Urllib2 http to kodi error
holdestmade
Post by holdestmade » Tue Oct 24, 2017 11:03 am
Hope someone can help with this.
I use the python code below to send a notification to several Kodi instances and all works great, except when one or more is turned off then I get a traceback error and it stops the whole script.
Is there a way to test if Kodi is reachable before running the code below ?
I have tried the XBMC2 plugin and that doesn't error but on Kodi I get a notification about a new connection before the notification I send and would prefer not to have that.
urllib2.urlopen('http://' + kodi_ip + ':8080/jsonrpc?request={"jsonrpc":"2.0","method":"GUI.ShowNotification","params":{"title":"' + title + '","message":"' + message + '","image":"","displaytime":' + str(duration*1000) + '},"id":1}')
eirik226
Re: Urllib2 http to kodi error
Post by eirik226 » Tue Oct 24, 2017 11:22 am
I don't really know how to code it but if you use error handling in the python code it should solve it.
I don't know how Kodi will respond but for websites it's 200 ok, 404 not found and 400 bad requests.
So you can basically solve it two ways I think, with IF statement, aka if respond ok continue else stop.
or with try statement:
https://docs.python.org/2/tutorial/errors.html
You should look at 8.3 --> https://docs.python.org/2/tutorial/erro ... exceptions
Edit: Something like this, I think should work:
import urllib2
kodi_ip = '10.0.0.10'
title = 'test'
message = 'test'
duration = 10
try:
except:
    print 'ERROR'
You can add more function to it as well if you want, how long the timeout should be etc.
EDIT 2: If you take a look at this URL you should get some ideas: https://stackoverflow.com/questions/249 ... -reachable
holdestmade
Post by holdestmade » Tue Oct 24, 2017 4:52 pm
Wow, that works perfect ! many thanks.
I'm reading up the link you sent for next time !
Cheers
