30 seconds. you cannot make this change in that properties dialog.
You basically want to duplicate everything you see in the qfailure (query failure settings)
RESET_PERIOD = reset
REBOOT_MESSAGE = reboot
COMMAND_LINE = command
FAILURE_ACTIONS = actions
be sure to wrap the value for reboot and command in double quotes. and if the item is blank then put in "" for it.
IMPORTANT: you MUST have a space between the = and the new value. actions= 0/0 or command= ""
sc failure "SOME_SERVICE_NAME" reset= 86400  reboot= "" command= "" actions= restart/30000/restart/30000/restart/30000
once you have located the service causing the issue and you have set the failure actions back to what they were. you are going to need to disable the service.
DO NOT DELETE THE SERVICE EXECUTABLE FROM YOUR FILE SYSTEM.
if disabling the service causes some kind of an issue you will be able to restore the settings.
sc config "SOME_SERVICE_NAME" start= disabled
You can greatly improve the performance as well as the startup time on your computer by tweaking the startup options. and what services are running.
I am always going to suggest you learn by installing your version of Windows into a virtual box. and mess around with it that way. we do not want you to have a crash of your production machine. The above instructions for avoiding the need to do a complete reinstall works extremely. I personally have never had it not work. so long as you follow the directions. You need to fully understand that it will only work if you DO NOT login again. Every system is different and is going to have different needs. This information is to provide you with some additional knowledge that will help in getting better operating system performance.
I run what I call Windows Thin PC x64 (and extremely lightweight Windows 7 x64). Microsoft made a 32 bit version that you couldn't do a whole lot on. The version I have made up uses less then 1 gig of memory and has about a 10 gig storage footprint. it has less then 40 processes running out of boot. put that onto a 6 core 3.2 ghz box with 16 GB of memory with an SSD. it fairs pretty well in the performance department.
and the next 3 posts are going to be very long.
Re: Windows Optimized Services
Post by kgschlosser » Sat Sep 08, 2018 11:14 pm
  • Windows 7 SP1
    • ActiveX Installer (AxInstSV)
      • Edition Default Setting
        • Starter: Manual
        • Home Basic: Manual
        • Home Premium: Manual
        • Professional: Manual
        • Ultimate: Manual
        • Enterprise: Manual
      • Performance Tune Setting
        • Safe: Manual
        • Tweaked: Disabled
        • Bare-Bones: Disabled
    • Adaptive Brightness (SensrSvc)
        • Starter: Not Available
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Application Experience (AeLookupSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
        • Bare-Bones: Manual
    • Application Host Helper Service (AppHostSvc)
        • Starter: Not Installed (Automatic, Started)
        • Home Basic: Not Installed (Automatic, Started)
        • Home Premium: Not Installed (Automatic, Started)
        • Professional: Not Installed (Automatic, Started)
        • Ultimate: Not Installed (Automatic, Started)
        • Enterprise: Not Installed (Automatic, Started)
        • Safe: Not Installed
        • Tweaked: Not Installed
        • Bare-Bones: Not Installed
    • Application Identity (AppIDSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Application Information (Appinfo)
        • Starter: Manual (Started)
        • Home Basic: Manual (Started)
        • Home Premium: Manual (Started)
        • Professional: Manual (Started)
        • Ultimate: Manual (Started)
        • Enterprise: Manual (Started)
        • Safe: Manual
        • Tweaked: Manual
    • Application Layer Gateway Service (ALG)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Application Management (AppMgmt)
        • Home Basic: Not Available
        • Home Premium: Not Available
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • ASP.NET State Service (aspnet_state)
        • Home Premium: Not Installed (Manual)
        • Professional: Not Installed (Manual)
        • Ultimate: Not Installed (Manual)
        • Enterprise: Not Installed (Manual)
    • Background Intelligent Transfer Service (BITS)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Base Filtering Engine (BFE)
        • Starter: Automatic (Started)
        • Home Basic: Automatic (Started)
        • Home Premium: Automatic (Started)
        • Professional: Automatic (Started)
        • Ultimate: Automatic (Started)
        • Enterprise: Automatic (Started)
        • Safe: Automatic
        • Tweaked: Automatic
    • BitLocker Drive Encryption Service (BDESVC)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Block Level Backup Engine Service (wbengine)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Bluetooth Support Service (bthserv)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • BranchCache (PeerDistSvc)
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Certificate Propagation (CertPropSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Client for NFS (NfsClnt)
        • Professional: Not Available
    • CNG Key Isolation (KeyIso)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • COM+ Event System (EventSystem)
        • Safe: Automatic
        • Bare-Bones: Automatic
    • COM+ System Application (COMSysApp)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Computer Browser
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Credential Manager (VaultSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Cryptographic Services (CryptSvc)
        • Safe: Automatic
    • DCOM Server Process Launcher (DcomLaunch)
        • Safe: Automatic
    • Desktop Window Manager Session Manager (UxSms)
        • Safe: Automatic
    • DHCP Client (Dhcp)
        • Safe: Automatic
    • Diagnostic Policy Service (DPS)
        • Safe: Automatic
