[FIXED] EG RC3 wont restart itself
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
Diz
Post by Diz » Fri Jul 07, 2017 3:31 am
With EG RC3 when i select 'Restart' from the file menu EG just closes and doesnt restart.
Re: EG RC3 wont restart itself
Post by kgschlosser » Fri Jul 07, 2017 5:34 am
OoOOo good catch. I missed something with the changes to how EG starts up.. TY for catching this.
Post by kgschlosser » Fri Jul 07, 2017 5:58 am
if you want the attached file should fix the issue. save it to eg\classes
Diz
Post by Diz » Fri Jul 07, 2017 1:15 pm
yup that fixed it... glad i could help :)
Re: [FIXED] EG RC3 wont restart itself
Post by kgschlosser » Sat Jul 08, 2017 6:55 am
sweet. sorry i forgot about the restart in the menus. little overworked I think. there have been a couple of bug reports that have been fixed or are pending being added. But hopefully we will release an rc4 this weekend or early next week. depends on if we get any more bug reports in the next day or 2.
