Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
egbaud
Post
by egbaud » Wed Jan 04, 2017 12:42 am
Version: 0.5 beta 5
Traceback: NONE
Event: NO EVENT
Description: When I "Show EventGhost", the log shows only entries that happened from that moment. If I show eventghost at 19:31:17, the first entry in the log is stamped 19:31:17. When I minimize EG then restore it, the same thing happens again: there are no log entries prior to the time at which I show the window.
This was not true of 0.5 beta 4. Other than that, EG seems to be working OK.
Except for the timestamps, this is what the log contains every time I show EG
20:02:06 20:02:06: 1 MainThread: Document.ShowFrame()
20:02:06 20:02:06: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
20:02:06 Task.Created.EventGhost
20:02:06 Task.NewWindow.EventGhost
20:02:06 Task.Deactivated.Desktop
20:02:06 Task.Activated.EventGhost
20:02:06 20:02:06: 1 MainThread: Document.ShowFrame => None
Post
by kgschlosser » Wed Jan 04, 2017 6:08 pm
We are aware of the issue and it has been corrected the Fix will be in the next version released. Thank You very much for the bug report and helping to make EG better. Look for the next release very soon.
If you like the work I have been doing then feel free to
