Use of Event wildcard in code ?
Snowbird
Post by Snowbird » Sat Dec 23, 2017 5:49 pm
I'm struggling a bit, I don't know how to use the wildcard with an event :
if eg.event.string == "System.PowerProfile.*" :
    my code here
I want it to match all these events :
System.PowerProfile.HighPerformance
System.PowerProfile.PowerSaver
System.PowerProfile.Balanced
I've checked the wiki but there's no mention about the use of wildcard directly in the code :
http://www.eventghost.net/mediawiki/ind ... _Events.29
how can I do this ?
Thank you
yokel22
Re: Use of Event wildcard in code ?
Post by yokel22 » Sat Dec 23, 2017 7:51 pm
I'm not sure if what you want is possible from script. You can use startswith() or the re module to accomplish this though.
string = "System.PowerProfile."
match = eg.event.string.startswith(string)
if match == True:
     # wildcard was met, execute code
     print 'wildcard'
Post by kgschlosser » Sun Dec 24, 2017 1:11 am
import fnmatch
if fnmatch.fnmatchcase(eg.event.string, 'Some.*.Event.?ame'):
    # do your code here
or this if you are looking for a specific phrase in the eg.event.string
if 'Some.Event' in eg.event.string:
    # do your code here
Snowbird
Post by Snowbird » Sun Dec 24, 2017 10:21 am
Thanks to both of you ;)
I picked kg method, it worked right away !
PS. Maybe it's worth adding this example in the wiki ? it could be helpful to others I think.
Merry X-mas everyone ! :)
