Bug when using a patch for Pause AutoScroll of the log Panel
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
Neytrino-OnLine
Post by Neytrino-OnLine » Tue Sep 12, 2017 8:51 am
Version: 0.5.0-rc4
File "C:\Program Files (x86)\EventGhost\eg\Classes\MainFrame\__init__.py", line 629, in OnIconize
self.Iconize(event.Iconized())
File "C:\Program Files (x86)\EventGhost\eg\Classes\MainFrame\__init__.py", line 554, in Iconize
self.document.HideFrame()
File "C:\Program Files (x86)\EventGhost\eg\Classes\Document.py", line 308, in HideFrame
if logCtrl.IsAutoscroll():
AttributeError: 'LogCtrl' object has no attribute 'IsAutoscroll
I try to use a patch from this topic, and get errors...
Sin©erely yours, Neytrino.
topix
Re: Bug when using a patch for Pause AutoScroll of the log P
Post by topix » Tue Sep 12, 2017 4:00 pm
This is not a bug of the RC4 it's 'bug' of the patch because it's for an older version. In RC4 we have pause mechanism for the log window: just scroll a few lines up and the log won't autoscroll anymore until you scroll all way down to the bottom of the log window.
Neytrino-OnLine
Post by Neytrino-OnLine » Wed Sep 13, 2017 3:45 pm
topix, thanks, I understand...
