New version 0.5.0-rc5 is out
topix
Post by topix » Sun Nov 25, 2018 12:17 pm
0.5.0-rc5 (2018-11-25)
Enhancements:
  • Add Event before the loading of the plugins. 277 (kdschlosser)
  • Trigger event Windows.User.USERNAME on EventGhost start 278 (kdschlosser)
  • Additional options for EventGhost.TriggerEvent (inspired by cobraman44) 279 (kdschlosser)
  • Appicon selection 283 (topic2k)
  • Enhancements to the output in the loglist (colours, icons) 285 (kdschlosser)
  • Add expand/collapse to toolbar, menu and context menu (config tree). 288 (topic2k)
  • NamedPipe.py: Add simultaneous connections 290 (kdschlosser)
  • Bring EG to front if it's only hidden behind other windows 292 (topic2k)
  • add an option to show date in log (requested by Snowbird) 302 (topic2k)
  • Fixes getting the default user language from the OS 325 (kdschlosser)
  • [PowerDVD] Update to work with newer PowerDVD versions (v12+) 330 (GruberMarkus)
Fixed bugs: Other changes: Download now
shayno
Re: New version 0.5.0-rc5 is out
Post by shayno » Mon Nov 26, 2018 9:45 am
Thanks for all the work you guys put into this... It's appreciated.
mbonaccors
Post by mbonaccors » Tue Nov 27, 2018 4:26 am
This is awesome - I use this every single day. Thank you!
farbox
Post by farbox » Wed Nov 28, 2018 4:48 pm
Thanks guys and a quick heads up for you:
Just updated to rc5, and Cybersight RansomStopper keeps flagging py.exe and pyw.exe, and sometimes the eventghost.exe as suspicious files, and quarantines them. Ive added the exceptions to my program, so it works ok....
Maybe you can report it to them as a false positive? I cant do it directly from their app.
topix
Post by topix » Wed Nov 28, 2018 6:41 pm
Maybe you can send them an email? With a link to our github download page?
farbox
Post by farbox » Wed Nov 28, 2018 11:10 pm
Email sent to support@cybersight.com !
