The driver download is fixed.
Post by kgschlosser » Sun Apr 19, 2020 12:30 am
@Spross was kind enough to let me RDP into his computer so I could figure out what was wrong with the driver downloads. We figured out what it is. It was the dumbest thing you can imagine. The cause was the the lack of capitalization in a filename causing the problem. So the automatic installation of the drivers should be 100% functioning. If you are running Windows 10 you will still need to disable driver signing the directions are HERE