        • Tweaked: Disabled
    • Diagnostic Service Host (WdiServiceHost)
        • Safe: Manual
        • Tweaked: Disabled
    • Diagnostic System Host (WdiSystemHost)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Disk Defragmenter (defragsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Distributed Link Tracking Client (TrkWks)
        • Safe: Disabled
        • Tweaked: Disabled
    • Distributed Transaction Coordinator (MSDTC)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • DNS Client (Dnscache)
        • Safe: Automatic
    • Encrypting File System (EFS)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Extensible Authentication Protocol (EapHost)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Fax
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
        • Bare-Bones: Uninstalled
    • Function Discovery Provider Host (fdPHost)
        • Safe: Manual
        • Tweaked: Disabled
    • Function Discovery Resource Publication (FDResPub)
        • Safe: Automatic
        • Tweaked: Disabled
    • Group Policy Client (gpsvc)
        • Safe: Automatic
    • Health Key and Certificate Management (hkmsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • HomeGroup Listener (HomeGroupListener)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • HomeGroup Provider (HomeGroupProvider)
        • Safe: Manual
        • Tweaked: Manual
    • Human Interface Device Access (hidserv)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • IIS Admin Service (IISADMIN)
        • Ultimate: Not Installed (Automatic)
    • IKE and AuthIP IPsec Keying Modules (IKEEXT)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Indexing Service (CISVC)
        • Enterprise: Not Installed (Started, Automatic)
    • Interactive Services Detection (UI0Detect)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Internet Connection Sharing (ICS) (SharedAccess)
        • Starter: Disabled
        • Home Basic: Disabled
        • Home Premium: Disabled
        • Professional: Disabled
        • Ultimate: Disabled
        • Enterprise: Disabled
        • Safe: Disabled
        • Tweaked: Disabled
    • IP Helper (iphlpsvc)
        • Safe: Disabled
        • Tweaked: Disabled
    • IPsec Policy Agent (PolicyAgent)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • KtmRm for Distributed Transaction Coordinator
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Link-Layer Topology Discovery Mapper (lltdsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • LPD Service (LPDSVC)
    • Media Center Extender Service (Mcx2Svc)
        • Safe: Disabled
        • Tweaked: Disabled
    • Message Queuing (MSMQ)
    • Message Queuing Triggers (MSMQTriggers)
    • Microsoft .NET Framework NGEN v2.0.50727 (clr_optimization_v2.0.50727)
        • Starter: Manual
        • Professional: Automatic (Delayed Start, Started
        • Ultimate: Manual
        • Enterprise: Automatic (Delayed Start, Started
        • Safe: Manual
        • Tweaked: Manual
    • Microsoft FTP Service (ftpsvc)
    • Microsoft iSCSI Initiator Service (MSiSCSI)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Microsoft Software Shadow Copy Provider (swprv)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Multimedia Class Scheduler (MMCSS)
        • Safe: Automatic
    • Net.Msmq Listener Adapter (NetMsmqActivator)
    • Net.Pipe Listener Adapter (NetPipeActivator)
    • Net.Tcp Listener Adapter (NetTcpActivator)
    • Net.Tcp Port Sharing Service (NetTcpPortSharing)
        • Starter: Disabled
        • Safe: Disabled
        • Tweaked: Disabled
    • Netlogon
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Network Access Protection Agent (napagent)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Network Connections (Netman)
        • Safe: Manual
        • Tweaked: Manual
    • Network List Service (netprofm)
        • Safe: Manual
        • Tweaked: Manual
    • Network Location Awareness (NlaSvc)
        • Safe: Automatic
    • Network Store Interface Service (nsi)
        • Safe: Automatic
    • Offline Files (CscService)
        • Safe: Disabled
        • Tweaked: Disabled
    • Parental Controls (WPCSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Peer Name Resolution Protocol (PNRPsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Peer Networking Grouping (p2psvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Peer Networking Identity Manager (p2pimsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Performance Logs & Alerts (pla)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Plug and Play (PlugPlay)
        • Safe: Automatic
    • PnP-X IP Bus Enumerator (IPBusEnum)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • PNRP Machine Name Publication Service (PNRPAutoReg)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Portable Device Enumerator Service (WPDBusEnum)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Power
        • Safe: Automatic
    • Print Spooler
        • Safe: Automatic
    • Problem Reports and Solutions Control Panel Support (wercplsupport)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Program Compatibility Assistant Service (PcaSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Protected Storage (ProtectedStorage)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Quality Windows Audio Video Experience (QWAVE)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Remote Access Auto Connection Manager (RasAuto)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Remote Access Connection Manager (RasMan)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Remote Desktop Configuration (SessionEnv)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Remote Desktop Services (TermService)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Remote Desktop Services UserMode Port Redirector (UmRdpService)
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Remote Procedure Call (RPC) (RpcSs)
        • Safe: Automatic
