Plugin Config Panels Not Scaled/Size Correctly
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
m19brandon
Post by m19brandon » Wed Dec 28, 2016 4:45 am
Version: 0.5 beta 4
No stack or traceback, see attached screenshot.
I believe this has always been an problem.
Steps to reproduce.
1. Change Windows default DPI to 150%, restart the PC.
2. Launch EG.
3. Load the Configuration Panel for any Plugin, It is not scaled correctly and there is no way to size the panel.
Note: ScheduleGhost's Weekly setting is a great example.
Re: Plugin Config Panels Not Scaled/Size Correctly
Post by Sem;colon » Wed Dec 28, 2016 11:38 am
SchedulGhost has even scaling problems at 100% DPI (EG 0.5 beta5)
Post by kgschlosser » Wed Dec 28, 2016 11:36 pm
Sem;colon wrote:SchedulGhost has even scaling problems at 100% DPI (EG 0.5 beta5)
i also came across the same problem in schedule ghost. I believe the issue to be in the new version of wx and not EG and scaling. i started looking at the code and made some changes It has something to do with hiding and showing of the widgets and the parent they are attached to I didn't get that far into it. maybe the parent is being hidden and the widgets aren't. don't know. that's just a poke at it. and schedule ghost does have some pretty complex code.
I never changed my dpi and this problem showed.
I haven't been able to find any other dialog that has the same issue.
Is there anywhere else where you have noticed this problem??
Post by Sem;colon » Sun Jan 01, 2017 8:54 pm
me not, maybe m19brandon?
Post by kgschlosser » Mon Jan 02, 2017 6:31 am
Either or.
I have only seen this problem in schedule ghost. i wanted to make sure i didn't run across it anywhere else before i put in a bug report to the schedule ghost thread.
Post by kgschlosser » Sun Feb 19, 2017 4:57 pm
Have we been able to nail down the source of the problem with this?? does it exist with more plugins then just scheduleghost?.
