New AddEventDialog
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
New AddEventDialog
Post by Sem;colon » Sat Dec 31, 2016 2:45 pm
The new AddEventDialog is not working for me in EG 0.5 beta 5
-Here is the error when I open it:
15:20:15: 37 MainThread: Create(cls=<class 'eg.Classes.AddEventDialog.AddEventDialog'>)
15:20:15: 38 MainThread: AddEventDialog.ProcessingTask()
15:20:15: 38 MainThread: AddEventDialog.Configure(parent=<eg.Classes.MainFrame.MainFrame; proxy of <Swig Object of type 'wxFrame *' at 0x8ed0340> >)
15:20:15: 38 MainThread: AddEventDialog.__init__(style=536877120, id=-1, parent=<eg.Classes.MainFrame.MainFrame; proxy of <Swig Object of type 'wxFrame *' at 0x8ed0340> >, title='Add Event...')
15:20:15: 38 MainThread: AddEventDialog.__init__ => None
15:20:15: 38 MainThread: AddEventDialog.Affirmed()
15:20:15: 38 MainThread: AddEventDialog.FinishSetup()
15:20:15: 37 MainThread: Create => <eg.Classes.AddEventDialog.AddEventDialog; proxy of <Swig Object of type 'wxDialog *' at 0x8ef1a18> >
15:20:15: 37 MainThread: AddEventDialog.GetEvent()
Traceback (most recent call last) (0.5.0-beta5):
  File "C:\Program Files (x86)\EventGhost\eg\Classes\AddEventDialog.py", line 159, in OnExpanded
    self.tree.GetPyData(event.GetItem()).expanded = True
  File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginModuleInfo.py", line 81, in __setattr__
    "%s has no attribute %s" % (self.__class__.__name__, name)
AttributeError: PluginInstanceInfo has no attribute expanded
  File "C:\Program Files (x86)\EventGhost\eg\Classes\AddEventDialog.py", line 156, in OnCollapsed
    self.tree.GetPyData(event.GetItem()).expanded = False
-The OK button is grayed out if you try to enter en Event manually
-A Description for the input field where you actually see the Event would be nice (maybe above), it looks a search field currently
-The Hint is missing that you can use also drag and drop to add events
topix
Re: New AddEventDialog
Post by topix » Sun Jan 01, 2017 10:45 am
Sem;colon wrote:-The OK button is grayed out if you try to enter en Event manually
Did you hit Enter after typing the event name?
Sem;colon wrote:-A Description for the input field where you actually see the Event would be nice (maybe above), it looks a search field currently
The text in the textctrl is the event you will get. But i understand what you mean and will try to make it more visible.
Sem;colon wrote:-The Hint is missing that you can use also drag and drop to add events
:oops: Didn't knew or tested it 8)
topix
Post by topix » Sun Jan 01, 2017 2:06 pm
I made some enhancements to the dialog (https://github.com/EventGhost/EventGhost/pull/151):
Post by Sem;colon » Sun Jan 01, 2017 8:44 pm
topix wrote:I made some enhancements to the dialog (https://github.com/EventGhost/EventGhost/pull/151):
Thank you, looks good! :D
I have one question though, why isn't it possible to resolve the plugins the Events come from? Or better, how can the list be populated? At the moment there is only a System and a <unknown> node.
topix wrote:Did you hit Enter after typing the event name?
No I didn't... How should I know that I'm supposed to hit enter?
After hitting Enter the OK button isn't greyed out any more, but I honestly didn't expect that you have to press Enter - why is that? Wouldn't it be better to activate the button whenever the Box is not empty?
That's funny, I didn't know that as well :lol:
It's cool though and worth a hint.
I was referring to the Hint in the old add event dialog, which I guess is helpful to people that are new to EventGhost:
Post by kgschlosser » Mon Jan 02, 2017 6:34 am
can we also drag and drop events from the logger to populate the list in the dialog?? :-D
Post by Pako » Mon Jan 02, 2017 8:24 am
kgschlosser wrote:can we also drag and drop events from the logger to populate the list in the dialog??
What kind of question is that ?
Maybe, I did not understand it correctly.
However - the answer is: of course we can.
I've already used it in several plugins. As an example, I can give the Music Bee plugin (main plugin dialog) or Media Player Classic plugin (Show MPC menu action).
Post by kgschlosser » Fri Jan 13, 2017 9:37 am
@ Pako.
You cannot drag and drop events into the AddEvents Dialog. you can only drag and drop them into the tree.
this dialog right here
and also what is that menu control events assignment?? never seen that dialog before and i can't seem to locate where it is
topix
Post by topix » Fri Jan 13, 2017 5:54 pm
kgschlosser wrote:and also what is that menu control events assignment?? never seen that dialog before and i can't seem to locate where it is
Don't know what you mean "menu control events"? Can explain more?
Post by kgschlosser » Fri Jan 13, 2017 6:06 pm
look at the image in pako's post...
what is that and where is it??
topix
Post by topix » Fri Jan 13, 2017 6:09 pm
I think it will be one of:
Pako wrote:As an example, I can give the Music Bee plugin (main plugin dialog) or Media Player Classic plugin (Show MPC menu action).
Post by kgschlosser » Fri Jan 13, 2017 11:09 pm
i wasn't' understanding what he was saying then. I thought that was apart of the add events dialog