    • Remote Procedure Call (RPC) Locator (RpcLocator)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Remote Registry (RemoteRegistry)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • RIP Listener (iprip)
    • Routing and Remote Access (RemoteAccess)
        • Starter: Disabled
        • Safe: Disabled
        • Tweaked: Disabled
    • RPC Endpoint Mapper (RpcEptMapper)
        • Safe: Automatic
    • SeaPort
    • Secondary Logon (seclogon)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Secure Socket Tunneling Protocol Service (SstpSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Security Accounts Manager (SamSs)
        • Safe: Automatic
    • Security Center (wscsvc)
        • Starter: Automatic (Delayed Start, Started)
        • Home Basic: Automatic (Delayed Start, Started)
        • Home Premium: Automatic (Delayed Start, Started)
        • Professional: Automatic (Delayed Start, Started)
        • Ultimate: Automatic (Delayed Start, Started)
        • Enterprise: Automatic (Delayed Start, Started)
        • Safe: Automatic (Delayed Start)
        • Tweaked: Automatic (Delayed Start)
    • Server (LanmanServer)
        • Safe: Automatic
    • Shell Hardware Detection (ShellHWDetection)
        • Safe: Automatic
    • Simple TCP/IP Services (simptcp)
    • Smart Card (SCardSvr)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Smart Card Removal Policy (SCPolicySvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • SNMP Service
    • SNMP Trap (SNMPTRAP)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Software Protection (sppsvc)
        • Bare-Bones: Automatic (Delayed Start)
    • SPP Notification Service (sppuinotify)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • SSDP Discovery (SSDPSRV)
        • Safe: Manual
        • Tweaked: Manual
    • Storage Service (StorSvc)
        • Ultimate: Not Available
        • Safe: Disabled
        • Tweaked: Disabled
    • Superfetch (SysMain)
        • Safe: Automatic
    • System Event Notification Service (SENS)
        • Safe: Automatic
    • Tablet PC Input Service (TabletInputService)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Task Scheduler
        • Safe: Automatic
    • TCP/IP NetBIOS Helper (lmhosts)
        • Safe: Automatic
    • Telephony (TapiSrv)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Telnet (TlntSvr)
        • Starter: Not Installed (Disabled)
        • Home Basic: Not Installed (Disabled)
        • Home Premium: Not Installed (Disabled)
        • Professional: Not Installed (Disabled)
        • Ultimate: Not Installed (Disabled)
        • Enterprise: Not Installed (Disabled)
    • Themes
        • Safe: Automatic
    • Thread Ordering Server (THREADORDER)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • TPM Base Services (TBS)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • UPnP Device Host (upnphost)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • User Profile Service (ProfSvc)
        • Safe: Automatic
    • Virtual Disk (vds)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Volume Shadow Copy (VSS)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Web Management Service (WMSVC)
    • WebClient
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Audio (AudioSrv)
        • Safe: Automatic
    • Windows Audio Endpoint Builder (AudioEndpointBuilder)
        • Safe: Automatic
    • Windows Backup (SDRSVC)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Biometric Service (WbioSrvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows CardSpace (idsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Color System (WcsPlugInService)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Connect Now - Config Registrar (wcncsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Disabled
        • Tweaked: Disabled
    • Windows Defender (WinDefend)
    • Windows Driver Foundation - User-mode Driver Framework (wudfsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Error Reporting Service (WerSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Event Collector (Wecsvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Event Log (EventLog)
        • Safe: Automatic
    • Windows Firewall (MpsSvc)
        • Safe: Automatic
    • Windows Font Cache Service (FontCache)
        • Safe: Automatic (Delayed Start, Started)
        • Tweaked: Automatic (Delayed Start, Started)
        • Bare-Bones: Automatic (Delayed Start, Started)
    • Windows Image Acquisition (WIA) (StiSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Installer (msiserver)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Live Family Safety (fsssvc)
        • Starter: Not Installed (Manual)
        • Home Basic: Not Installed (Manual)
    • Windows Management Instrumentation (Winmgmt)
        • Safe: Automatic
    • Windows Media Center Receiver Service (ehRecvr)
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Media Center Scheduler Service (ehSched)
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Media Player Network Sharing Service (WMPNetworkSvc)
        • Home Basic: Manual (Startedl)
        • Safe: Disabled
        • Tweaked: Disabled
    • Windows Modules Installer (TrustedInstaller)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Presentation Foundation Font Cache 3.0.0.0 (FontCache3.0.0.0)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Process Activation Service (WAS)
        • Starter: Not Installed (Manual, Started)
        • Home Basic: Not Installed (Manual, Started)
        • Home Premium: Not Installed (Manual, Started)
        • Professional: Not Installed (Manual, Started)
        • Ultimate: Not Installed (Manual, Started)
        • Enterprise: Not Installed (Manual, Started)
    • Windows Remote Management (WS-Management) (WinRM)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Windows Search (WSearch)
        • Safe: Disabled
        • Tweaked: Disabled
    • Windows Time (W32Time)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Windows Update (wuauserv)
