Restore from tray icon bug
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
Post by kgschlosser » Sun Feb 19, 2017 4:54 pm
We are aware of the bug where the log is scrolled all the way to the top when you restore EventGhost from the system tray. this has been fixed and will be included in the next release. If you do not want to wait for the next release you can click the link below to obtain the updated version.. Remember this is a "work in progress" build and the version number will display as such. it is between EG versions this is the only largeish change that has been made since the release of beta6.
https://ci.appveyor.com/api/buildjobs/p ... _Setup.exe
