Broadcaster: Broadcast action doesn't use default port
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
Boolean263
Post by Boolean263 » Thu Sep 28, 2017 1:04 am
Working away on documenting more plugins, I've gotten to Broadcaster. The Broadcast action is supposed to use the plugin's configured port (default of 33333) if the action is configured to use port 0. In practice, this doesn't seem to be happening.
I believe the bug is here:
    def bcastSend(self, eventString, payload="", port=0):
        if (port==None):
            sendToPort=self.plugin.port
            sendToPort=int(port)
The function's default port is 0, and 0 is also the value supplied by the configuration dialog by default. Thus port==None is never true (because 0 != None), so sendToPort will be set to 0, and never to self.plugin.port .
The easy fix is to change line 196 to `if (port==0):` , but some might say it's more "pythonic" to write something like this instead:
        sendToPort=int(port) if port else self.plugin.port
since port will be a True value as long as it's not 0, None, or False.
Again, I'm not sure if this bug is specific to the beta, but since I'm using the beta, it seems safer to report it here.
topix
Re: Broadcaster: Broadcast action doesn't use default port
Post by topix » Thu Sep 28, 2017 7:56 pm
From reading the source i think you're right. And i would also use sendToPort=int(port) if port else self.plugin.port.
In addition i would change line 216 from
def Configure(self, command="", payload="", port=""):
to
def Configure(self, command="", payload="", port=0):
Post by kgschlosser » Thu Sep 28, 2017 8:10 pm
I concur
