Error in log after system resume
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
Post by jonib » Sat May 05, 2018 4:28 pm
Version: 0.5.0-rc4
  File "threading.pyc", line 774, in __bootstrap
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\ThreadWorker.py", line 280, in __MainLoop
    self.__DoOneEvent()
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\ThreadWorker.py", line 261, in __DoOneEvent
    self.__PumpWaitingMessages()
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\ThreadWorker.py", line 287, in __PumpWaitingMessages
    while PeekMessage(byref(msg), 0, 0, 0, PM_REMOVE):
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\MessageReceiver.py", line 127, in WindowProc
    res = handler(hwnd, mesg, wParam, lParam)
  File "C:\Program Files (x86)\Utils\EventGhost\plugins\System\PowerBroadcastNotifier.py", line 234, in OnPowerBroadcast
    eg.actionThread.CallWait(eg.actionThread.OnComputerResume)
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\ThreadWorker.py", line 84, in CallWait
    return self.Func(func, timeout)()
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\ThreadWorker.py", line 131, in Wrapper
    eg.PrintStack()
  File "_ctypes/callbacks.c", line 315, in 'calling callback function'
  File "C:\Program Files (x86)\Utils\EventGhost\eg\Classes\ThreadWorker.py", line 132, in Wrapper
    raise Exception("Timeout while calling %s" % func.__name__)
Exception: Timeout while calling OnComputerResume
Description: When testing to send power on to my HDTV via the Pulse-Eight CEC+ plugin after a system resume I got this error.
topix
Re: Error in log after system resume
Post by topix » Sun May 06, 2018 8:27 am
When the system is resuming from sleep or hibernation EventGhost calls OnComputerResume on every plugin. So it looks like if some plugin isn't returning from that call, thus the timeout error.
Maybe the Pulse-Eight CEC+ plugin has a problem after system sleep. If you can reproduce the error, then please before sending the power on to your HDTV try stopping/starting the Pulse-Eight CEC+ plugin and/or EventGhost. (of course only to find the source of error, it shouldn't be the way for every day use)
Post by kgschlosser » Tue May 08, 2018 3:13 pm
This error should no longer show up as a traceback in the WIP versions of EG. This is a debugging message that will only show up when debugging is turned on. Once you turn it off this should go away.
If you read the traceback it's not a traceback per say. this line is the clue that it's not
eg.PrintStack()
it's a stack trace.
Post by jonib » Tue May 08, 2018 5:11 pm
OK
Post by kgschlosser » Tue May 08, 2018 6:35 pm
This specific problem shows up a lot. The whole system designed around the eg.MainMessageReceiver needs to be done over. The reason why is because what normally takes place is when a plugin starts either the already running message receiver is used or a new one is created but the message receiver in it's self runs in it's own thread. but the plugin was started in the Action Thread. and then the handle for the main message receiver is passed to the windows notification system while in the Action thread. and not in the thread the message receiver is running in. This causes all kinds of odd behavior.
newer versions of windows have become super sensitive to everything dealing with the windows notification system being handled by the same thread. and with windows it would be preferable if that thread is the min thread, issue there is wxPython takes over the main thread functions. so handling windows notifications in that thread is not something that can be done very easily.
addressing the power notifications it is not a great idea to stall the windows notification system waiting until the action thread finishes processing the state changes sent into the plugins.
This is one of those problems that the best solution is going to be a GUI/Service. where the service can do what it needs to do in the main thread. and the GUI can run wx in it's main thread.
