Virtual pictures
Post photos of your home automation. Have discussion about how you use EventGhost in your setup.
davidmark
Virtual pictures
Post by davidmark » Thu Nov 24, 2016 7:07 pm
Lots of captures of touch screen content here:
https://twitter.com/Cinsoft/media
Mostly generated by EventGhost and Tasker with a dash of IFTTT (it's mostly relegated to newsboy). GMail provides the Cloud services and its Web app is hacked to produced the final results. There's also an Alexa Web app hack (and associated Skill to mute confused responses) involved, which I'll post in the near future.
VoxCommand plays a small role as well, but only as I haven't had time to factor that PoS out of the system. Don't use the PC microphone for voice commands these days as the Alexa devices are much better listeners. And don't get me started on the VC app; replaced with Tasker voice commands on the mobile devices.
skribb
Re: Virtual pictures
Post by skribb » Fri Jan 06, 2017 6:40 pm
Wow, you use Gmail as an automation control panel? That's awesome. Is it the real gmail or a custom front end or something?
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
davidmark
Post by davidmark » Mon Jan 09, 2017 4:37 am
Thanks! It's the real deal. Just added a custom stylesheet with the Stylish extension for Chrome and a script with CJS.
https://chrome.google.com/webstore/deta ... cffe?hl=en
https://chrome.google.com/webstore/deta ... elnpjljija
There are many others that perform similar functions, but settled on those two a couple of years ago and they've done well.
Have started to compile the various bits that go into it, starting with the icons and CSS here:
https://github.com/david-mark/Funhouse
And as it is IMAP mail, the GMail client is not the only way to see my "log". Any IMAP client will do, though not with quite as much flair. Android notification shade, Mac Automator and the RSS Visualizer screen saver (with forwarding to a Google Group with RSS feed) are among other consumers of the data.
I like it as though Google can obviously read the text of my messages, their bots don't really know what it means. Most they will do with it is try to figure out ads to show me. Contrast with using something like Google Home or SmartThings where the 3rd party knows *exactly* what devices you have and what they (and you) are doing. Plus it's free for life. :)
Recommend Tasker and the Aqua Mail plug-in as another way to react to events. Also use Tasker to send entries straight to the "log" when away from my local network and Pushover to send a subset of events home to EG without using port forwarding. A homebody Android receives them and forwards on to EG over HTTP.
Also have very tight integration with Alexa and will post the JS I use for that when I get a chance. Will push to the above-mentioned repo as well. It runs atop the Alexa Web app, which also eliminates the need for port forwarding.
sofiabovino
Post by sofiabovino » Mon Oct 16, 2017 12:58 pm
But where is the pictures ?
zian
Post by zian » Mon Oct 16, 2017 1:30 pm
Did you click here?
Welcome to the forum Sofia.
Enjoy.
eventghost.net
Be there or be square.