    • WinHTTP Web Proxy Auto-Discovery Service (WinHttpAutoProxySvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
    • Wired AutoConfig (dot3svc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • WLAN AutoConfig (Wlansvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • WMI Performance Adapter (wmiApSrv)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Manual
    • Workstation (LanmanWorkstation)
        • Safe: Automatic
    • World Wide Web Publishing Service (W3SVC)
    • WWAN AutoConfig (WwanSvc)
        • Starter: Manual
        • Ultimate: Manual
        • Safe: Manual
        • Tweaked: Disabled
Post by kgschlosser » Sat Sep 08, 2018 11:15 pm
  • Windows 8.1
        • Base: Manual
        • Safe: Manual
    • App Readiness (AppReadiness)
        • Base: Manual
        • Safe: Manual
        • Base: Manual (Trigger Start)
        • Professional: Manual (Trigger Start)
        • Enterprise: Manual (Trigger Start)
        • Safe: Manual
        • Base: Not Installed (Automatic, Started)
        • Safe: Manual
        • Base: Manual (Trigger Start, Started)
        • Professional: Manual (Trigger Start, Started)
        • Enterprise: Manual (Trigger Start, Started)
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • AppX Development Service (AppXSVC)
        • Base: Manual
        • Safe: Manual
        • Base: Not Available
        • Safe: Disabled
        • Base: Not Installed (Manual)
        • Base: Automatic (Delayed Start, Started)
    • Background Tasks Infrastructure Service (BrokerInfrastructure)
        • Base: Automatic (Started)
        • Safe: Automatic
        • Safe: Automatic
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Disabled
        • Safe: Disabled
        • Base: Manual
        • Safe: Disabled
    • Claims to Windows Token Service (c2wts)
        • Enterprise: Not Available
        • Safe: Disabled
        • Safe: Manual
        • Safe: Automatic
        • Base: Manual (Started)
        • Safe: Manual
    • Computer Browser
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Automatic
        • Safe: Automatic
    • Device Association Service (DeviceAssociationService)
        • Base: Automatic (Trigger Start, Started)
        • Professional: Automatic (Trigger Start, Started)
        • Enterprise: Automatic (Trigger Start, Started)
        • Safe: Automatic
    • Device Install Service (DeviceInstall)
        • Safe: Manual
    • Device Setup Manager (DsmSVC)
        • Safe: Manual
        • Safe: Automatic
        • Safe: Automatic
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Disabled
        • Base: Manual
        • Safe: Manual
        • Safe: Automatic
    • DS Role Server (DsRoleSvc)
        • Safe: Not installed
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • Family Safety (WPCSvc)
        • Base: Manual
        • Safe: Disabled
    • Fax
        • Base: Manual
        • Safe: Manual
    • File History Service (fhsvc)
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
    • Hyper-V Data Exchange Service (vmickvpexchange)
        • Safe: Disabled
    • Hyper-V Guest Service Interface (vmicguestinterface)
        • Safe: Disabled
    • Hyper-V Guest Shutdown Service (vmicshutdown)
        • Safe: Disabled
    • Hyper-V Heartbeat Service (vmicheartbeat)
        • Safe: Disabled
    • Hyper-V Remote Desktop Virtualization Service (vmicrdv)
        • Safe: Disabled
    • Hyper-V Time Synchronization Service (vmictimesync)
        • Safe: Disabled
    • Hyper-V Volume Shadow Copy Requestor (vmicvss)
        • Safe: Disabled
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Base: Disabled
        • Safe: Disabled
    • Internet Explorer ETW Collector Service (IEEtwCollectorService)
        • Base: Manual
        • Safe: Disabled
        • Safe: Disabled
        • Safe: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • Local Session Manager (LSM)
        • Safe: Automatic
    • Microsoft Account Sign-in Assistant (wlidsvc)
        • Safe: Manual
        • Base: Manual
        • Safe: Disabled
        • Base: Manual (Started at boot, then stops)
        • Professional: Manual (Started at boot, then stops)
        • Enterprise: Manual (Started at boot, then stops)
        • Safe: Manual
        • Safe: Automatic
        • Base: Disabled (Changed to Manual and Started if the previous 3 Services are installed)
        • Professional: Disabled (Changed to Manual and Started if the previous 3 Services are installed)
        • Enterprise: Disabled (Changed to Manual and Started if the previous 3 Services are installed)
        • Safe: Uninstalled
    • Netlogon
        • Base: Manual
        • Safe: Disabled
        • Base: Manual
        • Safe: Disabled
    • Network Connected Devices Auto-Setup (NcdAutoSetup)
        • Safe: Manual
    • Network Connection Broker (NcbService)
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • Network Connectivity Assistant (NcaSVC)
        • Safe: Manual
        • Safe: Manual
        • Safe: Automatic
        • Safe: Automatic
        • Safe: Disabled
    • Optimize Drives (defragsvc)
        • Base: Manual
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Manual
    • Power
        • Safe: Automatic
    • Print Spooler
        • Safe: Automatic
    • Printer Extensions and Notifications (PrintNotify)
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Base: Automatic
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Base: Manual (Maybe Started when using Remote Desktop)
        • Professional: Manual (Maybe Started when using Remote Desktop)
        • Enterprise: Manual (Maybe Started when using Remote Desktop)
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
        • Safe: Automatic
        • Base: Manual
        • Safe: Disabled
        • Base: Disabled
        • Safe: Disabled
        • Base: Disabled
        • Safe: Disabled
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Automatic
    • Sensor Monitoring Service (SensrSvc)
