Startup Error with NetUserGetLocalGroups RC5
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
eatmeimadanish
Post by eatmeimadanish » Thu Nov 29, 2018 4:03 pm
Version: 0.5.0-rc2
Unhandled exception in WorkerThread <EventThread>:
Callers stack:
File "wx\_core.pyc", line 8657, in MainLoop
File "wx\_core.pyc", line 7952, in MainLoop
Traceback (most recent call last) (0.5.0-rc5):
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 253, in __DoOneEvent
self.HandleAction(action)
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 140, in HandleAction
action()
File "C:\Program Files (x86)\EventGhost\eg\Classes\ThreadWorker.py", line 324, in __call__
File "C:\Program Files (x86)\EventGhost\eg\Classes\EventThread.py", line 75, in StartSession
actionThread.Func(actionThread.StartSession, 120)(filename)
File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionThread.py", line 107, in StartSession
IsLocalAdmin=User.IsLocalAdmin(),
File "C:\Program Files (x86)\EventGhost\eg\WinApi\User.py", line 80, in IsLocalAdmin
return 'Administrators' in Groups()
File "C:\Program Files (x86)\EventGhost\eg\WinApi\User.py", line 61, in Groups
return win32net.NetUserGetLocalGroups(server, user_name)
error: (2221, 'NetUserGetLocalGroups', 'The user name could not be found.')
Event:
The system generates no events since it fails to fully load.
Re: Startup Error with NetUserGetLocalGroups RC5
Post by kgschlosser » Fri Nov 30, 2018 6:10 am
it seems as tho there is an issue with your user account. can you try logging in with a different username and then run EG???
eatmeimadanish
Post by eatmeimadanish » Tue Dec 04, 2018 8:55 pm
This does not happen in RC4. I am logged in under my domain account, I tried other accounts and they do the same thing. It could be a group policy that blocks this kind of access, not sure. Either way, this error should be trapped and the new option skipped if it fails.
Pretty sure this is related to identifying the user account and creating an event that was added in RC5.
Post by kgschlosser » Wed Dec 05, 2018 12:03 am
we added a new feature to 0.5rc5 what it does it simply gets the user name from windows and check the groups for the user to see if one of them is Administrators.
That's it. So I am not sure what could be mucking up the works with it. I am logged into a domain as well and do not have this issue.
I can't think of anything offhand that would stop a user from checking the groups that actual user is in. I can't think of any kind of a GPO or Security parameter that would stop that. Now granted You can be stopped from opening up MMC or the users and groups applet. But you should always be able to check your own permissions.
I am gathering your are running Active Directory as well if you are logging into a domain. Is this a work PC? or do you have a PDC setup at your house? if it is the latter then I would assume that you have some sort of an administrative account. does it do the same thing with that account as well??
If EG is being used in a business environment that becomes a big snafu. I do not know how I could support the use of EG with really off the wall security changes in most cases. Unless you have Administrative rights I do not know how to go about finding out what the problem is.
The reason for this addition was for RDP issues and also so the user could have their tree do different things based on who is logged in.
eatmeimadanish
Post by eatmeimadanish » Thu Dec 06, 2018 3:23 pm
Changing User.py line from line 51 with the code fixed the issue.
def Groups(user_name=Name(), server=None):
    Retrieves direct and indirect group name the username is a member of for a
    specific computer/server. If no parameters are passed it will default to
    the current user and the local computer.
    :type user_name: str
    :type server: str
    :rtype: list
    try:
    except:
        return []
eatmeimadanish
Post by eatmeimadanish » Thu Dec 06, 2018 3:27 pm
This has an example of how to properly explore user groups. I modified it for EG.
https://programtalk.com/python-examples ... calGroups/
    :type server: str
    :rtype: list
    groups = []
    try:
        groups.extend(win32net.NetUserGetLocalGroups(server, user_name))
    except:
        pass
    try:
        groups.extend(win32net.NetUserGetGroups(server, user_name))
    except:
        pass
    return groups
Post by kgschlosser » Mon Dec 31, 2018 7:25 am
Sorry for not responding sooner. I wasn't ignoring ya at all. Been crazy busy and I hate to tell ya. i forgot about ya :shock: .
I would very much like it if you get the acknowledgement for finding/repairing this issue. I do know know if you know how to use GitHub, and if you don't if you are willing to learn. I would like it if you would submit a pull request (PR) for this bug fix. This way the history points to you as the person that discovered and repaired the problem.
The only thing we would have to make sure of is that it does not affect the event that gets generated when EG starts up. from looking at the code I do not believe it will But we need to check to be sure.
eatmeimadanish
Post by eatmeimadanish » Thu Jun 27, 2019 9:19 pm
Been a minute, just upgraded and forgot about this issue until I did. The problem is that in some cases the NetUserGetLocalGroups can't get a list of groups, probably a permissions issue.
Post by kgschlosser » Fri Jun 28, 2019 3:35 am
there has been a fix submitted to be added to the core. there has also been quite a but of discussion about it. I do not believe there is any kind of a permission setting that can lock a user from obtaining a list of the groups they are in. I think there may be a problem with pywin32 the module that is used to interface with Windows. we have discovered other issues in pywin32. I have been writing a pure python Windows API interface The whole Windows SDK actually. It is a pretty large undertaking but has given me a much better working knowledge of Windows. At some point I would like to remove the use of pywin32. my ultimate goal is to create a module that will work cross platform and provide an API that can be used no matter the OS that is being used.
