[FIXED] Empty Log
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
[FIXED] Empty Log
Post by kgschlosser » Wed Jan 04, 2017 6:20 pm
for those of you who love EG so much and don't want to wait for the next release and really want this Empty log issues fixed.
attached is the file that corrects this issue
You can simply download it and put it into this folder. you will overwrite the existing file and restart EG
c:\Program Files (x86)\EventGhost\eg\Classes\MainFrame
and for those of you that can wait. and don't want to tinker with the EG files. the bug fix will be in the next release of EventGhost
LogCtrl.py
(10.17 KiB) Downloaded 97 times
m19brandon
Re: [FIXED] Empty Log
Post by m19brandon » Mon Jan 09, 2017 4:26 am
The fix works without issue. Thanks for the early fix.
Post by kgschlosser » Fri Jan 13, 2017 9:25 am
not me it was topix that fixed it... I just thought for people that don't know about github or how to use it this would be easier for them if they wanted the fix now. instead of waiting until another release