        • Safe: Disabled
        • Safe: Automatic
        • Safe: Automatic
        • Base: Disabled
        • Safe: Disabled
    • Smart Card Device Enumeration Service (ScDeviceEnum)
        • Safe: Disabled
        • Base: Manual
        • Safe: Disabled
    • SNMP Service
        • Base: Manual
        • Safe: Disabled
    • Spot Verifier (svsvc)
        • Safe: Manual
        • Safe: Manual
    • Still Image Acquisition Events (WiaRpc)
        • Base: Manual
        • Safe: Manual
        • Safe: Disabled
        • Safe: Automatic
        • Safe: Automatic
    • System Events Broker (SystemEventsBroker)
        • Safe: Automatic
    • Task Scheduler
        • Safe: Automatic
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
    • Telnet (TlntSvr)
        • Base: Not Installed (Disabled)
    • Themes
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
    • Time Broker (TimeBroker)
        • Safe: Manual
    • Touch Keyboard and Handwriting Panel Service (TabletInputService)
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • WebClient
        • Safe: Manual
        • Safe: Automatic
        • Safe: Automatic
        • Base: Manual
        • Safe: Disabled
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Disabled
    • Windows Connection Manager (Wcmsvc)
        • Safe: Automatic
    • Windows Defender Network Inspection Service (WdNisSvc)
        • Base: Manual
        • Safe: Manual
    • Windows Defender Service (WinDefend)
        • Safe: Automatic
        • Safe: Manual
    • Windows Encryption Provider Host Service (WEPHOSTSVC)
        • Safe: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
        • Safe: Automatic
        • Safe: Automatic
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • Windows Location Framework Service (lfsvc)
        • Safe: Disabled
        • Safe: Automatic
        • Base: Manual
        • Safe: Disabled (Uninstalled)
        • Base: Manual
        • Safe: Manual
        • Base: Not Installed (Manual, Started)
        • Base: Manual
        • Safe: Manual
    • Windows Store Service (WSService)
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • WLAN AutoConfig (WlanSvc)
        • Base: Manual (Automatic with Wireless Card Installed)
        • Professional: Manual (Automatic with Wireless Card Installed)
        • Enterprise: Manual (Automatic with Wireless Card Installed)
        • Safe: Manual
        • Base: Manual
        • Safe: Manual
    • Work Folders (workfolderssvc)
        • Base: Manual
        • Safe: Manual
        • Safe: Automatic
        • Base: Manual
        • Safe: Manual
Post by kgschlosser » Sat Sep 08, 2018 11:16 pm
  • Windows 10
        • Home: Manual
        • Safe Desktop: Manual
        • Safe Laptop/Tablet: Manual
        • Tweaked Desktop: Manual
        • Notes:
    • AllJoyn Router Service (AJRouter)
        • Home: Manual (Trigger Start)
        • Tweaked Desktop: Disabled
        • Notes:
        • Home: Manual
        • Notes:
        • Home: Not Installed
        • Safe Desktop: Not Installed
        • Safe Laptop/Tablet: Not Installed
        • Tweaked Desktop: Not Installed
        • Notes: If installed (Automatic, Running)
        • Notes:
        • Home: Manual (Trigger Start, Running)
        • Professional: Manual (Trigger Start, Running)
        • Notes:
        • Home: Manual
        • Safe Desktop: Disabled
        • Safe Laptop/Tablet: Disabled
        • Notes: Old functionality no longer needed.
        • Home: Not Available
        • Notes: Required for Group Policy software management
    • AppX Deployment Service (AppXSVC)
        • Home: Manual
        • Notes: Windows Store integration. Cannot be disabled via services.msc
    • AssignedAccessManager Service (AssignedAccessManagerSvc)
        • Notes:
        • Notes: If installed: (Manual)
    • Auto Time Zone Updater (tzautoupdate)
        • Home: Disabled
        • Notes:
    • AVCTP service (BthAvctpSvc)
        • Safe Desktop: Manual (Trigger Start)
        • Safe Laptop/Tablet: Manual (Trigger Start)
        • Notes: Do not disable if you are using Bluetooth Audio Device or Wireless Headphones.
        • Home: Manual or Automatic (Delayed Start, Running)
        • Professional: Manual or Automatic (Delayed Start, Running)
        • Safe Desktop: Automatic (Delayed Start)
        • Safe Laptop/Tablet: Automatic (Delayed Start)
        • Tweaked Desktop: Automatic (Delayed Start)
        • Notes: Manual or Automatic (Delayed Start, Running) depending on other optional services installed
        • Home: Automatic (Running)
        • Professional: Automatic (Running)
        • Notes: Cannot be disabled via services.msc
        • Notes: Do not disable due to Windows Firewall integration.
        • Notes: Do not disable if using storage encryption.
        • Home: Manual
        • Notes: Used by Windows Backup
    • Bluetooth Audio Gateway Service (BTAGService)
        • Notes: New. Wireless headsets.
        • Notes: Disable if no requirement for Bluetooth devices is desired.
    • Bluetooth User Support Service_????? (BluetoothUserService_?????)
        • Notes: New
        • Notes: Used by Windows Update for download sharing.
    • Capability Access Manager Service (camsvc)
        • Home: Manual
        • Notes:
    • CaptureService_?????
        • Notes: New. OneCore Capture Service.
        • Notes: Used with Smart Card login. No harm in keeping the default Manual mode.
        • Notes: Network File System Client available in Education/Enterprise versions.
    • Client License Service (ClipSVC)
        • Notes: Do not disable.
        • Home: Manual
    • Computer Browser
        • Notes: Network discovery of systems on local network.
    • Connected Device Platform Service (CDPSvc)
        • Home: Automatic (Delayed Start, Trigger Start)
        • Professional: Automatic (Delayed Start, Trigger Start)
        • Notes:
    • Connected Devices Platform User Service_????? (CDPUserSvc_?????)
