Check my script
jachin99
Check my script
Post by jachin99 » Tue Nov 21, 2017 5:18 pm
I've started attempting to create some python code that will control my XB1 via IR. I know there are errors in this but if someone who knows better happens to pass by this, please point out whatever obvious mistakes I have made. This is the kind of header file I will use for IR blasts, and when this is correct, I'll generate individual scripts that call these commands which can be added to macros. KG, this code started its life out as what you posted for my JVC TV. Thanks.
# Codes retrieved from: http://www.remotecentral.com/cgi-bin/mboard/rc-discrete/thread.cgi?7171,3
# Again, the Xbox command as a push and hold (xbox on...)
# will bring up the power window pop-up. sending a OK command will them power off the xbox.
class XB1(object):
 Power Toggle = (
 '0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 '
 '0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 '0689 0157 0056 0015 0E94 '
 Power On = (
 '0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 '
 '0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
 Power Off = (
 '0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 '
 '0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
 XBox = (
 '0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 '
 '0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 '
 One = (
 '0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Two = (
 '0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Three = (
 '0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Four = (
 '0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Five = (
 '0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Six = (
 '0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Seven = (
 '0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Eight = (
 '0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Nine = (
 '0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 Zero = (
 '0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
 //Volume_Up = (
 '0000 006d 0001 0011 0140 009e 0014 003c 0014 003c 0014 0014 0014 '
 '0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 003c '
 '0014 003c 0014 003c 0014 003c 0014 0014 0014 0014 0014 0014 0014 '
 '0379'
 //Volume_Down = (
 '0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 003c 0014 003c '
 '0379'
 //Mute = (
 '0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 '
 '0379'
 Up = (
 '0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
 Down = (
 '0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 00155 '
 '0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
 '0689 0157 0056 0015 0E94'
 Left = (
 '0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 '
 '0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
 Right = (
 '0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 '
 '0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
 A = (
 '0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 '
 '0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015'
 '0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 '
 '0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 '
 '067C 0156 0055 0015 0E4E '
 B = (
 '0000 006D 0022 0002 0155 00AC 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 '
 '0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 '
 '0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 '
 '0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 '
 '067D 0155 0055 0015 0E4E '
 X = (
 '0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
 '0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 '
 Y = (
 '0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 '
 '0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 '
 Left Bumper/Ch+ = (
 '0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 '
 '0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
 Right Bumber/CH = (
 '0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 '
 '0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
 Ok = (
 '0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 '
 '0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
eg.globals.XB1 = XB1
jachin99
Re: Check my script
Post by jachin99 » Tue Nov 21, 2017 6:17 pm
I'm sure it won't be too long before either A this problem gets solved an everything works OR B. this problem gets solved but all of the hex codes for XB1 have changed since 2015. With that being said, here is a complete list of the IR codes I have found, placed within my non working script header file
class XB1(object):
 Power Toggle = (
 Power On = (
 Power Off = (
 XBox = (
 One = (
 Two = (
 Three = (
 Four = (
 Five = (
 Six = (
 Seven = (
 Eight = (
 Nine = (
 Zero = (
 Up = (
 Down = (
 Left = (
 Right = (
 A = (
 B = (
 X = (
 Y = (
 Left Bumper/Ch+ = (
 Right Bumber/CH = (
 Ok = (
 Menu = (
'0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
'0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 '
Play = (
'0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Pause = (
'0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Play/Pause = (
'0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
'0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 '
FF = (
'0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
RW = (
'0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Stop = (
'0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Skip - /Left Trigger = (
'0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Skip +/Right Trigger = (
'0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Vol Up = (
'0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 '
'0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
Vol Dn = (
Mute = (
'0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 '
'0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 '
View = (
'0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
'0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 '
Eject = (
'0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 '
'0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
Re: Check my script
Post by kgschlosser » Mon Nov 27, 2017 1:01 am
class XB1(object):
    xbox = (
        '0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 0015 '
        '0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 '
        '0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 '
        '0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 '
        '0016 0015 0016 0015 0041 0015 0689 0157 0056 0015 0E94'
    ok = (
        '0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 '
        '0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 '
        '0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94'
    menu = (
        '0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 '
        '0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 '
    view = (
