Webserver plugin & WebUI demo
Tutorials & Guides
yokel22
Post by yokel22 » Sun Dec 04, 2016 8:01 pm
This is another Webserver demo using jqueryMobile with a number of functions for communication with EventGhost.
1.) Extract the contents of the file WS - Demoshort.zip
2.) Open the EG.WS.demo.xml with EventGhost
3.) Open the Webserver Configuration and set the html root folder to the "WS-Demoshort" folder you created in step 1. You can also change the port number to your preffered port.
4.) Open your preferred web browser and navigate to your EventGhost's computer's "ip:port". Something similar to this "localhost:8080" or "192.168.1.156:5163".
The index.html page should explain how to go about using the functions. If not, just ask for more clarification. The Websocket functions were written by Pako and Sebastian. Many thanks to them for posting there examples. The script controlling these functions is the "script.js" included in the html/js folder. If you have your own html and jquery mobile files you can attach that script to the head section of your html. Also copy the "script.js" to your html folder.
WS - Demoshort.zip
(1.19 MiB) Downloaded 195 times
EG.WS.demoshort.xml
EventGhost Configuration:
(13.89 KiB) Downloaded 199 times
yokel22
Re: Webserver plugin & WebUI demo
Post by yokel22 » Sun Dec 04, 2016 8:38 pm
This is working page with several remotes(kodi,iTunes,Sonos), weather, calculator and other utilities for further example of how to go about using the functions. I've tested this about as well as I can, but there will likely be a few that I missed on my system. Thanks to "eirik226" for helping with the testing. If you get an error or something just isn't functioning properly, let me know and post a screenshot of the error if applicable.
1.) Follow all the steps from the post above.
3.) Open the kodi folder, then this macro "Set KodiArt Directory (EDIT THIS THEN RUN FIRST: Set to your "HTML/images/kodiart" folder)"
4.) Open the Webserver Action here "Webserver: Set persistent value: kodiartdirectory: D://WS - Demo/images/kodiart/" , set it to where the unzip "WS-Demo" folder is located. In my case it's the root of the D: drive. Then run the entire "Set KodiArt Directory (EDIT THIS THEN RUN FIRST: Set to your "HTML/images/kodiart" folder)" macro once.
5.) Open the xbmc2 plugin Configuration, set fields to match your kodi settings "listed under services in kodi". It should look similar to this. (make sure to enable events)
6.) Open the Suntracker plugin Configuration and set your location.
6.) If you want to use iTunes you will need to install the updated plugin attached below.
7.) If you are using Sonos, the event's will need to be changed to the events generated by your speakers.
A few screenshots.
Some of the less obvious buttons:
1.) Clicking on the kodi icon at the top will pull up this menu.
2.) Clicking on the cover art will pull up the current playlist.
3.) Clicking on the fanart within the current playlist will bring up controls to change items position.
4.) Clicking on one of the stars will set the rating to that value.
WS - Demo.zip
(14.81 MiB) Downloaded 178 times
EG.WS.demo.xml
(398.18 KiB) Downloaded 190 times
iTunes Updated Plugin:
(45.41 KiB) Downloaded 203 times
Reason: Moved files from dropbox to forum server
eirik226
Post by eirik226 » Sun Dec 04, 2016 9:33 pm
I have been testing this and learning from it for a while now. In my opinion this is very well done and I definitely recommend it. It shows how well and much eventghost can do! Gave me a smile on my face a few times.
+1 to yokel, and thank you for sharing! :)
topix
Post by topix » Wed Dec 07, 2016 4:18 pm
I didn't test it, maybe somewhere next year, but it looks promising. Thank you yokel22 for the effort and sharing your knowledge. :thumbsup:
Post by blaher » Fri Dec 09, 2016 12:31 am
Looks awesome, looking forward to giving it a try.
Thank you for sharing! :)