        • Notes:
    • Connected User Experiences and Telemetry (DiagTrack)
        • Notes: Feedback and Diagnostics.
    • Contact Data_????? (PimIndexMaintenanceSvc_?????)
        • Home: Manual
    • CoreMessaging (CoreMessagingRegistrar)
        • Home: Manual
    • Data Sharing Service (DsSvc)
        • Notes:
    • Data Usage (DusmSvc)
        • Notes:
    • Delivery Optimization (DoSvc)
        • Home: Automatic (Delayed Start)
        • Professional: Automatic (Delayed Start)
        • Notes:
        • Notes:
        • Notes:
    • Device Management Enrollment Service (DmEnrollmentSvc)
        • Home: Manual
        • Notes:
        • Notes:
    • DevicePicker_27845 (DevicePickerUserSvc_27845)
        • Home: Manual
        • Notes: New. Cannot be disabled via services.msc
    • DevicesFlow_????? (DevicesFlowUserSvc_?????)
        • Home: Manual
    • DevQuery Background Discovery Broker (DevQueryBroker)
        • Notes:
    • Diagnostic Execution Service (diagsvc)
        • Notes:
        • Notes:
        • Home: Manual (Running)
        • Professional: Manual (Running)
        • Notes:
        • Home: Manual
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
    • dmwappushsvc
        • Notes:
        • Home: Automatic (Trigger Start, Running)
        • Professional: Automatic (Trigger Start, Running)
    • Downloaded Maps Manager (MapsBroker)
        • Notes: I do not use Windows/Bing maps. Google for the win here.
        • Safe Desktop: Not installed
        • Safe Laptop/Tablet: Not installed
        • Tweaked Desktop: Not installed
    • Embedded Mode (embeddedmode)
        • Notes:
    • Enterprise App Management Service (EntAppSvc)
        • Home: Manual
    • Extensible Authentication Protocol Service (EapHost)
        • Home: Manual
        • Notes:
    • Fax
        • Home: Manual
        • Safe Desktop: Uninstalled
        • Safe Laptop/Tablet: Uninstalled
        • Tweaked Desktop: Uninstalled
        • Notes:
        • Notes: Used by Windows Backup.
        • Home: Manual
        • Notes:
        • Notes:
    • GameDVR and Broadcast User Service_28eed (BcastDVRUserService_?????)
    • Geolocation Service (lfsvc)
        • Notes:
    • GraphicsPerfSvc
        • Notes:
        • Home: Automatic (Trigger Start)
        • Professional: Automatic (Trigger Start)
    • Host Network Service (hns)
    • Human Interface Device Service (hidserv)
        • Notes: Manufacture function keys generally on laptops for volume, screen brightness, etc.
    • HV Host Service (HvHost)
        • Notes:
        • Notes:
        • Notes:
        • Notes:
        • Notes:
    • Hyper-V Host Compute Service (vmcompute)
        • Notes: If installed: (Manual, Trigger Start, Running)
    • Hyper-V PowerShell Direct Service (vmicvmsession)
        • Notes:
        • Notes:
        • Notes:
    • Hyper-V Virtual Machine Management (vmms)
        • Professional: Not Installed (Automatic, Running)
        • Notes:
        • Notes:
        • Home: Not Installed (Automatic, Running)
        • Notes: Do not install.
        • Notes:
    • Infrared monitor service (irmon)
        • Home: Manual
        • Notes: File transfer via infrared devices.
        • Home: Manual
        • Notes:
        • Notes: Old service no longer needed.
        • Notes: IPv6 translation.
    • IP Translation Configuration Service (IpxlatCfgSvc)
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
    • Local Profile Assistant Service (wlpasvc)
        • Notes:
        • Notes:
    • LxssManager
        • Home: Not Installed (Manual)
        • Notes:
        • Notes:
        • Notes:
    • MessagingService_?????
        • Notes:
    • Microsoft (R) Diagnostics Hub Standard Collector Service (diagnosticshub.standardcollector.service)
        • Home: Manual
        • Notes:
        • Notes: Running if using MS account to log in to computer.
    • Microsoft App-V Client (AppVClient)
        • Notes:
        • Notes:
        • Home: Manual
        • Notes: Enable only if iSCSI device connectivity is required (rare for home user).
    • Microsoft Keyboard Filter (MsKeyboardFilter)
        • Home: Not Installed (Disabled)
        • Notes:
    • Microsoft Passport (NgcSvc)
    • Microsoft Passport Container (NgcCtnrSvc)
        • Home: Manual (Runningat boot, then stops)
        • Professional: Manual (Runningat boot, then stops)
    • Microsoft Storage Spaces SMP (smphost)
        • Home: Manual
        • Notes: Probably One Drive functionality.
    • Microsoft Store Install Service (InstallService)
        • Home: Manual
        • Notes:
    • Microsoft Windows SMS Router Service (SmsRouter)
        • Notes:
    • MultiPoint Repair Service (WmsRepair)
        • Notes: Leave Not Installed.
    • MultiPoint Service (Wms)
    • Natural Authentication (NaturalAuthentication)
        • Notes: Silly bio-metrics or face recognition login.