        '0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 '
        '0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 '
    class Power:
        toggle = (
            '0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 '
            '0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 '
            '0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 '
            '0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 '
            '0157 0056 0015 0E94'
        on = (
            '0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 '
            '0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 '
            '0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 '
        off = (
            '0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 '
            '0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 '
    class Number:
        one = (
            '0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 '
            '0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 '
        two = (
            '0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 '
        three = (
            '0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 '
        four = (
            '0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 '
        five = (
            '0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 '
        six = (
            '0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 '
        seven = (
            '0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 '
        eight = (
            '0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 '
            '0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 '
        nine = (
        zero = (
            '0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 '
    class Direction:
        up = (
            '0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 '
            '0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689 '
        down = (
            '0015 0016 0015 0016 00155 0016 0015 0016 0015 0041 0015 0016 '
            '0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 '
        left = (
            '0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 '
            '0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 '
        right = (
    class Button:
        a = (
            '0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 '
            '0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 '
            '0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 '
            '0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 '
            '0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 '
            '0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 '
            '0015 0015 0015 0040 0015 067C 0156 0055 0015 0E4E'
        b = (
            '0000 006D 0022 0002 0155 00AC 0015 0015 0015 0015 0015 0015 '
            '0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 '
            '0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 '
            '0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 067D '
            '0155 0055 0015 0E4E'
        x = (
            '0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 '
            '0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0689 '
        y = (
            '0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0689 '
    class Channel:
        up = (
            '0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 '
            '0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689 '
        down = (
            '0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 '
    class Media:
        play = (
            '0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 '
        pause = (
        pause_toggle = (
            '0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 '
            '0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0689 '
        fast_forward = (
        rewind = (
            '0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 '
        stop = (
            '0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 '
        previous = (
            '0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 '
        next = (
            '0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 '
        eject = (
    class Volume:
        down = (
            '0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 '
        up = (
        mute = (
            '0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 '
XB1.ok
XB1.Volume.down
XB1.Channel.up
XB1.Media.play
jachin99
Re: Check my script
Post by jachin99 » Mon Nov 27, 2017 7:26 pm
The most obvious difference is my indentation error but other than that and declaring a few separate classes, did you see any other problems?
Re: Check my script
Post by kgschlosser » Mon Nov 27, 2017 7:41 pm
the spaces at the end of the pronto code.
the spaces in the variable names.
the indentation
the line length. tho this will not stop the code from working it makes it far easier to read when you keep your line length under 80 characters. The reason for this is because the standard console output window is only 80 characters wide (like the command prompt)
the use of camel case variable names. again this will not stop it from working it is merely a way to determine what is a class and what is not. so the use of upper case in variable names is against standard practice. tho one exception seems to be instead of using an _ for a space you can squish 2 words together with the second word having an upper case first letter. Technically speaking... the variables should be in all uppercase because it is a constant and will never change.
those are the ones i can remember off the top of my head
the way i did the classes is more of a nicety for use in EG. because if you create an event that gets triggered that event can be used to grab the proper code. without the need to hard code the whole thing...
event = eg.event.string.split('.')
command = eg.globals
while event:
    if command is None:
        break
    command = getattr(command, event.pop(0), None)
if command is not None:
    print command
jachin99
Re: Check my script
Post by jachin99 » Mon Nov 27, 2017 7:48 pm
EDIT- Nevermind
Re: Check my script
Post by kgschlosser » Mon Nov 27, 2017 7:53 pm
so if you set your event to 'XB1.Power.off' and place an even in a macro that is XB1.* along with that python code then you are good to go. make sure you have that XB1 class added to the globals first.
Re: Check my script
Post by kgschlosser » Mon Nov 27, 2017 7:56 pm
here is another way to loop it as well. I kinda like this one better. dunno why. just do. I think it would run faster if actually timed.
for cls_name in event:
    if command is None:
        break
    command = getattr(command, cls_name, None)
    print command