        • Home: Disabled (Changed to Manual and Running if the previous 3 Services are installed)
        • Professional: Disabled (Changed to Manual and Running if the previous 3 Services are installed)
    • Netlogon
        • Home: Manual
        • Notes: Used only with a domain controller environment.
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
        • Notes:
        • Notes:
        • Notes:
    • Network Setup Service (NetSetupSvc)
        • Notes:
        • Notes:
        • Notes:
    • OpenSSH Authentication Agent (ssh-agent)
        • Home: Manual
        • Notes: New.
        • Home: Manual
        • Notes:
    • Parental Controls (WpcMonSvc)
        • Home: Manual
        • Notes: New.
    • Payments and NFC/SE Manager (SEMgrSvc)
        • Notes: Near Field Communication is a mobile phone technology. Not needed on desktops and tablets.
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes:
    • Performance Counter DLL Host (PerfHost)
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes:
    • Phone Service (PhoneSvc)
        • Notes: Windows Phone Service.
        • Home: Manual
        • Notes:
        • Notes:
    • Power
        • Notes:
    • Print Spooler
        • Home: Manual
        • Notes:
    • PrintWorkflow_????? (PrintWorkflowUserSvc_?????)
        • Home: Manual
        • Home: Manual
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
    • Radio Management Service (RmSvc)
        • Home: Manual
        • Notes: Keep Manual for Mobile devices, Disabled stops all wireless communication, including Bluetooth and WiFi.
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes:
        • Home: Manual (Maybe Runningwhen using Remote Desktop)
        • Professional: Manual (Maybe Running when using Remote Desktop)
        • Notes:
        • Home: Manual (Maybe Running when using Remote Desktop)
        • Notes:
        • Notes:
        • Home: Manual
        • Notes: No function in Windows 10.
        • Home: Disabled
        • Notes:
    • Retail Demo Service (RetailDemo)
        • Home: Manual
        • Notes: Not disabled by default? Really?
        • Home: Disabled
        • Notes:
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes: SSTP VPN Capability.
        • Notes:
        • Home: Automatic (Delayed Start, Running)
        • Professional: Automatic (Delayed Start, Running)
        • Notes:
    • Sensor Data Service (SensorDataService)
        • Notes: Leave as default for laptops and tablets.
    • Sensor Service (SensorService)
        • Notes:
    • Shared PC Account Manager (shpamsvc)
        • Home: Disabled
        • Notes:
        • Notes: Autoplay
        • Notes: Keep Not Installed.
        • Home: Disabled
        • Notes: Not needed if Smart Card login is not in use.
        • Home: Manual
    • SNMP Service
        • Home: Manual
        • Notes:
        • Home: Automatic (Delayed Start,Trigger Start)
        • Professional: Automatic (Delayed Start,Trigger Start)
    • Spatial Data Service (SharedRealitySvc)
        • Home: Manual
        • Notes: Virtual Reality data manager.
        • Notes:
        • Notes: UPnP functionality. Possible security risk.
    • State Repository Service (StateRepository)
        • Home: Manual
        • Notes:
        • Notes: Required for Windows Store.
    • Storage Tiers Management (TieringEngineService)
        • Home: Manual
        • Notes:
        • Notes:
    • Sync Host_????? (OneSyncSvc_?????)
        • Notes:
        • Notes:
    • System Guard Runtime Monitor Broker (SgrmBroker)
        • Safe Desktop: Automatic (Delayed Start, Running)
        • Safe Laptop/Tablet: Automatic (Delayed Start, Running)
        • Tweaked Desktop: Automatic (Delayed Start, Running)
        • Notes: New.
    • Task Scheduler
        • Notes:
        • Home: Manual
        • Notes:
    • Themes
        • Notes:
        • Notes:
        • Notes: Keep in Manual for laptop touch screens and tablets.
    • Unified Write Filter Servicing Helper Service (UwfServcingSvc)
        • Notes: Keep Not Installed. If installed: (Disabled)
    • Update Orchestrator Service for Windows Update (UsoSvc)
        • Notes:
        • Home: Manual
        • Notes:
    • User Data Access_????? (UserDataSvc_?????)
    • User Data Storage_????? (UnistoreSvc_?????)
    • User Experience Virtualization Service (UevAgentService)
        • Notes:
    • User Manager (UserManager)
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes: Windows Backup.
    • W3C Logging Service (W3LOGSVC)
        • Notes: Keep Not Installed. If installed: (Manual)
    • WalletService
        • Home: Manual
        • Notes:
        • Notes:
    • WarpJITSvc
        • Notes:
    • Web Account Manager (TokenBroker)
        • Notes:
    • WebClient
        • Notes:
    • Wi-Fi Direct Services Connection Manager Service (WFDSConSvc)
        • Notes: Connect to wireless display.
        • Home: Manual
        • Notes:
    • Windows Camera Frame Server (FrameServer)
        • Notes: Could be needed to capture webcam frames.
        • Home: Manual
        • Notes:
        • Notes:
    • Windows Defender Advanced Threat Protection Service (Sense)
        • Notes:
    • Windows Defender Antivirus Network Inspection Service (WdNisSvc)
    • Windows Defender Antivirus Service (WinDefend)
    • Windows Defender Firewall (MpsSvc)
    • Windows Defender Security Center Service (SecurityHealthService)
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
        • Notes:
        • Notes:
        • Home: Manual
        • Notes:
    • Windows Insider Service (wisvc)
        • Notes: Disable if not beta testing new versions of Windows via the Insider program.
        • Home: Manual
    • Windows License Manager Service (LicenseManager)
        • Notes: Windows Store.
        • Notes:
        • Home: Manual
        • Safe Desktop: Disabled (Uninstalled)
        • Safe Laptop/Tablet: Disabled (Uninstalled)
        • Tweaked Desktop: Disabled (Uninstalled)
        • Notes:
    • Windows Mobile Hotspot Service (icssvc)
        • Notes: Mobile Network Connection (3G, 4G, LTE, Etc). Disable on devices without those options.
        • Home: Manual
        • Notes:
        • Notes:
        • Home: Not Installed (Manual, Running)
        • Professional: Not Installed (Manual, Running)
        • Notes:
    • Windows Perception Service (spectrum)
        • Notes: New Virtual Reality Service
    • Windows Push Notifications System Service (WpnService)
        • Notes:
    • Windows Push Notifications User Service_????? (WpnUserService_?????)
        • Notes:
    • Windows PushToInstall Service
        • Home: Manual
        • Notes: New.
        • Home: Manual
        • Notes:
        • Notes:
        • Notes:
    • Windows Update Medic Service (WaaSMedicSvc)
        • Home: Manual
        • Notes: New.
        • Notes:
        • Home: Manual
        • Notes:
        • Home: Automatic
        • Notes: Automatic with Wireless Card Installed.
        • Home: Manual
        • Notes:
        • Home: Manual
        • Notes:
        • Notes:
        • Notes: If installed: (Automatic, Running). Do not install.
        • Home: Manual
    • Xbox Accessory Management Service (XboxGipSvc)
        • Notes:
    • Xbox Game Monitoring (xbgm)
        • Notes: Cannot be disabled via services.msc, but will not trigger start if XBOX Live Auth is Disabled.
    • Xbox Live Auth Manager (XblAuthManager)
        • Home: Manual
        • Notes: Leave in Manual if using any XBOX console PC to Console functions.
    • Xbox Live Game Save (XblGameSave)
    • Xbox Live Networking Service (XboxNetApiSvc)
        • Home: Manual
richa
Post by richa » Thu Jul 04, 2019 8:32 am
thanks for sharing informative post.
Thank you :D
Post by kgschlosser » Thu Jul 04, 2019 5:20 pm
no worries m8. I know people get nervous about disabling stock windows services. This helps to ease that. It is also really good to know what services are "factory" there are some malicious programs that will install them selves as a service this makes it far easier to identify them.
here is a link to the sysinternals suite of system management programs.
https://docs.microsoft.com/en-us/sysint ... downloads/
There are several programs in that suite that I use quite often. This is the list of the ones that I use
PendMoves - This will tell you about any files that have a pending name change when the system reboots. I have found that the viruses and the like will use this to "hide" it's self. when there is an active rename scheduled to take place when the system reboots even if you delete the original file it will not remove the virus because it simply has renamed it's self. It took me a long while to figure out how to remove a virus on a machine because it was doing the rename thing. This is the utility that helped me locate the new name and then i was able to go into the registry and delete the the key that was set to do the rename.
ProcessExplorer - Task manager on steroids
AutoRuns - You have to be really really really careful using this tool. if you do something wrong most times it cannot be undone and sometimes will lead to an inoperable system. It is always wise to do a search on the internet first before making any changes to your system using this tool. But you can really trim down on memory and processor use using this tool.
My system is running a custom version of Windows 7. Microsoft had once released an OS called Windows Thin PC. most people have never heard of it. But it is a version of Windows that only has a 10GB disk footprint and uses only 600 MBish of ram and I think has only 30 processes running after boot. The issue was they thinned it out to much and you could not do a whole hell of a lot with it plus it was only 32 bit. I made a version of Windows that keeps most of the functionality of Windows but trims it down to using 12GB disk 750MB ram the same low processes at startup and it is 64 bit. I removed all of the crap that does not need to be there. like the 50+ drivers for dialup modems. and the plethora of multifunction printer drivers. All of the crap that that no one really uses. Why does Windows come prepackaged with 20 year old SCSI drivers for a home version of Windows? IDK but they are there..
Here is a did you know...
Did you know that when you plug a USB device into a port it installs a driver.. Bet you did.. Bet you didn't know this. If you plug that same device into a different USB port on the same machine.. It installs a second copy of the exact same driver that it installed when you plugged it into the first USB port. You probably didn't know this either.. when you unplug the device it does not uninstall the driver. That driver then loads each and every single time you start windows. Even tho it is not being used. There are 2 ways to go about seeing these drivers. One is when you are in the Device Manager. click on the view menu option and then click on "View hidden devices" the other is to use a program like USBDeview the latter being very handy. Both ways allows the removal of these "hidden" drivers
dan Edens
Post by dan Edens » Wed Jul 10, 2019 4:51 am
I gained soooooo much from thissssss thrreeeaaaaddddddd
Post by kgschlosser » Wed Jul 10, 2019 9:21 am
I only pretend to know what I am doing.
dan Edens
Post by dan Edens » Thu Aug 22, 2019 11:46 pm
So what I will absorb until i to am capable of pretend
pretend is super op
